  1. Unclebrad
    Unclebrad
    I just took the top, with the windows, and stuck it on, matching the door seam position. I'm thinking this would be the easiest way to do it in real l ife.
    To get the rear to go farther back, you would need to do a little more work.
    49ratfink, Squablow and themoose like this.
  2. justabeater37
    justabeater37
    Rear quarters need tipped forward like the rendering and let the roof flow all the way to the bumper. It would definitely be a ton of work to pull it off right .
    phat rat likes this.
  3. edcj7
    edcj7
    Could I please, please, please get someone to make my Model A the green colors below with my wheels black? If the greens are so close in color that it won't make a difference could you also use the silver color with black wheels. I have my car at the body shop and have to make up my mind very soon. It would be rally nice to see the colors on my car. Thanks
  4. There are so many greens out there that you should post a sample of what you want. I don't have photoshop but someone that does will need the sample. My AVATAR has a green body with green wheels and they are very different.
    Charlie Stephens
  5. themoose
    themoose
  6. edcj7
    edcj7
    themoose likes this.
  7. Leon Sandcastle
    Leon Sandcastle
    I am beginning an early 60's styled T project. I have a 21 T coupe body, a t bucket frame, a pontiac 317 V8 and 2 vintage Radir 5 spokes. Could someone take the image, chop it (1 windshield), paint it white with 50's/60's style dark green flames with dark green pontiac engine in a t bucket frame. I would like to see the radir on the front with steels on the rear, and switched to get an idea of placement. The white coupe has the style of flames I was thinking. Thanks in advance!
  8. James D
    James D
  9. Unclebrad
    Unclebrad
    Pushing it farther...
  10. swade41
    swade41
    from Buffalo,NY
    Could someone make my bed wood the same color (dark walnut) as the deck
    Thank you
  11. Unclebrad
    Unclebrad
  12. swade41
    swade41
    from Buffalo,NY
    Hmmmm.... I might have to rethink that
    Squablow likes this.
  13. Dick Stevens
    Dick Stevens
    It looks more like red mahogany stain instead of walnut, red tint instead of the dark brown I think you want!
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I think the problem is that the wood and the metal are from different schools. The wood is finished to today's expectations and the metalwork remains to be done. You would probably get a better idea if the guys photoshopped a paint job on the bed sides etc.
    The color you choose for the metal will suggest how the wood should be finished.
  15. Unclebrad
    Unclebrad
    Agreed regarding paint. For instance, I think it looks good in weathered wood next to the existing paint.
    Also, here it is in what I might call black walnut.
    swade41 and Squablow like this.
  16. swade41
    swade41
    from Buffalo,NY
    I like the weathered look, this is a shop truck so not really finishing any paint to any show car status, the underside of the truck and engine bay will be finished though.
    The wood is red oak so I'm not sure if that would mess with stain choices.
    rod1 likes this.
  17. Unclebrad
    Unclebrad
    Mine has oak also. I had to leave the truck outside for one winter and it turned gray like the picture. I'll probably sand it down to get the color back but if I wanted to leave it gray, I would just give it a good coat of varnish or something to keep it from deteriorating further.
    swade41 likes this.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes @Unclebrad,
    The weathered grey look is keeping more in the overall theme of the truck.
    Maybe a coat of grey primer on the metal would bring it all together even more.
  19. Leon Sandcastle
    Leon Sandcastle
    Could I please see this coupe chopped, fenderless, with a V8, and with radirs on the front and steel wheels on the back and then radirs in the rear with steel wheels up front? Also, any 50's/60's era paint.
  20. quakerchevelle
    quakerchevelle
    Hey all, I'd like to see this Pontiac Wagon without front emblem, side trim, and rear trunk trim. Smoothed if possible and same green as the main body. Thanks.
  21. themoose
    themoose
  22. themoose
    themoose
    You would have to extend the front to balance thing off and make it look correct
  23. Leon Sandcastle
    Leon Sandcastle
  24. bobbytnm
    bobbytnm
  25. quakerchevelle
    quakerchevelle
  26. quakerchevelle
    quakerchevelle
    themoose and Leon Sandcastle like this.
  27. Makes it look like a '57 (?) Studebaker wagon from the back!!! EEEEEW!!!!
    chopolds and bobbytnm like this.
  28. RockyMtnWay
    RockyMtnWay
    Buddy over this past weekend drinking a little rum said I should put blackwall tires on my red rims (currently have WW). I got have a very good imagination so I need some help to see it.
    Could you please do your magic making the whitewalls into blackwalls.
    Thanks in advance.
    41sedanetteowner likes this.
  29. Rot 'n Kustom
    Rot 'n Kustom
    @Leon Sandcastle
    If it were mine, this would be my model:
    Joe Cruces' T coupe.
    Leon Sandcastle and lurker mick like this.
  30. themoose
    themoose
