Customs 4 Barrel manifold for 331 Cadillac OHV
Discussion in 'The Hokey Ass Message Board' started by lucas doolin, Jan 12, 2025.
  1. lucas doolin
    lucas doolin
    I have an early Cadillac 331 OHV with a stock 2 barrel carburetor in a 1940 Mercury. To gain more under hood clearance I was thinking a four barrel carb. Increased performance is not the goal. Research tells me the first Cadillac factory single four barrel carb manifold came on the 1956 365 CID V8. Will this manifold interchange with the earlier 331 CID I now have? Did any aftermarket suppliers offer a single four barrel intake manifold for the 331 V8? Thanks for the help.
  2. Andy
    Andy
    I am famous for posting bad info so take this as bs. I took a four barrel wcfb off an early caddy. It must have been 56 or earlier as it did not have the secondary velocity valves. The carb did not work for me. The car and intake are probably still there. It is a business so they might pull the manifold for you if you need one.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    1949-1962 intake manifolds interchange. I have never seen an aftermarket single 4 bll manifold for an early Caddy. Hollander interchange manual shows a 4 bll carb as early as 1952
    mad mikey likes this.
  4. guthriesmith
    guthriesmith
    My 53 331 (also going in a 40 Merc) has a factory 4-barrel on it.
  5. oldsmobum
    oldsmobum
    from SoCal
    I imagine you might have to look out for the early 4 barrel small base vs later large base bolt patterns on these?
  6. warbird1
    warbird1
    Yes...
  7. guthriesmith
    guthriesmith
    Mine is definitely small base.
  8. ss34coupe
    ss34coupe
    1952henry and guthriesmith like this.
  9. guthriesmith
    guthriesmith
    Here is mine without the carburetor on it.
  10. Andy
    Andy
    55 Olds wcfb is a great carb. Small base and has the secondary velocity valves.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    1952-56 Cadillac engines used the carburetor with the small, almost square bolt pattern (3 7/8x3 3/4 ). '57 -'62 used the larger pattern, but could have come with a Rochester 4GC or Carter AFB. Most of them in that vintage ended up with an AFB.
  12. 42merc
    42merc
    Hollywood-East likes this.
  13. guthriesmith
    guthriesmith
    No kidding…I think you are right! I never noticed that… :oops: Hopefully they didn’t glue it on. :D
  14. lucas doolin
    lucas doolin
    Thanks everybody. Looks like the 4 barrel will provide additional under hood clearance.
