Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone likes this.
  2. choptop4
    choptop4
    20250228_144507.jpg 20250228_144507.jpg 20250228_144507.jpg started making skirts for the Boznetic Coupe '
    Starting with a cardboard template them transferred it to Masonite. Fit was good. Making lower brackets today. When iam happy with that , I'll transfer it to shèetmetal and wheel in a little ark.
    hfh, skooch, anthony myrick and 12 others like this.
  3. You can never go wrong with Tacos!
    hrm2k, Okie Pete, 61Cruiser and 2 others like this.
  4. DDDenny
    True, but a bib sure comes in handy!
    hrm2k, Okie Pete, Sharpone and 2 others like this.
  5. abe lugo
    abe lugo
    Took a break and finished it up. It's got a top now. Just need to do the snaps for the cover.
    pila38, porkshop, rod1 and 13 others like this.
  6. jazz1
    jazz1
    frame car is sitting on no better. Mouse house frame rails
    Something for folks to watch for when purchasing car with boxed frame that’s been sitting for decades image.jpg
  7. lumpy 63
    lumpy 63
    Worked on putting ladder bars on Bob's Lark on the rack but I thought you guys might dig the A sedan. We had Bobby Walden form a roof skin for it and a machinist buddy of ours made dies for the roller to match the reveal on the c pillars to eliminate the drip rails. 20250301_101230.jpg
  8. swade41
    swade41
    from Buffalo,NY
    Cgrgrspt10, pila38, porkshop and 15 others like this.
  9. snoc653
    snoc653
    from Iowa
    I've been taking the 51 apart and bagging parts. As I pull the front end apart, I'm putting the hardware in ziplock bags and labeling them. Some of the hardware is a little flakey. Both headlight buckets had 1 square bit screw. The previous owner had undercoated the car at some point in time, which makes finding all the bolts and screws a royal PITA. I wouldn't mind so much had they fixed the rust before they undercoated. Who does that? If I go tilt front, I've figured out I can move the radiator forward and not have to cut the firewall. Now I'm weighing options on would it be better to move the engine back for balance and if I should build ducts that go out and over the tires to keep the fresh air tubes.
  10. saltflats
    saltflats
    from Missouri
    The more engine setback you can get for a cl*** the better in my opinion.
    pila38, hrm2k, Tickety Boo and 2 others like this.
  11. RMcCulley
    RMcCulley
    Fixed my steering issue... the front pan hard bar was just loose enough to make driving interesting.
    pila38, hrm2k, Okie Pete and 7 others like this.
  12. -Brent-
    -Brent-
    The roof had a piece of sheetmetal screwed to it in it's racecar days. The holes were welded but the metalwork wasn't done.
    Last night I worked the p***enger side into better shape. It still needs some more TLC but it's much better.
    I ordered a bullseye pick to address some of the finer stuff. It will be a good learning experience.
    P***enger side above door, before:
    P***enger side above door, after:
    Back p***enger side, before:
    Back p***enger side, after:
    The whole length:
    Cgrgrspt10, pila38, porkshop and 19 others like this.
  13. HOTRODNORSKIE
    HOTRODNORSKIE
    Painted stripes on my hoods and grill shell for my 35 olds. 20250301_124632.jpg 20250301_124639.jpg 20250301_124648.jpg 20250301_132621.jpg 20250301_132633.jpg 20250301_132657.jpg
  14. Sharpone
    Sharpone
  15. lumpy 63
    lumpy 63
    Got up early today and drove up into the hills above San Diego to look at a 67 El camino . Original black plate CA car been parked since 2005, It was 40 degrees up there and I wore a T shirt:) You guy's in the colder areas are laughing I'm sure. Went back to the shop and finished the ladder bars on the lark and finished the dash harness on the tempest. @4pedals came by the shop for a visit and we had a good time talking Hot Rods. Good day in my book:D
  16. DDDenny
    Oookay, now, about the ElCamino?
    Maybe we should say it's a 65........just to keep things legal here and all.
    porkshop, Tickety Boo, hrm2k and 2 others like this.
  17. lumpy 63
    lumpy 63
    My buddy bought it , factory marina blue , black interior, rally wheels. Rats have been in it, needs interior. Going to pull unknown sbc and glide and install healthy 327 T400 and a repop interior. I will post a pic in the off topic section.
  18. DDDenny
    :cool:
  19. mad mikey
    mad mikey
    Please do, sounds like a solid plan.
  20. cavman
    cavman
    After some unexpected down time, I finished up the side panels, built a rear bumper from an old drive shaft, and covered the rear seat. Also did a bit more wiring. I got enough left over material from the seat for a poncho. sides.jpg seat.jpg
  21. Mike Miller
    Mike Miller
    Finished it, it's done. Now on to the next project. (Yea, I know< they are never done.)
  22. 265 Edelbrock 3 deuce intake. Bought it super cheap decided I’d modify it to fit 57 up ports
    Thought I’d try out spool gun on it
    I was out of tungsten at the house
    it’s messier than a tig. But probably faster.
    I’ll use dye and a file to level it out then sandpaper and straight edge.
    do a slight gasket match on the inside
    seems to have penetrated well.
  23. Paul
    Paul
    Editor
    another tool I didn't know I wanted, now I do
  24. mad mikey
    mad mikey
    I have wanted to try that very thing with my spool gun, maybe I will now. Carry on professor.:)
  25. gimpyshotrods
    gimpyshotrods
    I have the same one.
    It is great for bulk build-up.
  26. We have one at work, my buddy Johnny is the only one who uses it. John also got to work with Gene Winfield a few years ago at a World of Wheels show in Chicago. Gene was helping chop a top on a 51 Mercury. IMG_0431.jpeg
    Okie Pete, Spooky, mad mikey and 7 others like this.
  27. 1971BB427
    1971BB427
    from Oregon
    Went to Marty Strode's shop this morning and he bent up my tubing for the Lakewood 3 point rollbar clone I want to put in my '39 Chev coupe.
    More welding and painting once I cut and weld the other leg and cross brace.
  28. 51504bat
    51504bat
    Gimpy,
    You up and about yet?
    Sharpone and Truckdoctor Andy like this.
  29. Bulk build up is the correct term.
    We started tiging it several years ago and got 1/2 of 1 side done. Got distracted on other things.
    The mig process isn’t as pretty but that’s ok for this project. It’s getting ground all around
