Projects 1934 Ford PU Build
Discussion in 'Traditional Hot Rods' started by Jeff34, Jul 27, 2015.
  1. Jeff34
    Jeff34
    Well, I may have another project soon. My cousin in Montana is interested in buying a boat in my area. He has asked if I would be interested in going to take a look, buying the boat and towing it to MT. What do I get in return? He has offered to give me his A Roadster. I'll start another thread on that, but thought I'd announce it here to create the link between the two...Here's a couple of pictures of the Roadster, and of the boat I'll be "trading" for it.
  2. Craig Owens
    Craig Owens
    Damn! You got the better end of that trade Jeff. Help him transport a boat that ain't yours in exchange for that cool Model A roadster...yeah, that's a win. Of course he is your brother, so there's that. Gotta come and check out that Model A when you get it home.
    kidcampbell71 and nunattax like this.
  3. nunattax
    nunattax
    love that A,hope to get one some day good luck with it.chris
  4. jim galli
    jim galli
    Dream stuff. Both the "A" and the '34. Sweet! Git 'ur done. Quick.
    nunattax likes this.
  5. Jeff34
    Jeff34
    I'll let you know when it's home. I'll have to find a time between my travels to make the trip...BEFORE WINTER SETS IN!
    Well, I DO have to buy the boat. So I get the A for whatever I pay for the boat...(I think I'm still getting the better deal)...
    brEad and Runnin shine like this.
  6. Jeff34
    Jeff34
    Thanks! The PU has been a blast to have.
  7. Craig Owens
    Craig Owens
    Oops, I overlooked that little detail. Still a swingin' deal. That Model A roadster looks great!
  8. Runnin shine
    Runnin shine
    Excited for you but also a little sad that your brother may be leaving hot rodding?
    kidcampbell71 likes this.
  9. Jeff34
    Jeff34
    He’s never really been a hot rod type. I was surprised he bought it. The car has gl*** rear fenders and the rumble was converted into a trunk. Other than that, I think it’s all stock.
  10. Jeff34
    Jeff34
    Hoping I can get some guidance from the almighty HAMB on this one. My truck has been overheating recently. It is also starting a bit hard. It was suggested that I check the points. Today, I pulled the distributor to check the points. They do have some pitting (****py pics on next post). And, the point gap is only .008-.010". That's low compared to VanPelt's, who says it should be .014-.106".
    Bubba rebuilt this distributor about 6-7 years ago if that helps.
    Questions:
    1) Hard to tell from these ****py pics, but should I replace the points? I'm thinking since I've already got the dizzy out, I should. But, that begs the following question
    b) IF I remember correctly, changing the points means setting advance again. Since I don't know where TDC is on this flathead, and it doesn't have a mark, I'm thinking that might be more trouble than it's worth, unless anyone has any input on this one. This brings me to the third question
    3) Should I just use an old school emory board to clean up the points, set the gap and run it to see if that solves my problem?
    Cheers!
  11. Jeff34
    Jeff34
    Pics of points. 762D5EDF-A25B-4813-8800-02282B921E98.jpeg C75625BE-E5A7-44B1-9787-29A1B604415E.jpeg
  12. nunattax
    nunattax
    replace points and condenser
  13. D Newcomb
    D Newcomb
    Just found and bought this 34PU all apart!! Old WA State rod Anyone remember it- has 'Stacks' reuse?? Newc
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    Newc,
    Your posting in an incorrect area
    Make a new post with this question.
  15. Jeff34
    Jeff34
    I got the points set, distributor timing set, and back in the truck. Put everything back together and it fired right up. Runs well at idle and advance looks right at fast idle. I'll take it for a ride this weekend to see if this solved the overheating issue. It seems to start a bit easier as well, but it's hard to tell. Maybe I just want to think it's starting easier...
    Petejoe likes this.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    Jeff,
    Your radiator needs a residual valve attached to your overflow hose. I wouldn’t add a recovery tank. Not needed.
    Preferably a 4 pound pressure release valve.
    But they are hard to find.
    I’ve installed a 2 pound brake residual valve on my 34 truck and it does the same thing.
    That radiator will not pressurize without a valve. Pressuring increases the boiling point but more importantly it slows the loss of coolant when your running full speed. You won’t believe the difference.
  17. Jeff34
    Jeff34
    I've been battling a fuel leak for a while, and yesterday I tried to get it fixed up. I have a fuel filter, fuel pump, and regulator (in that order) inside the frame rail on the driver's side of the truck. When I disconnected the line between the pump and the regulator, gas was draining from the tank through the line. I'd like to replace all the hoses and the filter, but I'd rather not drain the tank. If I blow air back through the line from the engine end and purge the line, will that stop the constant dripping, or will it start to syphon again?
    Thanks.
  18. Petejoe
    Petejoe
    from Zoar, Ohio
    Use hard lines, preferably the copper/nickel alloy type. Easy to work with.
    Install a rubber hose at the tank outlet and clamp it with a pair of vise grips while installing the new line.
    I ran some short rubber line off of the hard line for my pump and regulator for the ease of replacement.
  19. Jeff34
    Jeff34
    I used copper nickel lines. Worked great. I didn't put a rubber hose between the tank and the filter (dang). And, to get to that place, I need to remove the bed.
    Outback likes this.
  20. Outback
    Outback
    from NE Vic, Oz
    Dang!
  21. Duke of Haphazard
    Duke of Haphazard
    from PNW
    Jeff, thanks for keeping your thread going. I, like many others on here am jealous of your exceedingly original truck.
    Outback and brEad like this.
  22. Toms Dogs
    Toms Dogs
    from NJ
  23. Jeff34
    Jeff34
    IMG_4441.jpeg Well, it's been a while since I update this thread. I got my fuel leak fixed. Pulled the bed off the truck and replaced everything and sealed it all up tight. No more leaks. I cleaned off and waxed the back of the cab and the front of the bed while it was off since I'm not going to have it off again (I hope). I'm working on replacing the check strap on the drivers door, and I need to repair the door where it's been tearing the sheet metal because the check strap was not working right. I'll post pictures of all this later.
    Hotrodmyk likes this.
  24. Jeff34
    Jeff34
    I do have a question for everyone: I'm at the point where I need to replace the original windshield. The separation of the layers is getting worse, and starting to block my view. Can anyone point me to a DIY windshield removal thread, video, or how-to?
  25. richard noble
    richard noble
    They are relatively easy Jeff, take the side arms off, open the windshield as far as it will go, then prop it up. You will see a line of screws holding the hinge to the header, pull all the screws out and the windshield will drop down. You might want some help to lower the ***embly out. The two corner screws in the frame itself can be hard to remove, so soak them first.
    lurker mick and Jeff34 like this.
  26. richard noble
    richard noble
    Yes, replace the points. That looks like a 1942 crab distributor your running, the points have to be gapped the same on both sides. There is a way to set the timing if you don’t have a timing fixture, you can use a machinist rule on the back of the distributor against the slot and so many thousands off the top hole. Then you advance the point plate to the point the left points just start to open. I'll see if I can find the diagram for you. I live in Springville so it’s too far to come and show you Jeff.
  27. Jeff34
    Jeff34
    Thanks @richard noble Got the windshield off. End screws were tough but not too hard. Got the header off. Now I’ll remove the gl*** and clean it all up. Then off to the gl*** shop
    richard noble likes this.
  28. Jeff34
    Jeff34
    Here are pictures of my windshield frame after I got the gl*** and seals out. The old tape gl*** channel actually looked pretty good for being 90 years old! New seals should arrive today and I'll take it to the gl*** shop on Monday. IMG_4499.jpg IMG_4500.jpg IMG_4501.jpg IMG_4502.jpg IMG_4503.jpg IMG_4505.jpg
  29. richard noble
    richard noble
    Are you going to install the gl*** and setting tape yourself?
  30. Jeff34
    Jeff34
    @richard noble No, my gl*** shop does a great job at that. They did my '29 windshield last month, and it turned out great!
    missmuriel and richard noble like this.
