Projects 1941 Studebaker Champion Sedan Gasser Resurrection
Discussion in 'Traditional Hot Rods' started by Chucky, Sep 9, 2024.
  1. Chucky
    Chucky
    Commercial carpenters may recognize the CRC, cold rolled channel (red arrow). I really like that material for adding strength. It’s 1.5” wide by .5” tall and made from 16 gauge. It’s normally used to strengthen metal stud walls. The blue arrows point to the duct tape that was used to transfer the required notches.
    catdad49, porkshop, Thor1 and 6 others like this.
  2. Chucky
    Chucky
    There’s a gap between my garage floor and the concrete apron outside. I might have slipped this chunk of steel in there and added some bend to this patch panel. I definitely used self tapping sheet metal screws to hold it in place, even though I own Clecos. IMG_0930.png
    catdad49, -Brent-, porkshop and 5 others like this.
  3. Chucky
    Chucky
    I’m planning to add another chunk of CRC across the top, inline with the factory trunk bulkhead braces. That will stiffen the floor and give me something to attach the future bulkhead to. The lapped spot welded seams will get brush painted with Rustoleum rusty metal primer. Capillary action will draw the primer into the seams. Topped off with seam sealer, it will outlast me for sure. The entire floor will be getting some type of bed liner paint. That’s the plan for now anyways.
  4. TRAVLR
    TRAVLR
    Looking good Chucky.
    porkshop and Chucky like this.
  5. bchctybob
    bchctybob
    I like the duct tape trick.
    Where do get the CRC? I had some that I used to strengthen the floor in my Austin but I got it from a friend when he cleaned out his garage. I had no idea where to get more.
    porkshop likes this.
  6. bchctybob
    bchctybob
    Thanks! The pieces I got from my neighbor weren’t galvanized but that doesn’t matter. It’s probably better to just clean the areas to be welded and the rest will be protected.
    Home D shows it out of stock but I’ll check back. Thanks again.
    catdad49 and porkshop like this.
  7. Chucky
    Chucky
    @bchctybob - I got my CRC from Tamarack Materials, which is a commercial carpenter supplier that sells to the public. I’m sure if you call around, you will find it. I paid $24 for 30 feet (10 footers). I ended up using a bunch in the trunk to make it strong enough for things like the gas tank and the battery.
    catdad49, saltflats, loudbang and 4 others like this.
  8. Chucky
    Chucky
    More tape (blue this time) to transfer patterns. Drill drill drill…and then drill some more.
    catdad49, saltflats, -Brent- and 4 others like this.
  9. Chucky
    Chucky
    I ran out of welding gas, but swapped the bottle yesterday. It’s not welded in this photo, but it will be soon. Bead roller? We don’t need no stinkin’ bead roller!:D It’s gonna look great once painted and some sort of texture applied.
    catdad49, saltflats, -Brent- and 8 others like this.
  10. TRAVLR
    TRAVLR
    I gotta ask... When you said "We don't need no stinkin' bead roller", were you wearing a sombrero and using a Mexican accent? LOL!
  11. Chucky
    Chucky
    @TRAVLR - Si señor!
    Check out this cool old ad…Is the price legit? $700 in 1941 is about $15,000 today. Either they were selling them too cheap, or we are getting screwed when buying cars today. It’s the latter, I’m sure.
  12. TRAVLR
    TRAVLR
    Arriba!:)
    I'll take 4 if the price in the ad still stands! (2) 2 door sedans and (2) coupes please.
  13. No_Respect
    No_Respect
    from So-Cal
    Nice build so far.. if you need hood let me know
    Chucky and porkshop like this.
  14. -Brent-
    -Brent-
    This build is sick!!! I love it.
    Chucky likes this.
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Chuckie;
    Thanks for the tip on CRC.
    Now I gotta see what else the sneaky commercial-building folks utilize that we can cannibalize... :D .
    Marcus...
    catdad49, bchctybob and Chucky like this.
  16. Chucky
    Chucky
    Thanks for the comments and ‘likes’ everyone! The trunk is fully welded and I framed in the front section. I don’t need a hood, but I am missing 2 pieces of trim. Hopefully, French Lake auto parts will fix me up.
    catdad49, bchctybob, porkshop and 6 others like this.
  17. Chucky
    Chucky
    Is anyone else tired of floor repair progress photo’s? Yeah, me too…but I think this one is kinda cool.
    catdad49, bchctybob, porkshop and 9 others like this.
  18. Chucky
    Chucky
    My son and I did some repairs and mods to our 2014 Rubicon, and the whole family spent a week in California, so the Studebaker was put on the back burner. But, I did make some progress today. Unfortunately, now I need to go buy more sheet metal as my remaining chunks aren’t large enough to finish the floor.
    BigRRR, catdad49, bchctybob and 9 others like this.
  19. Chucky
    Chucky
    In an attempt to save time, and because I don’t own a pipe bender, I ordered some Speedway seat mounting frames. I think they have a vintage race car look and they were rather inexpensive. The length was perfect, but they did require narrowing. I took 2.5” out of them.
  20. Chucky
    Chucky
    The “fake” A100 seats are actually forklift seats from Northern Tool and Equipment. They come with the adjustable slide mechanism. Not vintage 60’s, but they look the part and don’t break the bank. On a side note - that’s not the shifter handle I’m using.
    catdad49, TRAVLR, saltflats and 4 others like this.
  21. Chucky
    Chucky
    After tossing on some return springs, I very roughly hung the pedal ***embly off an existing hole. It’s going to need significant tweaking, but it will work great. There’s the perfect amount of space for 3 pedals. In about 6 weeks, I’ll be putting our pontoon in the lake and progress will slow dramatically. Happy Easter!
    catdad49, saltflats, porkshop and 5 others like this.
  22. Chucky
    Chucky
    I pried the old 2 bbl iron manifold off my mock-up engine tonight and tossed it in the trash. Yes, mice had set up camp in there a while ago. The floor replacement, which is still in process, is rewarding, but also a bit of a steep hill to climb. Sometimes, if you can’t see the light at the end of a tunnel, you need to take a step back and remind yourself of why you do this crazy ****. I ran the Chevrolet script valve covers on the ‘37 Plymouth and then the aluminum Corvette covers on “the Grinch”. There was really only one choice remaining. I grabbed these from a fellow HAMBER and couldn’t be happier with how they look. Thanks @lcfman ! We both have been members here since 2009.
  23. bchctybob
    bchctybob
  24. saltflats
    saltflats
    from Missouri
    Looks like good progress. Keep swinging the axe and the tree will fall.
    porkshop, Chucky and 427 sleeper like this.
  25. bchctybob
    bchctybob
    Any updates??
    Chucky, porkshop, Roothawg and 2 others like this.
  26. porkshop
    porkshop
    from Clovis Ca
    was just thinking the same thing....
    Chucky likes this.
  27. Grumpy ole A
    Grumpy ole A
    Hope he wasn’t under the tree.
    I was going to tell him a like the valve covers
    porkshop, 427 sleeper, Chucky and 2 others like this.
  28. bchctybob
    bchctybob
    Yeah, me too. Always liked those 327 valve covers chromed with the sticker.
    porkshop, 427 sleeper and Chucky like this.
  29. Chucky
    Chucky
    I’ll start by saying, there’s a lot of amazing builds on the HAMB right now. Thanks for asking about mine. I never know what to post, when to post, and that sort of thing. I can relate and appreciate some of the more personal stories that other members post. The blend of technical and life experience is what makes this place so great. With that said, let me go a bit OT to explain the delay in progress on the Studebaker…
    porkshop and Thor1 like this.
