Projects Building a 57 Chevy Shop Truck
Discussion in 'The Hokey Ass Message Board' started by swade41, Nov 1, 2017.
  1. swade41
    swade41
    from Buffalo,NY
    The history is that way back in the 7th century someone in my family took the name for their own, so I've known it for all my life.
  2. pila38
    pila38
    Well…that makes a ton of sense then! Learn something new everyday.
    porkshop and swade41 like this.
  3. pila38
    pila38
    And thank you for your service.
  4. swade41
    swade41
    from Buffalo,NY
    I'm thinking I might try this effect I did on this test panel for the Henry J to the inside of the bed (in turquois and maroon) then blow a bunch of dirt into it.
    Like I mentioned earlier I've never really tried to match old paint and I'm not a huge fan of fake patina.
    The only thing left of the blue will be the cab shell and the hood, the fenders, doors and bedsides will all be an ***ortment of different colors, so maybe I'm just chasing my tail here to match that bed paint.
    Blue and green fenders
    Gray rear fenders
    A black door
    And a gray door
    I do like the way this Willys looks with it's fake barn dust look, I wouldn't be opposed to something like this with corner gas station shop truck lettering.
  5. Toms Dogs
    Toms Dogs
    from NJ
  6. LOST ANGEL
    LOST ANGEL
  7. swade41
    swade41
    from Buffalo,NY
    I cleaned up the angle strips and wheel tubs then gave them 2 coats of gray primer sealer then 2 coats of red oxide.
    Then I taped them up and seam sealed the gap in between wheel tub and bedsides
    Picked up some seaside and burgundy paint and wadded up some shrink wrap. The burgundy quit spraying almost immediately, but none the less I wasn't to impressed with it, although I didn't throw any dirt at it yet lol
  8. lumpy 63
    lumpy 63
    What red oxide is that Phil?
    porkshop likes this.
  9. swade41
    swade41
    from Buffalo,NY
    Rustoleum's finest, really called rusty metal primer, but red oxide sounds so much cooler
    Chucky, porkshop, Okie Pete and 5 others like this.
  10. swade41
    swade41
    from Buffalo,NY
    Round 2, satin teal followed by some kind of satin red, shrink wrap dabblin, then a little primer dusting followed by some teal sprayed directly on the shrink wrap and more dabblin.
    It might tone down a bit once it's completely dry, at any rate there's a few layers of paint on it for protection.
    20250224_155124.jpg 20250224_155150.jpg 20250224_154816.jpg Screenshot_20250224_164501_Gallery.jpg
  11. swade41
    swade41
    from Buffalo,NY
    I messed with it more today, tomorrow I'll scotchbright it then move onto further adventures
  12. swade41
    swade41
    from Buffalo,NY
    I mocked up the new crossmembers that hold the box to frame to get an idea of how much they need trimmed backed do to the new wheel tubs.
    I used the wheel tub templates I had made before welding them in. Cut out with an exacto knife it fit over the end of the crossmember and made for a perfect pattern to trace.
    Lop it off
    And see how good a job you did
  13. swade41
    swade41
    from Buffalo,NY
    I spent the afternoon making my bed so I could mark the cuts needed at the wheel tubs and holes drilled in the outer boards.
    It was kind of a pain in the *** to be honest with you, I squared the bed to frame, figured the bolts would just drop in the holes, nope.
    But in the end I got there
    This needs cut out
    I'm thinking I'd like a dark brown walnut stain maybe
    rod1, Chucky, porkshop and 11 others like this.
  14. chevy57dude
    chevy57dude
    That bed looks beautiful. Clear wood with no knots stained dark, you can't go wrong.
    porkshop, mad mikey and swade41 like this.
  15. swade41
    swade41
    from Buffalo,NY
    I don't know much about wood working, I just know it's supposed to have something on it to seal out moisture and UV rays.
  16. Bigtrain
    Bigtrain
    I’m partial to black stain and spar varnish.
    You’re making great progress.
    porkshop, tb33anda3rd and swade41 like this.
  17. swade41
    swade41
    from Buffalo,NY
    Originally I wanted to do rough cut lumber and used motor oil stain, then I went and bought this fancy oak kit lol
    Tickety Boo, porkshop, pila38 and 2 others like this.
  18. swade41
    swade41
    from Buffalo,NY
    Took it back apart this afternoon and cut and drilled the boards
    The holes even lined up
    Next step will be to recess the board so the wheel tub can sit down into it, leaving the angle strip flush on the surface
    rod1, Tickety Boo, porkshop and 6 others like this.
  19. pila38
    pila38
    Not gonna lie, the rough cut lumber and used oil would’ve been sweet. However, your doing a damn nice job, so that fancy floor is looking good in there too.
    427 sleeper, swade41 and guthriesmith like this.
  20. swade41
    swade41
    from Buffalo,NY
    If the Amish wasn't so far away I would've done it, would've fit the theme of the truck better, but ya know these themes change, heck I started out wanting a Project X truck
    porkshop, 427 sleeper, pila38 and 3 others like this.
  21. 1956 F100
    1956 F100
    from Louisiana
    rod1, Paul B, porkshop and 4 others like this.
  22. swade41
    swade41
    from Buffalo,NY
    What color of stain is that ?
  23. 1956 F100
    1956 F100
    from Louisiana
    Here are the products I used. I stained the bottom and edges black so it matched everything under the truck. 7 coats of urethane .
  24. swade41
    swade41
    from Buffalo,NY
    I got the two planks recessed using the good ol drill press hole saw mill hack method, worked much better than doing it by hand that's for sure.
    All that's left for the boards are sanding and stain, but undecided if I should wait till more of the truck is together to pick a color or not.
    I'm not sure how long I can store this wood without it warping.
    57tailgater, porkshop, rc57 and 5 others like this.
  25. Dick Stevens
    Dick Stevens
    They can be stored for a long time if they are in a humidity controlled environment, warping occurs when the wood either dries out or is exposed to moisture. The easiest way to prevent warping is to stain and finish them with varnish or polyurethane on all sides.
  26. Dooley
    Dooley
    from Buffalo NY
    I was thinking you were going to use a grinder to recess them..turned out good. You and the hole saw are your own cnc machine
  27. neilswheels
    neilswheels
    from England
    This is great, cant believe i've not found it before. Love the engine choice, or choices, now following.
  28. swade41
    swade41
    from Buffalo,NY
    I tried that first with a flap disc, then a cutoff wheel, then a regular grinding wheel, a sander, that yellow wood chisel.
    Then I smarted up lol
    porkshop and Tickety Boo like this.
  29. swade41
    swade41
    from Buffalo,NY
    Thanks, this isn't going to be a speedy build by no means but we'll get there
  30. swade41
    swade41
    from Buffalo,NY
    Added some brown to my ugly fake patina, toned down the new colors a bit and kinda blends in better now
    X-cpe and Dooley like this.
