Technical Large cam degree Wheel
Discussion in 'The Hokey Ass Message Board' started by 19Eddy30, Feb 25, 2025.
  1. 19Eddy30
    19Eddy30
    from VA
    Looked on line , @ one time I thought I seen like a 20 -24 inch made out of Aluminum , resembled a 4 spoke steering wheel ,
    Anyone know of ?
    Sharpone likes this.
  2. Joe H
    Joe H
    I made a 30" wheel out of plywood, then went to one of the local print stores and had them print off a generic degree wheel at 30" diameter.
    This is the one I use now, https://www.blocklayer.com/degree-wheeleng I just enter the cam information and have it printed off in the size I need. Then when degreeing the cam, theres no figuring, its all right on the degree wheel.
    jet996, seb fontana, 19Eddy30 and 2 others like this.
  3. Comp Cams lists 4 spoke wheel.
    lothiandon1940 and Sharpone like this.
  4. Bentrodder
    Bentrodder
    from Cotati
    Serious question. What's the advantage of the bigger wheel? Just easier to see?
    seb fontana, Tickety Boo and Sharpone like this.
  5. Sharpone
    Sharpone
    Wow cool, I saved this and will use it in the future Thanks!
    @Bentrodder the larger the wheel the more accurate your degree readings will be - less error, also easier to read.
    Dan
  6. Oneball
    Oneball
  7. earlymopar
    earlymopar
    Larger wheel = improved accuracy
    Sharpone, Tickety Boo and Bentrodder like this.
  8. 19Eddy30
    19Eddy30
    from VA
    I have a few 9 & 12 , looking for 20 -22
    Maybe , Big Diesel or Aviation .
    Good ideal on Printing degs on vinyl or sticker @Joe H .then add to aluminum or plexi /Lexan etc.
    & @Oneball Yes $$. Comps is 16 inch,
    If I remember correctly, what stood out on the steering wheel design deg wheel You could rotate wheel turning
    The crank ,
  9. Joe H
    Joe H
    I found when i printed on paper from home and taped them all together, it worked just as good as a one piece printed at the store. It was super easy to check with the cam spec's already on the degree wheel. I used a old small degree wheel to bolt the large diameter plywood to, 1/4" plastic would be a good choice also.
