What would happen if you had too of a soft coil springs in a M2 front end?
Discussion in 'Off Topic Hot Rods & Customs' started by Roothawg, Feb 25, 2025 at 8:24 PM.
  1. Roothawg
    Roothawg
    I have been driving my old straight axle this week and it rides pretty harshly.
    I decided to put a M2 in my next project and I would like to soften the ride as much as possible.
    If you run a spring rate that is too low, what will happen, ride wise? Too low? Too bouncy?
  2. squirrel
    It bottoms out all the time.
    Spring rate, and spring height, are both important. It needs to sit up enough to have decent travel, and also have stiff enough springs that it doesn't go further than full travel. If the springs are too stiff, you'll get a rough ride because the suspension won't deflect over bumps.
    rockable and nunattax like this.
  3. Roothawg
    Roothawg
    My 35 just jars your teeth when you hit the expansion joints. With this next build I want to avoid that.
    I wonder about tire size also. I have the VW tire size up front 165/15. I was thinking a guy might go with a little more surface area to cushion. The wife's Lincoln has those little rubber band tires from the factory and it rides better than mine. Of course, it's the latest technology vs horse drawn wagon technology.
    I was looking at a 275-300 lb spring. The weight of the truck is about 2600# Figure 60/40 weight split =1560# divide that by 2 wheels=780# divided by 2=390#. Is my thinking right here?
  4. squirrel
    the control arm gives some leverage on the spring, so the load on the spring is not exactly the amount on the tire. It's complicated.
    rod1 and Roothawg like this.
  5. vtx1800
    vtx1800
    When I installed the MII in my 38 I tried to use stock four banger springs from the Mustang I "relieved" of it's components:) They were way to long/stiff whatever. I couldn't even get the shocks to bolt up. That was when the bolt on style was made in eastern Iowa (twenty years ago), I called their tech guy, he told me what I needed and in a few days I got 'em and installed them, rides fine now.
    Short answer, call the tech line, good luck!!
    Roothawg likes this.
  6. RodStRace
    RodStRace
    There 's a rear spring thread going which is trying to gather data points for guidelines.
    https://www.jalopyjournal.com/forum/threads/post-rear-coil-over-lb-rate-for-your-car.1330859/
    As @squirrel said, you rarely have a spring vertical acting directly at a 1:1 relationship to tire movement. There are formulas and charts, opinions and back to back testing, but the best source is going to be the people on the front line every day, trying to sell the right part the first time. Just like cams, it has to fit the combo and usage.
    EXAMPLE
    https://www.eatondetroitspring.com/mustang-ii-coil-springs/
    275 to 450!
    I remember an old article that compared 2 different schools of thought on road race springing. One liked a softer spring with a very strong shock. The other liked a stiffer spring with less firm shocks.
    Both were respected, professional team owners. If they couldn't agree, what chance do us regular folk have?
    EDIT, didn't find the article, but remembered one of the names. Here's a discussion about Herb Adams and his stance. Not MII but you get the idea, that even in this modern age with computer simulations, and F1 drivers doing laps in simulations, it isn't an exact science.
    https://www.camaros.net/threads/herb-adams-advice-for-springs.29493/
    snoc653, rockable and Roothawg like this.
  7. Roothawg
    Roothawg
    I figured if I could get close, I could experiment. The good thing is the springs are fairly cheap, so I wouldn't be saddled with a life long regret.
    RodStRace likes this.
  8. rockable
    rockable
    Eaton Detroit has never steered me wrong. Call them. The lady who answers the phone (Sandy?) has been doing it for years and has a great database. I buy all my springs from these folks.
  9. Damon777
    Damon777
    I'll also vouch for Eaton Detroit. Swapped my old cut springs for new drop springs in my 50 and it made all the difference in the world for ride quality.
  10. TexasHardcore
    TexasHardcore
    from Austin-ish
    Adjustable (Height & Dampening) coilovers??
    nunattax likes this.
  11. snoc653
    snoc653
    from Iowa
    I am a fan of the softer spring theory. For road racing I feel the spring balance is more important than other applications might require. I know that on my 51 with a big block I have opted for a slightly softer springs to allow the front end to come up and transfer weight to the rear. Heidt's had multiple spring options for the 51. I went with the heavier small block springs which were 50 lbs lighter than the heavy small block springs. I plan to use shocks with adjustable extension and compression to control the front end lift and rebound compression. As long as the springs don't reach coil bind they should be the right choice. If the shocks can't keep the spring extension from hitting the stops on them, I might have to put a full extension limiting strap on them. If the shocks bottom out and over extend the shocks then I'll have to go to a heavier spring. Spring rates and how to control the ride quality is considered by many to be a science that most will never fully understand. For those of us that fall into the category of not fully understanding, we need to rely on trial and error to a large degree. The OP would be ahead to contact one of the suspension companies and use their experience to minimize the potential for error based on the trials made by their customers.
    swade41 and RodStRace like this.
  12. Why not take a few leafs out of your straight axle ride to improve the ride ?
    As far as the mustang ll spring thing it reminded me of a thread here a long time ago of good riding springs. I ordered the springs that many had recommended as being "the ones to get" what arrived was a spring that was much taller but slightly smaller coil diameter.
    It took all I could do to get them in, I'm lucky I didn't decapitate myself, look at the banana bow in these cocksuckers
    Old springs
    New banana springs, this is sitting on the ground too !
    I don't remember what springs I used afterwards but I did cut a coil off of them to dial it in and it rides great
  13. nunattax
    nunattax
    this is the way to go.cutting springs is stone age carry on .
  14. squirrel
    also you can't compare springs until EVERY part is on the car...and you've driven it around a while...
    Cutting springs works OK if you understand how it affects things. But if you don't, you'll be in for a surprise.
  15. Roothawg
    Roothawg
    It's a brand new set of Posies Reversed eye on 4" drop CE axle. No room to go any lower.
  16. nunattax
    nunattax
    can you post a picture of your current front end set - up
  17. gene-koning
    gene-koning
    Are you sure the springs are not bottoming out now, or that something else might be bottoming out? Maybe the shocks are bottoming out? How much air pressure do you have in your tires?
    You may already have too soft of a spring!
    Larger diameter radial tires tend to ride better then short wall bias ply tires do.
    Modern gas filled shocks give a harsher ride then the old oil filled shocks did.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    If the cross spring in your pickup is too stiff, why not remove a leaf or 2 to soften it and simply put a block on top of the spring to get the ride height back?
    rod1 likes this.
  19. I will be the odd man out but I would not use a mustang 2 suspension. The lack of travel under normal driving conditions is a severe downside. I owned an original mustang 2. I can tell every car I have ridden in with a mII front in about 50 feet. It has filled a place in our world. Affordable, adaptable, many positives. But I would look for something with more travel. I spent years with a straight axle 32. The lowered springs are stiffer which gives far worse ride quality. When you drive them every day under adverse conditions you are well aware of this. Compromises aren't something you may want to deal with every day with age. IMHO. :)
  20. squirrel
    Getting any lowered car to have sufficient suspension travel for a smooth ride, is difficult. The whole point of lowering a car is to reduce the available travel, and there's just no way to have soft enough springs for a smooth ride, if they can't have the travel needed.
    I gave up on lowered cars years ago...
  21. snoc653
    snoc653
    from Iowa
    If the MII suspension is limiting the car’s wheel travel, the car isn’t set up properly. Control arms, springs and ball joints limit travel range. The kit I bought has the same length control arms as the stock car so the travel will be about the same. I don’t see any design issues that will restrict the wheel travel. The harsh ride is from improper spring rates or possibly mechanical binding due to improper setup. Steering geometry can adversely affect the handling if it is setup wrong.
    Edit: As Squirrel pointed out, lowering the car with shorter springs normally reduces the amount of control arms travel thus limiting suspension function. Suspension is more than just the pieces. They have to be designed to work together. Other than being inexpensive cars, MIIs didn’t drive badly and some were tweaked to handle fairly well.
  22. Roothawg
    Roothawg
    I had ElPolacko (Steve) build me a crossmember and a set of tubular control arms with the heavier duty Dodge Dakota ball joints.
  23. Roothawg
    Roothawg
    I already have.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    I don't understand why it is so stiff. My 40 rides as smooth as a gravy sandwich
  25. Roothawg
    Roothawg
    I dunno. I bought the high dollar shocks. It helped, but still...man it drives a man to drink. For 30 years I used the stock axle and it wasnt any better.
  26. twenty8
    twenty8
    Wise words. Your teeth and your butt are no doubt grateful....
  27. Roothawg
    Roothawg
    I get it, I'm getting there...........nah never mind.;)
