My 41 Chevy P/U Build
Discussion in 'Off Topic Hot Rods & Customs' started by swade41, Jan 9, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    Let's work on a latching device to pull this hood down and **** it in to the cowl. The hood was cut off that old tilt front end, when they did the mold for that they had to have went right over the top of a stock front, grill and all !
    Everything is oversized but I work with what I got, it's also a 1/4 inch thick which makes it set up proud.
    I sketched out a few designs thinking I'd do an "L" shaped rod that would be on the side of the hood like an emblem that could twist and hook into a latch somehow but the angles just never worked out right.
    porkshop and Okie Pete like this.
  2. swade41
    swade41
    from Buffalo,NY
    So I ended up using a hood pin on the inside roll of the fender so it's unseen from the side.
    It stuck up kinda tall and would've needed a slot hole in the fender to work with the arc of the tilt.
    So I trimmed the head off of it a bit
    Then I sketched out a design for the plate that the safety pin rides on
    But I was unsure of the orientation I wanted
    porkshop, Okie Pete and loudbang like this.
  3. swade41
    swade41
    from Buffalo,NY
    Next up was getting those fender sections I cut off back in 2016 to mount to the cowl, as with any fibergl*** parts when they lay loose they distort shape.
    At first I was going to form a lip on them for the fender to ride on during the tilt but in the end I just made a nice clearance gap between the two pieces. I also made a couple tabs off the running board to hold the fender in place once it's closed.
    I'm hoping that a few heat cycles will get the hood and the other parts back into a tighter fit to the cowl. I'm also hoping that by adding these pieces back it won't be so damn hot inside the cab.
  4. swade41
    swade41
    from Buffalo,NY
    The front hood was so out of shape to fit the fenders, which were stock dimensions, I had to cut pieces free then cut them up then try and gl*** them into some kind of blended shape. Notice how the hood sits over the top of the grill.
    This is how stock parts fit with grill on the outside
    I gave it a guess to where the grill was supposed to go, since there's no reference points, but kept sliding the hood back to get a better fit on the nose and ended up with this hack looking job.
    Since I didn't want to narrow the nose I decided to buildup the back side of the hood so the grill could connect to that like stock then figure out the outside fit somehow.
    I then carved out a spot for each grill bar to nestle down into
    40FORDPU, porkshop, Okie Pete and 2 others like this.
  5. swade41
    swade41
    from Buffalo,NY
    That rear script panel was also a royal pain in the ***, my idea was to have a flat panel with a raised script. I thought welding it in would warp the panel so I had a shop recess the flat panel and then use panel bound to attach the metal piece with the script.
    It was not clamped flat so in some sections the panel with the script was raised up higher than the flat panel. No matter how I went about it I could not get my vision of a flat panel with raised script, it inadvertently would look wavy.
    In the end I tried taping the script off and tried to build up around it the thickness of the tape to give it the slightest of a recessed box with the script in it.
    porkshop, Leakie and loudbang like this.
  6. swade41
    swade41
    from Buffalo,NY
    Sand, sand and when you think your done sand some more
    20241026_162101.jpg 20241014_163813.jpg 20241014_163824.jpg 20241028_160151.jpg 20241029_171103.jpg
    I used the same paint I used for the fenders back in 2017
    That's some shiny satin
    40FORDPU, porkshop, loudbang and 2 others like this.
  7. swade41
    swade41
    from Buffalo,NY
    Got the grill squeezed back in without damage
    I had to make a spreader for the upper to get it around the to wide hood
    I was really happy with the way that fit into the little pockets I made.
    Can't tell much about the rear but I think it's a good compromise
    loudbang and Okie Pete like this.
  8. swade41
    swade41
    from Buffalo,NY
    I got the headlights back on, starting to look like something now
    I'm liking the new hood windows too
    Fender extensions back on and fit pretty good, I put some door edge guard around it to help protect it from the fenders banging around during the opening/closing
    Hood pin protectors back on and I trimmed the pin so the ring fastens around it so it doesn't fall out on it's own.
    Then I wiped the truck down to get an overall look, I like the changes I gave it, my ideas worked out
  9. swade41
    swade41
    from Buffalo,NY
    Well it's mid November 24 and time to kick it out of the heated section so I can get another one in.
    Then a quick test drive around the block a couple times, everything seems good, brakes work, my string front end alignment is straight, carbs need dialed in, shifter shifts.
    It's good to see it back out after a five year hiatus
    20241116_145600.jpg 20241116_143539.jpg 20241116_143600.jpg 20241116_143551.jpg 20241116_151520.jpg
    And ready for it's winter slumber
    pila38, Okie Pete, Leakie and 4 others like this.
  10. swade41
    swade41
    from Buffalo,NY
    I didn't get everything done on the list, but got a lot done in a years time.
    I still need to paint the door panels, figure out the side windows and decide on a front rim to match the new rear rims.
    I've pretty much narrowed it down to these two American Rebel's, leaning towards the starburst
    Screenshot_20191104-022411_Gallery.jpg Screenshot_20250307_135534_Chrome.jpg
    I do have a pair of 15x3.75 ET slots I could polish up
    Or switch lug pattern to chevy and use some existing Gyros
    Who knows when I'll get to gettin around to that, but it leaves room for future installments.
    To be continued ........
    pila38, Okie Pete, SS327 and 3 others like this.
  11. swade41
    swade41
    from Buffalo,NY
    Thanks to @fastcar1953 I got the American Rebel Starburst wheels for the 41
    Put 165/80/15's on, this is the first wheel change in 30 yrs for Evil41 and I dig it.
    pila38, Okie Pete, 65type1 and 7 others like this.
  12. swade41
    swade41
    from Buffalo,NY
    I gave it a bath and took it to Father's Day lunch with my kids today.
    The longest drive yet and it did well, only got up to 175 and had a bit of blower surge while waiting at a long light. I was thinking about adding a bit of surge to it this time around too.
    20250615_133127.jpg IMG_2212 (1).jpg 20250613_173707.jpg 20250613_173732.jpg
    pila38, Okie Pete, Gasser 57 and 12 others like this.
  13. 40FORDPU
    40FORDPU
  14. swade41
    swade41
    from Buffalo,NY
    4th of July yard display, the parade runs a block away so there's a lot of foot traffic by the house. My neighbors have been displaying their cars the past couple years too, so it's like a mini car show for the folks.
    Got it inspected so I've hit a couple cruise nights with it, it's doing good but I really need to make a cover for the hole in the floor around the master cylinder.
    Lot of people bending over to look in the holes I cut in the hood sides, one guy in traffic mouthed the words WHAT THEEE F♤◇K, then made the gesture of his mind being blown. Lol
  15. swade41
    swade41
    from Buffalo,NY
    I was finally able to park next to a stocker for a side by side comparison check.
    Al***ude difference from roof to the ground is most noticeable
    Headlights moved, fender tops rounded off, hood and fenders molded together, custom made scoop, shaved bumper, running boards widened at rear and straight level body line from nose to bed rails
    Shortened wheelbase, shortened bed, shaved doors, smooth running boards
    This shows the bed sides being raised to better line up with the body lines and bed slid forward to eliminate the gap between cab and bed
    This angle shows the rear window moved down 2 inches and chopped 2 inches. The bed is 4 inches narrower and rear fenders are 2 inches wider, of course custom bumper, tailgate and taillights.
    Every piece has been modified on this old truck with the exception of the cowl. Maybe a couple more changes to come down the road, who knows.
    pila38, porkshop, loudbang and 6 others like this.
  16. pila38
    pila38
    Can I get a ride?
    swade41 likes this.
  17. swade41
    swade41
    from Buffalo,NY
    Anytime and it even has brakes lol
  18. pila38
    pila38
    Hahaha…well yours is a ‘41, it’s got those fancy new fangled safety upgrades!
    swade41 likes this.
