After looking at pictures of the 39 Ford clutch pedal ***embly, isn't it set up to push the stock clutch fork? When using a SBC clutch fork set up that has to be pulled so I'm guessing the 39 Ford pedal ***embly has to be dissembled and flipped. Am I correct? Thanks
I’ve flipped several of them If you use a nova bell housing it’s nearly a straight pull and the brake pedal won’t hit the fork
You can also use an early ford style adaptor and save yourself a lot of head ache. for example, let’s say you’ve got a sbc and a t-5 going in your 39 use a sbc to early ford adaptor mated to an early ford to t-5 adaptor. then you can use the stock clutch linkage and everything works harmoniously
You remove the pin from the clutch pedal; rotate the actuating arm 180 degrees so it faces down, align the clutch pedal, drill a new hole, and pin the clutch pedal.
That I can’t say I’m building 36 with a nova bell housing and a 39 pedal ***embly. But won’t be there for a year or so Sorry
