Hot Rods 34 Coupe. Winters rear. T Spring?
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Mar 2, 2025.
  1. panhead_pete
    panhead_pete
    Im sorting through the planning of replacing the C2 corvette rear in my 34 a****st a raft of other ch***is work. Sitting at work and looking at options and going through previous threads etc including info posted by Abone and other - thanks!
    Want to fit new parts etc so they outlast me so will be buying a new rear end and ultimately there isnt a lot of difference in price between a 9 inch from Currie and a Winters Quick Change.
    Has anyone here fitted a Winters QC to their Model 40 coupe and have any words of wisdom? From what I can see so far it looks like a Model A or T rear spring is often used?Model A rear crossmember?
    For the remaining parts of the suspension it looks like ladders bars are often used or even 36 bones? The driveline is a mild 355 and muncie and whilst I get into it every now and then it doesnt get thrashed.
    Thoughts?
  2. grdra1
    grdra1
    Mine has Model A crossmember and spring and my own fabbed up ladder bars. Glen 20241008_162422[1].jpg 20241008_162428[1].jpg 20241010_174630[1].jpg IMG_20241010_195737.jpg
  3. panhead_pete
    panhead_pete
    Thanks and nice work on those ladder bars and the rest of it. Looks great.
  4. grdra1
    grdra1
    Any time, here is some info I received from a chap named Gary on the Hamb, he was so helpful and full of knowledge, also my build thread has lots more pics.
    I always set everything up based on the flat center part of the frame. My model a crossmember was always level with the center of the frame. I set me rearend at 2.5-3 degrees up at the nose. My spring hangers were level with the top of the crossmember and the center of the frame. Your distance between the frame and rearend looks good. Make sure you set your spring hangers so you end up with a 45 degree shackle under a load. I’ve never used a rear panard on a buggy spring rear. I had P&J’s make my Ladder bars and my 33-34 bars were extra long and worked really good.
    2deuces64, catdad49 and panhead_pete like this.
  5. model a crossmember with a winters qc under my '34 tudor 71547458_10220898336638040_4970918324310376448_n.jpg
    rod1, 2deuces64 and juan motime like this.
  6. panhead_pete
    panhead_pete
    Cheers how did you set up the suspension?
  7. Rocky
    Rocky
    Classified Editor
    Model A crossmember and spring with Pete&Jakes ladder bars. 34reassembly2.jpg 34rodders Journal photo.jpg [ATTACH=
  8. alchemy
    alchemy
    For someone half way around the world, I’d say it’s easiest to just order all the parts from Pete & Jake’s. They could probably even weld the ladder bar, shock, and spring perches to the axle before shipping. They could supply every single part you need (unless they don’t have the Winters axle, but you could have it shipped to them).
    panhead_pete and Happydaze like this.
  9. ' 69240106_2459686977407561_1887637860304027648_n.jpg 36 ford radius rods, fabricated torque rods reveresed eye model a Spring
    panhead_pete likes this.
  10. panhead_pete
    panhead_pete
    So have been doing a lot more reading, using google to search the HAMB is much better for results.
    Thanks to all that have posted so far!
    It appears from this thread if the bones arent split I dont need a torque rod or some sort of panhard bar. Thanks @SamIyam for that.
    https://www.jalopyjournal.com/forum...od-suspension-simplified.677460/#post-7528169
    @voodoo Twin added a little more strength to his although Im not sure why the additional upper section is adjustible when the original bones arent? Perhaps for setup?
    If splitting them I can definetly see the need for a panhard bar or similar as @metal man did
    Have I got this right? Thanks
    Happydaze and HemiDeuce like this.
  11. Happydaze
    Happydaze
    I think you've got a grip on it! I imagine the 'adjustable' bits are merely a simple way of making the bars. The clevises are a neat way of meeting the mounting tabs, thus threading the bars becomes necessary. Bonus would be adjustability for any dimensional issues created by welding?
    Chris
  12. flamedabone
    flamedabone
    As for the do you need a torque arm or not, the short answer is yes. The stock arms relied on the closed tube driveshaft ***embly to control rear end torque load. If you have an open driveshaft, you will need some sort of torque arm. In theory, you will also need a panhard bar, but in practice, many cars don't have a rear panhard.
    -Abone.
  13. krylon32
    krylon32
    from Nebraska
    I've done the above with 36 bones and a torque arm several times or P&J's ladder bars. In the last 40+ years I've done countless buggy spring rears with either an A spring or 40 spring and have never used a panard bar. If the rear end is set up right with proper spring perch spacing when loaded the shackles are at a 45 degree angle which eliminates side sway. Yes a panard is needed in the front in a car with cross steer regardless of shackle angle to eliminate side movement created by the cross steering
