Does anyone make an adapter to use the world cl*** 5 speeds that you would find in a 94 and later s-10. I have one of these ******s laying around that I would like to put it behind the flathead in my 50.
do a search, topic has been covered heaps of times. I think cornhusker does a kit for that box. but use the search, it is your friend.
I know that cornhuskers kit is for the 93 and earlier ****** because I thought that I was gonna be lucky enough to use that ****** behind my 35 flathead that I am putting in my 35. I have decided to keep the 50 and I want to be able to jump in it and go because right now I am limited to about how far I can go because I am not a big fan of cruising around at 50mph and getting 10 miles a gallon these days can get expensive.
Check here. http://www.transmissionadapters.com/index.htm or here, http://www.flat-o.com/ or here, http://www.wilcap.com/webdoc8.htm read this.... http://www.streetrodderweb.com/tech/0307sr_contemporary_transmission_swaps/
Run in part by Mark Kirby....Motor City Flatheads. They'll know . I used the Offy adaptor. Works like a champ.
Cornhuskers kit is made for the GM pattern S-10 trans 85-92 and Shadow Rods is for a Ford pattern as I believe the later 93 up S-10 trans have. I could be mistaken.
