Projects Poly begets a Hemi begets a Model A
Discussion in 'Traditional Hot Rods' started by wstory, May 21, 2020.
  1. brigrat
    brigrat
    from Wa.St.
    I have a stock S10 T5 in a '55 Chevy, 350, 370 gears, shifts like ****er. If you don't have a heavy foot & big weenies I don't see the need for overthinking it with a WCT5, other than gear ratio choices.
    brEad likes this.
  2. Tim
    Tim
    from KCMO
    Any updates?
  3. wstory
    wstory
    from So Calif
    On the S10-T5, I now have about 3,000 / 4,000 miles on the new trans. Other than getting the hydraulic T/O bearing dialed in the trans seems okay. It seems a little louder than I recall, tho the car has little sound insulation and,...I may be over thinking it because of past experience o_O
    warhorseracing, stillrunners and Tim like this.
  4. wstory
    wstory
    from So Calif
    On the 180 degree headers,...I'm thinkin about a reboot. The flame went out late last year after several failed attempts to stuff all of the pipes between the head and frame rail and get all that under the toe board on the driver side. Re that, I'm also looking at cowl steering and suspended pedals because of space issues.
  5. Tim
    Tim
    from KCMO
    Good to hear about the new trans! The re work with the headers is a frustrating spot to be, but I am curious to see how you tackle it.
  6. wstory
    wstory
    from So Calif
    Sheech!!!!! It's been well over a year since I shared anything on the Header Project. :eek: Wellll,...I'm back. Finally ****ed up my enthusiasm to get back to the challenge. When I last left this project, I was struggling to stuff all the tubes in the space available. Today I gave up, and ripped everything out,....again. The last two pics are todays effort. Hopefully 3rd time's a success. I've run outta tubing bends so I'm on the site with Summit,....AGAIN!
    Deutscher, brEad, 63fdsnr and 9 others like this.
  7. Tim
    Tim
    from KCMO
    “Third times the charm”
    on the upside you’ve probably got one heck of tubing wall display in the shop now!
  8. 40ply
    40ply
    The best part about working with metal is you can cut it out and weld it back together again. Glad to see you're back at it!
  9. jimpopper
    jimpopper
    I’m going fender less and started with a used set of 50 dollar exhaust from a 454 race car. Even traveling outside of the frame has issues so I can only imagine the scope of your efforts. IMG_2232.jpeg
    warhorseracing and Outback like this.
  10. wstory
    wstory
    from So Calif
    This thing is kickin my ***! Dunno if I posted this diagram before. It's my guide to connecting all the dots. I found it quite easy to get my tubes crossed :eek: The latest challenge was finding the routes for primaries #4 and #6 and,..... I had to adjust #1 and #7 to make room for them.
    Pretty sure I've got it now after relocating the #1 "swirl".
    thumbnail 6.jpg These two guys, #4 and #6 were the biggest headache,....making room for them and then connecting the dots.
    As you can see everything is "tacked" together. The next order of business is to remove sections,....without upsetting the many connections and finish welding without introducing warpage that would make re***embly difficult if not impossible.
  11. rockable
    rockable
    You're a talented man and a stubborn one, Mr. Bill! I would have thrown in the towel a long time ago. Go, Bill, Go!
    HemiDeuce, 73RR and j hansen like this.
  12. 73RR
    73RR
    Bill exemplifies what being a hot-rodder/car guy is all about. Damn fine work!
    j hansen likes this.
  13. wstory
    wstory
    from So Calif
    FINALLY ! ! ! ....., another milestone.
    Although I anticipated having enough clearance to remove the headers (it's really tight), I was a bit concerned after tacking everything together that I might get a nasty surprise. Concern gone ! After unbolting both the flange to the engine and the manifold routing primaries under the pan, the driver side header dropped out slicker'n snake ****.
    Now on the bench, finish welding can proceed. The blue tape seen in the second pic is temporarily holding those two primaries in place. Those tubes will be removed in order to provide access for welding otherwise inaccessible joints in the adjacent tubes.
  14. Tim
    Tim
    from KCMO
    Outstanding! Holy cow you did it!
  15. lake_harley
    lake_harley
    That's an impressive bit of fitting tubing and keeping straight where each tube ends up ! I'm just glad I'm not the one who has to weld in all of those tight spots.
    Lynn
  16. wstory
    wstory
    from So Calif
    Whew!!!!!!!!! Now when people ask "Why",... I can respond, "because I can!" T'was touch and go there for awhile but I finally got over the hup. thumbnail 16.jpg
    I, like i image most folks, are inclined toward symmetry and I was frustrated by not being able to approach that. The failure to do that I blame on, 1) the heads are staggered by 3/4 of an inch. 2) the firing order is not consistent between right and left banks. 3) clearance requirements for oil lines on one side and the starter on the other were very different,....a considerable effort to yield symmetrical muffler and tailpipe locations.
  17. 73RR
    73RR
    ...and I thought that I had a touch of CDO...:confused:
  18. rockable
    rockable
    Wow! Congratulations, Mr. Bill! I bet it will sound unique!
  19. wstory
    wstory
    from So Calif
    Still gotta finish from the mufflers back,.....i.e. threading the tail pipes under the panhard bar, over the axle, around and between the tank and the coil overs, and have a symmetrical exit parallel with the frame horns, and ***ure that it can be "hung" and dismantled.
    Deutscher, Tim, HemiDeuce and 2 others like this.
  20. Dick Stevens
    Dick Stevens
    That should be a piece of cake compared to what you've done so far!
  21. Tat2Neil
    Tat2Neil
    from Mesa AZ
    Wow what a great project and killer accomplishment! Hope we get to see/hear a video once you have it running, I’m incredibly intrigued to hear what this will sound like! Great work sir
    Tim likes this.
  22. panhead_pete
    panhead_pete
    Holy cow Mr Bill that exhaust is outstanding!
    chevrod likes this.
  23. flynbrian48
    flynbrian48
    Wow.
  24. BigJoeArt
    BigJoeArt
    Way cool! I've always wanted to try to build a set of 180 degree headers.
    Is there a reason you necked it down so far at the end of the header?
    seems like the tailpipe is really small for the large primaries in front of it.
  25. wstory
    wstory
    from So Calif
    A lot of this project was/is an exercise to see if I could actually pull it off. I attempted the same on my 32 several years ago but gave up. That experience drove several decisions. This engine is all of 270 inches, the previous being 325 inches,...with 1-5/8 primaries and 2-1/8 exhaust. The Model A has less real estate than the 32. So,....smaller tubing like 1-1/2 inch primaries and 2 inch exhaust means tighter bends for tighter spaces. And then, getting all the "plumbing" collected and stuffed under the firewall while preserving foot space, with gentle transitions, lead to the extended collectors.
    Also because of that "box of snakes", I am driven to suspended pedals and cowl steering,....cool but, no surprise, more challenges!
    Current status is completing the system from the mufflers to the end of the tailpipes. Until now I've guestimated clearances between panhard bar, axle, coil-overs and gas tank, which are all very tight. I'm hoping to receive and install the coil-overs in the next few days, and not receive any surprises.
    Deutscher, Tim, brEad and 4 others like this.
  26. wstory
    wstory
    from So Calif
    EXHAUSTED ! ! ! :rolleyes:
    Can't claim to be done but close enough. You'll note that many of the joints are still "tacked". That so's sections could be broken apart to adjust clearances which are really tight. Like 40ply sez " nice thing about steel" Also got the coil-overs mounted and hangers figgered. Finish welding will be "cake".
    And,.... I love looking at and recording the curves and spatial relationships.
    Deutscher, Tim, brEad and 9 others like this.
  27. Looks great Bill! Nice progress.
  28. wstory
    wstory
    from So Calif
    Few more that I couldn't figger how to edit into the sequence :mad:
    Deutscher, brEad, Tat2Neil and 9 others like this.
  29. 40ply
    40ply
    Really nice work Bill. I don't know why but I'm watching your thread but I sometimes don't get notifications. I'm all caught up now.:cool:
  30. wstory
    wstory
    from So Calif
    Welllll,....finish welding was NOT cake. There were four surfaces that had to line up,..the exhaust manifold surface on each head and the flanges that connect the four primaries that cross over beneath the oil pan. Many of the connections were "tacked" but when I took the whole pile of snakes apart, several of the tacks failed. I was particularly concerned about warpage when doing the final welding so there was a lot of trial and error and fitting and refitting to ***ure everything would, in the end, bolt up.
    20250429_164018.jpg Finally got all the welding done and all sub ***emblies bolt to the engine and to each other.
    I'm planning to get this stuff media blasted and then coated with High Temp exhaust paint. I know the High Temp is not the best but it will be quite some time before this guy is fired up and the paint will protect from corrosion in the meantime.
    Enjoy the pics. I sure like looking at the final result that will "embrace" the engine!
    20250429_165421.jpg 20250429_165427.jpg 20250429_165656.jpg 20250429_171345.jpg
