As I’m about to embark on lowering our ’50 Ford, I was doing some recon work, I’m going to fab my own front blocks, and maybe my own rears, I was looking at the front lowering kit that Butch’s Cool Stuff sells. I noticed the kit only comes in a 2” drop for several makes, but a 2-1/2” for ’39-’48 Chevy’s. Is there a reason for only offering 2” ones? Is it because it’s an average drop and no justification for investing in casting other sizes or is there a greater reason? When I order my material (bar stock) I can get other sizes just as easily as I can 2”.
If you take a look at your lower 'A' arms, when 'dropping' the lower coil pan 2" below the 'A' arm frame, this part of your suspension becomes the lowest part of the car. Any more than 2" approaches collision with uneven road surface, aka 'Ride Height', or 'ground clearance'. (this is legally referred to as 'Scrub Line') Dropped spindles will result in similar quotient.
IIRC, Aerostar springs will drop your Shoebox 2.5-3", so that's an option if you're rebuilding the front end (or do both if you really want it slammed). Do a search, there's been some threads on the subject with good info.
@A****er Mike, thanks. I've yet to crawl under it and look, plans are to tonight. That makes perfect sense, my mind never went to the scrub line.
@Hot Rods Ta Hell, I'm hoping for a 3"-4" drop, I'm planing doing some spring work, I was just hoping to grab as much as I could with the spacers, but now I see I'm getting 2"!
An issue to keep in mind. When you space the spring bucket down your moving the upper A-Arm up the same amount. This causes the Top of the Spindle Support to tilt inboard. The further up you go with spacers the further in things move. Now at some point the Spindle Support needs to come back outboard to get the King Pin some where close to where it lived in stock form. You accomplish that with a Torch however you can't change the new swing arc of upper A Arm to Spindle Support. The more you increase this arc the crazzier the action at the Big Round Thing in your hands is as you travel over bumps and rises of the road. Yep, you can get used to it if you pay attention.
Just got off the phone with Shoebox Central, they are strongly against the use of the lowering blocks.
I'm saving my pennies for Shoebox Central's front drop kit. Spindles (uprights), and their camber correction pieces for the upper a-arms. I have a new-in-box set of Moog Aerostar springs that'll go in, too. Right now I have cut Aerostar coils and it rides like **** but sits great!
If you lower the rear much more than 2" you will have to deflate the tires to put them on or take them off. Plan to carry a floor jack and a compressor with you in case you have a flat.
There is an option. Narrow your rear Axle 2" per side and run a deep reversed wheel. Tire and wheel nearly fall's out of the wheel house.
As far as spacers go, not using any at all. As far as lowering the car, using his 2" dropped kit. A totally respectable suggestion.
Aerostar front coils & 3" lowering blocks rear. I have 14" rims on now, have 15" rims that will eventually be used.
I installed 1" lowering spacers in my 51', ended up removing them, the lower A-arm was setting just to low. But I also had cut Granada coil springs which made it even lower. I ended up with just the cut coil springs, it dropped it a lot, I was happy with it so I left it! I cut 2 rounds out of the Granada springs.
25 years ago I have put the butches style blocks in a 50 ford with results I felt were good . Not long ago I made some blocks for my 55 bird. started with 2 inch material when I set the car on the ground way to low. front tire were kicked in hard at the top looked like it dropped the car about four inches .I tried to cut them in half with a band saw. they were not super straight had a buddy mill them down strait. ended with about 3/4 inch. I do not know how but it seems it lowered the car close to 2 inches. took it to get aligned didn't need anything
Its interesting you say that, I read somewhere in another post yesterday, maybe by @Pist-n-Broke , that the measured height at the fender was greater that the spacer height. I posted a reply as to what I have done so far in the link below, and its a pretty good thread, not necessarily my post. I'm using 1" x 1/4"w square tubing to fab my spacers. https://www.jalopyjournal.com/forum/threads/lower-a-1950-ford.49132/page-2
I used Aerostar springs on the one I had. Sat perfect and rode great. It had bags on it when I got it, but, not a fan of bags. Then I used Chevy S10 springs, cut two coils, but it was too stiff. So I went with the Aerostar springs. Easy install, no cutting no modifying, besides shorter shocks.
The net vehicle drop will be more than the front spacer height. 1" lower control blocks will actually net you about 2" drop. The reason why is because the blocks are lowering the coil spring pocket, effectively 'decompressing' the coil springs. Once the spacers are installed and the weight of the car is back on the suspension, the coil springs will be less compressed, pose less resistance and effectively lower the car. The plus is that the ride will be better than cut coils. The " 2 inch drop" spacer kit is not actually comprised of 2" thick spacers, as it would be with 2" rear leaf blocks or 2" dropped spindles (spindle built 2" higher than stock).
I made 1" spacers between my lower "A" arm and spring perch along with cut coils on my 54 Merc. Had 5/8" clearance between lower "A"arm and frame. Drove to Paso Robles (2000 miles round trip ) banging on nearly every crack in the road ! Got home, ripped out the lowering blocks and replaced springs with Arostar ones. ...haven't looked back.
@Hot Rods Ta Hell thanks for the information/knowledge! With that and my guestimate, I will be lowering it in the 4" to 5" range, which I feel our car sits high to begin with, so I may have it right where we want it. "If" I have to get new springs for the front, it won't be the end of the world. @Crayons how much did you cut your coils, just curious, I know its not an apple to apple comparison. I don't know if you saw, but I wacked mine 1-1/2 coils.
I have a set thats home made out of thick wall 1" box tubing - all it takes is the tubing, a cut off wheel and a 3/8 drill to make your own - I took them out of my car ('51 coupe) thinking I may keep it at stock ride height - Doing a motor swap now, once Im done and see how the car sits, Id be willing to let mine go - Ill post up a pic and dimensions tonight -
