Hot Rods what cars/ trucks had 5 on 5.5 ..15''wheels... I was thinking 50's f=100
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Mar 6, 2025 at 6:13 PM.
  1. ALLDONE
    ALLDONE
    looking for some wheels and wondering where to look???
    LOU WELLS and chryslerfan55 like this.
  2. Roothawg
    Roothawg
    Jeeps, full size Ford trucks 1/2 ton
    ALLDONE likes this.
  3. F1-f100 1948-1979 if you find some 1961-1963 I'd be up for some:)
    ALLDONE and chryslerfan55 like this.
  4. 2devilles
    2devilles
    Actually f-150 up until 1996 have 5x5.5. Jeeps as mentioned, some Chevys and Dodges also.
  5. tjm73
    tjm73
    All Ford cars till '49. All Ford trucks till '96. All 5 lug Econoline vans from at least '78 till they stopped making E150's. Some others as stated.
  6. 51504bat
    51504bat
  7. squirrel
    never heard of a Chevy with 5 lug 5.5" bolt circle. But some of the Dodge 4x4s from the 70s, might have? The old Imperials, mid 50s to early 60s, had 5.5" bolt circle. But they might have had 14" wheels, just to confuse you.
  8. 2devilles
    2devilles
    You are correct, brainfarted and the 5.5 chevy half ton pattern is a 6 lug. I apologize and I'll go to the bathroom and give myself a thorough beating. I promise to enjoy it.
  9. Roothawg
    Roothawg
    2devilles and chryslerfan55 like this.
  10. rusty valley
    rusty valley
    Then you can get into whether the wheel has innie or outie hubcap bumps. Innies, Ford 1/2 tons, 5" wide from early 50's to 66, and special order 16" innies Too. Outies after 66, all 15" for....a long time in varying width
  11. Rusty O'Toole
    Rusty O'Toole
    The heaviest Chrysler products like Imperials, some station wagons and limousines.
    ALLDONE likes this.
  12. The bolt pattern on a 1940 Ford is 5 x 5.5 . HRP
    ALLDONE likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    49-51 mercury used 15” 5 on 5 1/2
    ALLDONE likes this.
  14. 90's Dodge vans had 5x5.5 also
    Also the International Scouts were 5x5.5
  15. Well to redeem yourself the chevy tracker did have 5x5.5
    2devilles and ALLDONE like this.
  16. dwollam
    dwollam
    But, don't try to bolt them on a stock Model A without hydraulic brakes. While they are the same bolt pattern, they will not fit the drums.
    Dave
    ALLDONE likes this.
  17. Damon777
    Damon777
    Dodge trucks and vans. My son has an 89 ramcharger 2x4 with them. the 5-lug 4x4 has them as well. If the center hole was bigger, the steelies from my 2003 Ram bolted up to my 66 Scout (just not up front).
    ALLDONE likes this.
  18. ALLDONE
    ALLDONE
    which ones??? you can get most from about 80 bucks on ebay free shipping....on market place I see people asking 150 plus shipping... I wanna do spyder caps so the center is not that important.... but going on model a drums is....well I should say 1939 /40 ... I've got a new set of 8-20's/5-50's 15's that I wanna put on my Vicky...
  19. ALLDONE
    ALLDONE
    seems like a lot for old rims???? 90 bucks each plus shipping....parts flippers are kinda killing it for traditional builders.... most don't even have a car... but snatch up all the good parts and mark them up sky high...like these rims ... yard sell 20 bucks all 4// market place 100 each...
  20. ramblin dan
    ramblin dan
  21. FrozenMerc
    FrozenMerc
    International Scout's, Travall's and Pickups too.
    ALLDONE and 2devilles like this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    keep in mind that some of the truck and 4x4 applications have a giant center hole.....
    ALLDONE likes this.
  23. X-cpe
    X-cpe
    I believe the 4 1/2" (4x108mm) should actually be 4 1/4".
    ALLDONE likes this.
  24. It depends what style rim you want, inside bump or outside bump. Inside bump (think '40 Ford wheels) are going to be more expensive then outside bump (think 60's F100). Seems like getting cheap rims is getting really hard now, even self pull junkyards are pricey. $50 for a used needing cleaning and paint rim isn't out of question around here.
    ALLDONE likes this.
  25. ALLDONE
    ALLDONE
    close to vegas???
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    no, all ads belong in the classifieds and not on the main board
    ALLDONE likes this.
  27. ALLDONE
    ALLDONE
    thanks
  28. I've got a whole stack of Ford half-ton pickup wheels with 5 on 5.5 bolt pattern. Don't know how I ended up with so many of them. I also have a couple of Mercury 15" wheels, same bolt pattern.
  29. 2devilles
    2devilles
  30. A personal pet peeve of mine is the later ford truck rim has flat cooling holes
    where as the earlier stuff has the nice Cresent moon shaped holes.
    D-Russ and deuceman32 like this.
