Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. pila38
    pila38
    I’d probably stick with the old, depending on how old. Nothing with flat tappets is getting better.
  2. -Brent-
    -Brent-
    The first redneck body puller didn't work. It just pulled the vehicles together and flexed the suspensions.
    I had to rig up a fixture that sat inside the trunk. Strapped it to the winch bumper for insurance. It kept the winch from tearing out of the wood.
    Okie Pete, kram, mad mikey and 14 others like this.
  3. saltflats
    saltflats
    from Missouri
    That reminds me of using the power pole out front of my shop and a wrecker pulling on the car we were trying to get into shape.
  4. Sharpone
    Sharpone
    IMG_2963.jpeg Yore not going to skirt it Right?
    Dan
  5. Yesterday would have been a yes
    But rethinking that now. Kinda dig it
    I’ll stick the skirt on soon and see how I like it
  6. lumpy 63
    lumpy 63
    So good. Necessity is the mother of invention.
  7. This may be a stupid question but where or how do you get the little chrome ring on the wheel That surrounds the lug nuts? I have seen this treatment a few times and I really like it It. feels very early '60s or late '50s in the looks department.
    porkshop and Sharpone like this.
  8. Oneball
    Oneball
    They fit on just like a dog dish hubcap.
    porkshop, Sharpone and anthony myrick like this.
  9. Called spider cap rings or something like that
    Ya beat em on like a hub cap
  10. Greg Rogers
    Greg Rogers
    I have never seen rings like that- Me Likey!!
  11. verno30
    verno30
  12. swade41
    swade41
    from Buffalo,NY
    I thought they were called Shannon cones, I believe @wheelkid had a thread about making them a few yrs back
  13. squirrel
    Putting wheel bearing #5 (or is it 6?) in the left side of the Corvette.
  14. Paul
    Paul
    Editor
    figuring belt lengths
    I had some 2" x 1/8" rubber strip, cut a couple to the available belt lengths.
    and ordered one up.
    I'm getting ahead of myself here,
    the engine is an unknown core right now,
    I only went as deep as pulling the heads and dropping the pan, so far it looks like a good candidate, I won't know for sure until it's in for machine work,
    but it's making pretty good garage art right now.
  15. This is a Shannon Cone
    mine are push thru caps and trim rings
  16. swade41
    swade41
    from Buffalo,NY
    anthony myrick likes this.
  17. Got 2 of the 3 galley plugs out.
    got creative.
    The center one is stripped. I’ll either leave it and flush from the front or weld a nut on it
  18. saltflats
    saltflats
    from Missouri
    I always give those a good smack with a heavy hammer before I try to remove them.
    porkshop, Okie Pete, pila38 and 6 others like this.
  19. Might leave it and extend the pipe cleaner and scrub it out.
    porkshop, Okie Pete, Sharpone and 2 others like this.
  20. pila38
    pila38
    Spark plug wires
  21. BJR
    BJR
    Sounds like something in the rear end is bent!
  22. deathrowdave
    deathrowdave
    from NKy
    My Friend , trying heatin it and sticking a candle to it 2 or 3 times . The melting wax can be your friend when a tight spot .
  23. hrm2k
    hrm2k
    I didn’t need another project. But it is for my grandson and I am trying to save him from a Toyota so I bought a 65 Corvair for him. A friend of mine had it…it didn’t look bad. I got it to my garage and up on the lift to find this kind of high performance work. Dryer vent is a nice touch
  24. lumpy 63
    lumpy 63
    Been working on Tempest speedo ***y. The 62 bezel is plastic which is usually destroyed by UV. The 61 bezel is pot metal but getting really hard to find. I finally got one awhile back and took 3 tries to match the dark brown color but I think it's close enough now. 20250228_174641.jpg IMG_20250228_174844.jpg 20250228_174649.jpg
  25. saltflats
    saltflats
    from Missouri
    I drove a airvair for a daily driver for many years. I would go with the 65 and newer model, they are much better drivers.
    porkshop, Tickety Boo, pila38 and 4 others like this.
  26. guthriesmith
    guthriesmith
    Tonight, I was working on eating some good tacos instead of pulling heads off a couple 292’s like I should have been…
    Foot, 57 Fargo, porkshop and 24 others like this.
  27. lumpy 63
    lumpy 63
    distractions are good:D
  28. Sandcrab
    Sandcrab
    Over the last couple weeks I have been putting together a test stand from a wide stance engine stand. I made a slip in frame to carry the radiator and a control panel with mechanical oil and temp guages and a tach. The adjustable supports were from old frame table parts with all thread adjusters to carry the load at the motor mounts.
    I had picked up a number of Aluminum Buick 215 engines in various states of dis***embly and put one together from the pile and started it today. I used an adjustable link belt to drive the water pump since there was no alternator. The belt can be shortened until it is tight enough to just slip over the pulleys. It worked great.
    I expect to build at least two more engines from the pile since I ended up with two re ground cranks that do not appear to have ever been installed and several other engines that I have never heard run including the V8 60, a 350 SBC and a Rover which is also a 215.
  29. grdra1
    grdra1
    Fabbed some headlight trims for my recently purchased swap meet headlight buckets, they will be going on my 34 5 window. Glen image000000.jpg image000003 (1).jpg image000004 (1).jpg image000004.jpg image000003.jpg
  30. 34Phil
    34Phil
    truck exhaust elbows can be trimmed into a teardtop. Thicker material, though. Could be used as hammer form.
