Technical ***March 2025 Banger Meet Thread - In Like A Lion, Out Like A Lamb***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 3, 2025.
  1. Jiminy
    Jiminy
    Link to previous month: February 2025 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    Deutscher likes this.
  2. Had a weekend driving the Coupe about with its fresh engine.
    IMG_6543.jpeg IMG_6546.jpeg IMG_6547.jpeg 30d0ce2e-a11d-44a5-850e-3d36d4e10d6a.jpeg IMG_6549.jpeg
  3. wuga
    wuga
    Still pretty icy up here in southern Ontario.
    Warren
  4. hotrodA
    hotrodA
    Banger Magneto Question….
    I’ve been looking at different magnetos for the B engine in my vintage, pile-o-parts sprint car.
    Here’s the latest one I’ve looked at:
    WICO AP, base mount 4 cyl.
    https://www.ebay.com/itm/2568331321...bx14briS1u&var=&widget_ver=artemi***edia=COPY
    Does it rotate CW looking at the drive end? Yes CW
    Does it have an impulse drive? Apparently.
    Will it work on my Alexander OHV with side drive if the drive lines up?
    Thanks!
    jet996 likes this.
  5. Nothing too major to report! With a circus of 4 toddlers between me and my girlfriend, I decided its time to get a heavy hauler!
    Does anyone know if a Belond header will fit with the engine pans without t*******?
    So far I've got a B distributor for it, downdraft intake and carb, 6:1 head, and a belond header.
    [​IMG][​IMG][​IMG]
    Outback, mvee33, Bigcheese327 and 4 others like this.
  6. burl
    burl
    from Minnesota
    Try to find out from somebody that has run a mag and find out what's involved to make work right. My discussions with guys that used these for racing told me they had to run a like a choke cable to be able to advance and retard the spark. Most were used on stationary equipment and didn't need an advance curve. From what I've heard after starting and engine is hot, they can be hard to restart if you don't have a way to adjust. Hopefully somebody with more experience chimes in and has some information to share.
    hotrodA likes this.
  7. I've been thinking about linkage for my side drive, but the choke cable idea is genius! I forgot where exactly he wrote it, but Jim Brierly made a comment regarding side drives recommending the use of an impulse. I'm sure with using the stock GAV mount and a clever bell crank design, you could adjust one
    Outback likes this.
  8. Crazydaddyo
    Crazydaddyo
    I've used this American Bosch mag on one of my side drives. I prefer it because it has a lever that adjusts the timing manually.
    https://www.ebay.com/itm/2671168370...9bTJY9TVDeCsKGKpnOiZVchw==|tkp:Bk9SR4bjybqsZQ
    jet996 and burl like this.
  9. hotrodA
    hotrodA
    Thanks for the first hand advice @Crazydaddyo ! Definitely one to consider,
    EDIT: Considered it for about a minute, and bought it.
    Cheap enough to experiment with. Plus I found another one equally as cheap. Dredged up some pages on the net from an original manual..
    Good info on that model and its setup.
    Thanks again! Looks promising.
    Crazydaddyo likes this.
  10. Star 351
    Star 351
    Hot rod sedans are plenty of fun, I've just got mine running with a hopped up burtz, mines right hand drive so I can't answer your question about the header, but I can tell you I haven't had any overheating problems with the previous hopped up banger and the current burtz since I went to a pressurised radiator, some 16 wires with 7.00 rears and 5.50 front tyres its sits ok on stock suspension but I do have a 34 axle for it and plan to pull a couple of leaves to get it sitting better
    Here a quick video of it running, the burtz is pretty healthy, it's got a lionspeed 7.5:1 head, burtz 340 cam, burns intake, larger holley 94 from a y block and a home made 4 into 1 header that works pretty well, it will pull 55mph in second with a stock transmission, 3.78 gears, I've had it to 80mph so far but chickened out due to stock brakes, but boy is it fun, I've had fun this last month of summer
    Deutscher, jet996, Outback and 4 others like this.
  11. I do love a 7-window Coupe myself...
    jet996 and Outback like this.
  12. Bearing Burner
    Bearing Burner
    from W. MA
    Can anyone help me with information on a '32 Plymouth 4 cylinder engine?
  13. Stovebolt
    Stovebolt
    @Star 351 at 80mph, braking would be fun!!
    great going
    Outback likes this.
  14. burl
    burl
    from Minnesota
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You might want to look at posts made by the late RichFox. There might be something there.
  16. Bearing Burner
    Bearing Burner
    from W. MA
    I talked with Rich before he died. He couldn't remember very many details.
  17. Crazydaddyo
    Crazydaddyo
    Burl
    Yes.
    There is also a lag mechanism on the drive side (impulse drive) that automatically retards the timing at engine starting speed. Once the engine is at idle speed, the lag locks out and reverts to static timing. If I remember correctly, the timing lever on the back changes the timing @ 10 or 12 degrees.
    burl likes this.
  18. hotrodA
    hotrodA
  19. Crazydaddyo
    Crazydaddyo
    American Bosch mags came in different frame sizes. MJA, MJB, and MJC. The MJA is the largest and MJC is the smallest. There is no difference in spark out put. The MLC fits most of the side drives that I've seen,
    hotrodA and Outback like this.
  20. Outback
    Outback
    from NE Vic, Oz
    Have you searched on here? He posted for many years here, might be able to glean some info.
    Do the Montana Dodge Boys play with Plymouth's too?
  21. denis4x4
    denis4x4
    from Colorado
    The '29 Super Cab will be back on the road this weekend after almost 2 years of malingering. Fired it up and set the timing yesterday. After lunching the Model B with an original CRAGAR head, I bought a touring engine from Bert's Model A and traded the CRAGAR to Steve Becker.
    Outback and G Baese like this.
  22. burl
    burl
    from Minnesota
    Nope,
    They use the db fast four that was produced in 1927-1928
    Outback likes this.
  23. Rich’s last build was a DB
    It currently resides in NZ
    J
  24. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Outback, Bigcheese327 and Crazydaddyo like this.
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    T-GO head, Buffalo wheels, and a new Polyform body! Not sure about the intake manifold… but looks like a good start to me!:cool:
    Outback and Crazydaddyo like this.
  26. Steves46
    Steves46
    from Florida
    Is anyone using Charlie Price's Vintage Speed Carb Adapter on their Banger? If so, how does it perform?
  27. wuga
    wuga
    Not that one, But I have a bunch of stuff from Charlie and have never had any issues. But onto another issue. Two Model As, both running stock running gear, mechanical brakes and cast drums. The stock 35 wheels fit the drums no problem, but the Kelsey Hayes with their welded spokes will not fit over the drums. Has anyone else encountered this and can we grind the welds a bit?
    Warren
    Kelsey Hayes wheel with welded spokes
    Spokes making contact
    Stock 35 wheel
    Outback likes this.
  28. Stovebolt
    Stovebolt
    I run kh wires on my coupe.
    32 front brakes, model A rear.
    I've not experienced any issues with fitting over the drums.
  29. alchemy
    alchemy
    Pretty sure the bent spokes aren’t welded in the centers. Those are the heads of the spokes. Do not grind!
  30. Zax
    Zax
    I got to ride in a killer Tudor Sedan with a hopped up banger this weekend on a reliability run to the Don Garlits Museum. It has a Burtz block with a Miller overhead and a T5. It was amazing how well it ran. tempImageU5M1l1.png tempImage4SM02X.png tempImageH2syCQ.png
