Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Outback
    Outback
    from NE Vic, Oz
    Woohoo I wish I could hear this one run
    porkshop, Kelly Burns and 427 sleeper like this.
  2. Nice work there Marty. I see what you did there with the 2-piece base mount and fully adjustable stanchion post to the connecting links. A lot of time spent doing layout there. Well done pal.
  3. Marty Strode
    Marty Strode
    I got the unit set in place and the throttle connected to the pedal. Now I need a small boot to seal at the firewall. Taking the unit to Spud Miller this week, to get it checked out. IMG_1176.jpg
    BigJoeArt, alanp561, swade41 and 25 others like this.
  4. Marty Strode
    Marty Strode
  5. Weedburner 40
    Weedburner 40
    Looking good Marty, should be having fun pretty soon>
  6. Tim
    Tim
    from KCMO
    Looks great!
    Sharpone and porkshop like this.
  7. Marty Strode
    Marty Strode
    After I left Mitch Kim's place, I stopped to help out my old buddy Lonnie Gilbertson on a project. He gave me some new drive belts to go along with the rest of the parts, I got from Marlo Treit. Now I can get the fuel pump drive completed. Nice to have friends ! IMG_1219.jpg IMG_1222.jpg
  8. Stan Back
    Stan Back
    Treit's a Treet.
    Stogy, Sharpone and 427 sleeper like this.
  9. Johnny99
    Johnny99
    Truck looks great Marty!
    Stogy and Sharpone like this.
  10. Marty Strode
    Marty Strode
    I hope so Dale, we are close to start ***embly of an aluminum head 331 incher, with 1- 13/16 injector. I am nearly done with customer stuff, so I am looking forward to making strides on all these projects. Take car my friend.
    alanp561, porkshop, Stogy and 6 others like this.
  11. Marty Strode
    Marty Strode
    Thanks Tim !
    porkshop and Stogy like this.
  12. Marty Strode
    Marty Strode
    Jim, I have known Marlo for fifty years, and watched him race since the early 60’s. He has a wild imagination!
    porkshop, Stogy and 427 sleeper like this.
  13. Marty Strode
    Marty Strode
    John, maybe we will finally get side by side, this year, have a happy one !
    Stogy likes this.
  14. jimmy six
    jimmy six
    I too have known Marlo a long time. I’ve always enjoyed his company when we find ourselves at the same spot. I understand he will be off to Australia with Project 550 this year. I wish him and Les the best of luck.
    Marty…. The roadster looks great!
    Stogy likes this.
  15. Marty Strode
    Marty Strode
    Thanks JD, Weather kept them off the Aussie salt last year, they could use some luck. Will you be going to Speedweek this year ? If so, I hope to see you, I enjoy your company !
  16. jimmy six
    jimmy six
    Not sure…looking at the October meet. Too hot for me in August and the waiting in line all day is gotten out of hand. One car every 10 minutes is ridiculous……
    Lowbuck DR likes this.
  17. Johnny99
    Johnny99
    Sounds like fun! Always a blast when it's a close race running side by side, hope that's the way it is when we go at it. Happy New Year to you as well. The car has new coat of paint, the 468 is done, just got finished with back brace on the rear today, housing ends tacked in place, waiting for new rear brakes and axles to arrive for a trial fit before final welding. Then there's the rest of the to do list, ugh! Take care, John
  18. Marty Strode
    Marty Strode
    I am not going to have a chance against that combo, it’s looking great!
    Sharpone, porkshop and Just Gary like this.
  19. Johnny99
    Johnny99
    A high winding injected small block in a fly weight model A. I'm not falling for that "not going to have a chance" stuff! I was born at night, but it wasn't last night.
  20. Marty Strode
    Marty Strode
    It does run pretty slow.
  21. Marty Strode
    Marty Strode
    I finally got around to installing the mandatory side bar. It's some of the same 1-3/4- .125 wall 4130 that I used on the rest of the bar. It was a little rusty, but I looped some Emery Cloth around it, and clamped it down under the tool post, and shined it up.
  22. Roothawg
    Roothawg
    Marty, what do the rules say about a floor mount? Just wondering if the plywood floors would be an issue? It looks great btw.
    porkshop, alanp561, bskustoms and 2 others like this.
  23. Marty Strode
    Marty Strode
    Root, it has steel brackets on each side of the rail. On the side with the plywood there will be steel sleeves welded to the bottom of plate that reach through the plywood, for solid contact to the gusseted lower mount. I am also going to skin the plywood with aluminum, top and bottom.
  24. Roothawg
    Roothawg
    Gotcha. Thanks.
    porkshop likes this.
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    Did you use the longitudinal feed or just run it manually? Sure looks good!
  26. Tim
    Tim
    from KCMO
    Looking good! I had a quick question about your distributor/ mag clearance on the firewall. Where relief/cove meets the flange between the upper and lower firewall do the halves of the cove just **** up against each other or did you add a flange on the back side to bolt it together?
    I have a similar operation in my future and have been eyeing solutions.
    porkshop and 05snopro440 like this.
  27. DDDenny
    Bruce
    More importantly, ask him if he has ever done it by wrapping the emory cloth around the tubing and gripping it with a closed hand (thumb under tubing), I bet his answer would be............
    Only one time!
  28. Marty Strode
    Marty Strode
    I also learned to run the spindle in reverse to have the the tension on the cloth on the top. Big difference.
    porkshop, Outback, bchctybob and 5 others like this.
  29. Marty Strode
    Marty Strode
    Bruce, I just ran it manually.
    porkshop and Sharpone like this.
  30. Marty Strode
    Marty Strode
    Tim, the side flanges are bolted together, and the middle has a narrow flange that rests on the lower half. I plan on using seam sealer on everything, when it goes together for the last time. IMG_1290.jpg
