Technical Stroking 289 - Budget Build
Discussion in 'The Hokey Ass Message Board' started by MUNCIE, Feb 24, 2024.
Tags:
  1. MUNCIE
    MUNCIE
    from Houston
    Thank you sir, I will check them out
  2. MUNCIE
    MUNCIE
    from Houston
    Yes sir, that is exactly what I did for the rotating assembly. Just trying to determine what route to go with the heads...
  3. Unkl Ian
    Unkl Ian
    This is common.
  4. MUNCIE
    MUNCIE
    from Houston
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Budget36 likes this.
  6. MUNCIE
    MUNCIE
    from Houston
    Yes sir, I just called them. It refers the OD of the spring, roller/hyd flat tap cam/ and max lift. The -1.250 are set up for hyd flat tap cam and max lift .510 vs. the -1.437 are set up for a roller cam and have a max lift of .650.
    Since I have never had a set of aluminum heads can I run the old style finned valve (cal) covers or would they have to be the newer Ford version(s). I really want to keep the block looking like it was built back in the 60's. Have a reworked OEM distributor and a Pertonix that looks like it is a points distributor.
    Thanks,
    Mark
  7. Budget36
    Budget36
    Place your VC on a head, bolts line up? Have proper clearance?
    On my kids engine, due to CB VCs, I had to used narrow body roller rockers. Stamped steel would have been used, but seems I’m a glutton for spending money;)
    MUNCIE likes this.
  8. MUNCIE
    MUNCIE
    from Houston
  9. birdman1
    birdman1
    I put 351c pistons, 302 rods, 302 crank. Cleveland heads ,2v is fine, an aftermarket boss 302 intake and headers for a Cleveland. Use a original grind boss302 cam and you will have a nice, quick street engine
    MUNCIE likes this.
  10. Kerrynzl
    Kerrynzl
    MUNCIE likes this.
  11. MUNCIE
    MUNCIE
    from Houston
    Yes I got it back about 4 months ago and according to them I should be getting the re-worked heads back this week fingers crossed. I'm not gonna run the high rise, sticking with a dual plane for now. Trying to piece everything together. For my cam if I stick with the C4 going to need a 2500 or a tad higher stall and 3.90 or 4.11 gears. I have everything to convert to a 4 speed with the exception of the transmission. I would love to have a toploader in there.
    Question though for those who would know, with any standard trans would a camshaft with .500 and above lift present any street driving issues.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    When you have a clutch , a finicky engine is far easier to control . I think the other cam numbers mean far more to a lack of smoothness than the lift .
    MUNCIE likes this.
