Hot Rods Am I Wrong?
Discussion in 'The Hokey Ass Message Board' started by krylon32, Mar 5, 2025.
  1. krylon32
    krylon32
    from Nebraska
    For years customers have come to my shop asking for a suicide front end like the Bones cars. I have done several of the spring the axle fronts. I recently discovered a Walden front cross member in my stash for a pinched front end, offered it for sale as a Walden front cross member for a pinched suicide front end. I was promptly corrected by several telling me I was wrong with my designation of a suicide front. I was simply taking the verbage from what I had read on the Walden pinched ch***is ad and what I had heard many people call the front ends on the Bones cars???????????????????????
  2. 19Eddy30
    19Eddy30
    from VA
    I since 70s ,I always heard , said , told
    Spring behind axle " suicide"
  3. Oneball
    Oneball
    I always thought a suicide front end is where the axle is beyond the ch***is/spring so if something breaks the ch***is hits the ground rather than landing on top of the axle.
  4. oldolds
    oldolds
    What he said! ^^^^^^^^^
    chryslerfan55 and porkshop like this.
  5. sidevalve8ba
    sidevalve8ba
    What are the naysayers calling a suicide frontend?
  6. hotrodjack33
    hotrodjack33
    I agree.
    I've always heard a suicide front end had the spring perch ahead of the front cross member.
    Double suicide is when the suicide front end has the tie-rod in front of the axle.
  7. Malcolm
    Malcolm
    from Nebraska
    I've also always considered the typical T-bucket front end pictured above as the 'suicide' front end.
    The other type I've always called Rolling Bones or Doane Spencer or spring behind axle -
  8. RICH B
    RICH B
    My take. Always been spring over like '28-'34, spring forward like '35-'48, axle forward AKA suicide like T buckets and other hot rods. Style never differentiated between where the spring perch was located.
    chryslerfan55, porkshop and twenty8 like this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    The magazine writer who coined the phrase is long gone , plus there may have been more than one , call it what you like or consult your favorite magazine writer.....
  10. Suicide fronts dates back to the 1920s, kits were available to lower T's by moving axle forward, if something broke, kiss ya **** goodbye! This style was likely most dangerous on circle track cars that used Model T parts and not parallel leaf front. The term "Suicide Front" has evolved to include the style of Doane Spencer/Rolling Bones setup. Really any axle setup that places axle out in front of ch***is where a spring failure would see ch***is drop & dig into ground is a "Suicide Front"
    Kume, akoutlaw, chryslerfan55 and 4 others like this.
  11. deucemac
    deucemac
    Many years ago I was discussing suicide axles with my late father and he asked me if I knew where the term started. Of course I didn't and he explained that the term came from dirt track roadster racing. It seemed that if you were racing and the spring or the spring perch on the cross member broke, the axle and wheels would rotate around on the radius rod mount and come crashing into the ****pit and either beat the snot out of you or kill you outright. I met a few old racers years ago and they backed up my father's story. My dad used to watch roadster racing at Soldiers Field in Chicago right after the war. Apparently it happened more than they would have liked. I wouldn't know first hand because I didn't come along until late 1947 and didn't attend racing until the ripe old age of 5, at Illiana Speedway.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    In extreme situations, aka dirt circle track racing I can see where a spring perch failure could not only send the front of the frame into the dirt but also flip the front axle up and over the ch***is as you describe.
  13. Dave G in Gansevoort
    from Upstate NY
    Take a look at some old pictures of dirt track big cars and in particular look at the front of the car. Most had a spring steel skid, purposely for keeping the frame from digging into the dirt when something broke. Better than nothing but probably not the answer for the street
  14. PotvinV8
    PotvinV8
    :eek: I never even considered THAT!
    chryslerfan55 and TagMan like this.
  15. ratamahata
    ratamahata
    from Argentina
    The Bones front end setup... Lol. They welded two pieces of metal at top of the front rails trought the front axle, some sort of fusile to prevent a damage if the the spring loose or! And served as the radiator support too... I do not now if that mod can prevent something really! ;)
  16. krylon32
    krylon32
    from Nebraska
    I've done several bones style ch***is. I have my own design for doing the perches thru the bones. I do not weld them. With the axle in front of the frame. I blend a 2 inch wide piece of 3/8th flat into the top of the rails over the axle. This piece of flat is drilled and tapped 3/8 co**** for the radiator and also another tapped hole that uses a short hard rubber bullet bumper to control vertical axle travel. The piece of 3/8th flat will also prevent the car from digging into the pavement in case of spring or perch problems. No Failures to date.
    burl, Jimmy B, Xman and 5 others like this.
  17. They probably did not until it happened a couple times.
    Ben
    hotrodjack33 and chryslerfan55 like this.
  18. Royalshifter
    Royalshifter
    Moderator
    If the spring breaks guess what happens.
    Totally suicidal.
  19. PotvinV8
    PotvinV8
    Suicide front ends and cowl steering, discuss! :cool:
  20. krylon32
    krylon32
    from Nebraska
    Don't bring the dam cowl steering up again. After some criticism about my ad.about the proper terminology. All I was asking was if the spring behind the axle mounted into the bones was called a suicide front end. I'm 80 and it's been that way since I first got into cars in the 50's. This all stems from my ad offering a Walden pinched front cross menber for a suicide front end! In the ad for his Jitney ch***is he refers to the front suspension as a suicide front? All I know is with a spring behind the axle car if the spring perch or spring breaks and the car drops to the ground bad **** is going to happen.
  21. 270bob
    270bob
    Your not wrong. Pinched frame cross member can be suicide front end or spring above axle. I have built many both ways too.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    I had a spring pivot break while driving , the hairpin dropped down on the tie rod , by going slowly we were able to limp into a town where we found someone who was willing to help us out , not catastrophic, but it certainly gets your attention .
  23. Koz
    Koz
    So is my frontend a "suicide"? Sort of a hybrid?
    RICH B likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    no, I don't think so. if your spring breaks it will just clunk down on top of the axle and you can still drive to the side of the road or slowly to get it off the road
    GasserTodd likes this.
  25. The37Kid
    The37Kid
    This all started over 100 years ago with a $16.00 bracket the Chevrolet Brothers manufactured for race cars & speedsters.
    Kume, Jimmy B, Lepus and 3 others like this.
  26. PotvinV8
    PotvinV8
    Just stirring the pot Gary, your reputation precedes you!
    I would add that the setup in post #23 would typically be referred to as a suicide-style or suicide perch front end. Essentially any design where there isn't either a crossmember or framerails over the axle could qualify.
    I built this '32 RPU and I always considered it a suicide-design. Not the way I'd do it today, but this was 25 years ago and we all live and learn. lol
    And it doesn't have to be a transverse sprung setup to be considered suicide-style. Here's one of the latest ch***is going together in the shop. This one will get some sort of bump stop arrangement for the axle, so perhaps it suicide-less style?
    Ned Ludd, Lepus, Gremlinguy and 7 others like this.
  27. 38Chevy454
    38Chevy454
    Maybe the simple way to think about it: if the spring or the spring mounting breaks, and your frame (or whatever is hanging below) can drop to the road, it is "suicide front suspension".
    If the spring or the mounting breaks and there is something for the axle to contact which stops the frame from dropping to the road it is not suicide front suspension. It might still be spring ahead of grille design, or crossmember ahead of grille design, but those may have something that prevents the frame from dropping to the ground. Having something that contacts the axle preventing the frame dropping is what makes it not suicide front suspension.
  28. krylon32
    krylon32
    from Nebraska
    Potvin: Wow, *****in tube/torsion ch***is. Always fantasized doing a torsion bar deuce highboy but never got around to it..One of my favorites was the white model A highboy tudor tub on deuce rails with torsion bars. Been around for a long time but keeps on going.
    osage orange, Speccie and ratamahata like this.
  29. Speccie
    Speccie
    Potvin, that is a nice set up.
  30. Dave G in Gansevoort
    from Upstate NY
    And another V8-60 axle! Not as rare as we would like to think…
