50's Chevy 235 has no oil filter??
Discussion in 'The Hokey Ass Message Board' started by tuekwik4u, Feb 22, 2025.
  1. tuekwik4u
    tuekwik4u
    I'm so new to this old motor, did GM really make this 235 motor with no oil filter? From what I have researched, it only has this oil line on the driver's side engine block that goes towards the front of the motor and connects to the head on the p***enger side of the motor??
    Sharpone likes this.
  2. Matt Dudley
    Matt Dudley
    from New York
    Oil filters were optional in those days. Most got them, but if you wanted to be cheap you could get it without. There are a lot of aftermarket housings that were available, where you might find an engine that originally never had one, now has one. The engines are set up for byp*** filters, which isn’t full flow like today’s engines.
  3. tuekwik4u
    tuekwik4u
    Ok. So I can test run the engine just the way this engine is? Sorry for the questions but I'm still learning
    Just Gary and Sharpone like this.
  4. finn
    finn
    An oil filter wasn’t even standard equipment on the 265 sbc when it was first released in 1955, although it was an option.
    2OLD2FAST, Sharpone and bschwoeble like this.
  5. Lone Star Mopar
    Lone Star Mopar
    Yes you are fine to run it as is.
    I didn't run the #s but like mentioned it looks like a 216 or early 235 splash oiler at a glance. Not going to win any races, but they're tough as nails & plenty of torque.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved this to the main forum. The antiquated section is for 65 and older non automotive stuff
  7. BJR
    BJR
    With that T fitting and valve, my guess is the rocker arm oiling in the block is plugged and that is an auxiliary oil line to the rocker shaft.
  8. hepme
    hepme
    Right, I had a 55 265 that had an external filter at the front of the engine--on a bracket that looked like a piece of old 3/8" steel bent into a U and cut with a cutting torch. I don't think it did a thing.
  9. BJR
    BJR
