Vintage mechanical fuel injection pictures
Discussion in 'Traditional Hot Rods' started by longstory1948gmc, Aug 11, 2014.
  1. DDDenny
    Ditto!
    sdluck and 427 sleeper like this.
  2. Russ B
    Russ B
    The tubes were made by the original engine builder from two tubes. I converted the motor from alcohol to gas and changed the tubes to a shorter set available from Hillborn/Fuel Injection Engineering. It was at least 13:1 compression.
    427 sleeper likes this.
  3. I have none of this stuff anymore. After I quit racing, it was time to liquidate. However, after I started to run mech f.i., I became much better at tuning carbs. Learning what the engine needed rather than letting the carb make a general decision made adjustments simpler. :)
  4. das858
    das858
    Our current set up in our dragster, its a Gene Adam's Hilborn . 20240828_110645.jpg
  5. 29Sleeper
    29Sleeper
    from SoCal
    MojoRacing, enloe and Deuces like this.
  6. Flatrod17
    Flatrod17
    My old Arias unit adapted to my 4 banger. Been running it on the street for a couple years now. 12-28-22.jpg
  7. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    Here is one I was involved with a few years back,still take it out once in a while.I ran a electric fuel pump to a ac 20201022_212012.jpg ***ulator tank on the firewall and used the belt driven pump to draw from that tank on the firewall.Works great and has been a good set up for driving it around although not traffic friendly.
  8. Stan Back
    Stan Back
    I drove my injected roadster as my only car for years with a 3-gallon Moon tank in front of the radiator with a 10-gallon tank in the back. It had a cut-down carburetor float chamber that kept the Moon tank about 2/3 full. Worked fine. A lot easier than using the dash-mounted hand pump for the six 97's using the 10-gallon tank in the back. Low on gas -- pump a lot to get started, lots of gas in tank -- constant pumping now and then. Worked fine at over-pressurizing the 97s and starting a fire.
  9. Jtaylorok327348
    Jtaylorok327348
    How did this turn out ? Did you mount it on a W motor ?
  10. jnaki
    jnaki
    single Hilborn injection on a Buick motor
    Hello,
    We have always liked all of Tommy Ivo’s race cars. They were always finished to the umpteenth point and ran like the top performer it was. Lots of victory trophies in the FED cl***es and Top Eliminator trophies, too.
    It was one fast FED while the compe***ors wished he would go to another dragstrip on alternating Saturdays… ha! But, the single injected Buick went to other So Cal drag strips as an alternating drag race day, much to the dismay of those wanting to be the Top Eliminator, elsewhere.
    Jnaki
    But, as much as we liked the single engine Buick Motor in the Kent Fuller Ch***is, we always had a laugh or two. When my brother and I talked about how cool it would be to show up at Lion’s Dragstrip with that injected motor in our dad’s 57 Buick Roadmaster, it was fun to dream.
    What cl*** would it have been? The heavy weight would have put it in D/Gas even with the injected Buick motor. The Bruce Slicks tucked neatly under the rear wheel openings and the sound of the rumbling motor would have made others take notice. !!!
    But, in late 1959, this showed up unexpectedly at the Lion’s Dragstrip and Riverside Raceway pits.
    If one is good, then two is better than one… YRMV
    lurker mick likes this.
  11. Dave G in Gansevoort
    from Upstate NY
    Saw this back up. Fixed the old post. Here it is again so you don’t have to scroll back to it IMG_0270.jpeg
    20a nozzles on methanol, have a set of 7a for gasoline. They’re waiting for an engine to get finished now…
  12. tlap
    tlap
    from So. Cal.
    D-Russ likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    @D-Russ
    From what I see in pic ,
    Yes Hilborn , by the hard lines , Looking
    70s early 80s, if original too.
    Some small manufacture Maybe dirt racing ? Did you try Kinsler , @ one time
    Good source also for all type of MFI
    Small & big companies
    D-Russ likes this.
