Technical 39 Ford Clutch pedal
Discussion in 'Traditional Hot Rods' started by Bob Bagley, Feb 1, 2025.
  1. Bob Bagley
    Bob Bagley
    After looking at pictures of the 39 Ford clutch pedal assembly, isn't it set up to push the stock clutch fork? When using a SBC clutch fork set up that has to be pulled so I'm guessing the 39 Ford pedal assembly has to be dissembled and flipped. Am I correct? Thanks
  2. RonaldR
    RonaldR
    Yes I did it on my 39 when I put a olds in it. Worked that way for years.
  3. F-head
    F-head
    I’ve flipped several of them
    If you use a nova bell housing it’s nearly a straight pull and the brake pedal won’t hit the fork
    LOU WELLS likes this.
  4. Bob Bagley
    Bob Bagley
  5. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    Can you explain flipping? Thanks
  6. hotdamn
    hotdamn
    You can also use an early ford style adaptor and save yourself a lot of head ache.
    for example, let’s say you’ve got a sbc and a t-5 going in your 39
    use a sbc to early ford adaptor mated to an early ford to t-5 adaptor.
    then you can use the stock clutch linkage and everything works harmoniously :)
  7. You remove the pin from the clutch pedal; rotate the actuating arm 180 degrees so it faces down, align the clutch pedal, drill a new hole, and pin the clutch pedal.
  8. Chainsaw chipper
    Chainsaw chipper
    from Illinois
  9. Bob Bagley
    Bob Bagley
    With the Nova bell housing, will the clutch arm clear the stock wish bone on a 40 Ford? Thanks
  10. F-head
    F-head
    That I can’t say
    I’m building 36 with a nova bell housing and a 39 pedal assembly.
    But won’t be there for a year or so
    Sorry
  11. Bob Bagley
    Bob Bagley
    Thanks. good luck with the 36. So, you have no clearance issues with your clutch arm?
  12. F-head
    F-head
    Like I said I don’t know yet
    The other cars I built with a nova bell housing had split wishbones
  13. Bob Bagley
    Bob Bagley
    Thats what I needed to know, Thanks.
