Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. RodStRace
    RodStRace
    I don't recognize the make of that, but it looks like the pot metal quick chrome stuff.
    Take the time to coat every thread into it with copper coat or anti-sieze.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahaha if that were the case, I'd be hanging out in the back yard by the pomelo tree. Maybe when the car is finished!
    Good call! That said, I take all kinds of chrome on this car. It'll eventually weather together!
  3. denis4x4
    denis4x4
    from Colorado
    I would be concerned that a chrome fuel pump would be so fast that it would flood the carbs.
    Stogy, Outback, trevorsworth and 5 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    Nope. "If it don't go--Chrome it." So according the traditional hot rod wisdom a chrome fuel pump pumps less. :D
    J.Ukrop, osage orange and shanejgass like this.
  5. richard noble
    richard noble
    I hope the benefit for Yama went well, that was really nice of you to put on that event, Joey…
    J.Ukrop, osage orange and Six Ball like this.
  6. Beanscoot
    Beanscoot
    This looks su****iously like a modern "Push connect" type fitting. Even the threaded part looks typical of straight thread vs. (taper) pipe thread.
    J.Ukrop likes this.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you, Nobey! The event is actually this Sunday. I'll make sure to share some pictures!
    Hmmm good eye. I'll have to replace it!
    41 GMC K-18, Tim and richard noble like this.
  8. Jeff34
    Jeff34
    Hey Joey, GREAT progress man! Lovin how that's looking. If you want them, I've got a couple of old br*** fittings that might work to replace that Q connect on the fuel pump. The smaller one is in good shape, and I think it's the correct thread. The larger barbed one has some damage to the hex area. IMG_4528.jpg IMG_4529.jpg
  9. richard noble
    richard noble
    Just a suggestion, Ford fuel pumps and carburetors have straight cut fittings, the inlet uses a flex line, with a taper that seats at the bottom. The outlet uses a straight thread with a ferrule to seal.
    After market fuel blocks use the tapered thread or pipe fittings. The fitting that Joey has there should be alright. I don’t know where you can find a straight thread fitting with the tapered end today, all the speed shops used to carry this stuff. I’m sure someone on the H.A.M.B. knows where to acquire one.
    Outback and RICH B like this.
  10. richard noble
    richard noble
    There you go, you need that first one with the straight thread Joey, and thanks Jeff….
    Outback, RICH B and Jeff34 like this.
  11. oliver westlund
    oliver westlund
    Thats why I harvest every single br*** fuel fitting I can and stick em in a can!
    Outback and Tim like this.
  12. Beanscoot
    Beanscoot
    And remember to use the "beaded" type fittings, not the "barbed" ones that often tear the hose when disconnected.
    Stock hose fittings are almost always the former, for that reason.
    The best way to deal with those hard-to-find fittings is to get some br*** bar stock and something like this:
  13. RodStRace
    RodStRace
    The guy is trying to build a hot rod, not start up a fully equipped machine shop! :D
    Outback, Six Ball and Speedy Canuck like this.
  14. Beanscoot
    Beanscoot
    Everyone needs a lathe!
    V8-m, Six Ball, Tim and 4 others like this.
  15. I've been feeling the same way. Thanks for the reenforcement!
  16. Fogger
    Fogger
    My Dad gave me his South Bend lathe that I grew up using. Occasionally he'd ask me if I ever used it. " Every time I'm in the shop!!!! ". I would be lost without it.
    enloe, V8-m, Outback and 1 other person like this.
  17. NealinCA
    NealinCA
    I've been using a lathe since I got hooked in high school metal shop. I bought a 9" Southbend right out of college and then bought and sold various lathes to work my way up to a 14x40 gear head lathe. I'd be lost building a car with out a lathe...
  18. Tim
    Tim
    from KCMO
    I’m ***uming that Joey has a friend or two with lathes he can use. I think the only lathe like machine he would have room for in his work space is hand powered and sharpens pencils.
  19. Jeff34
    Jeff34
    It would probably blow the old gl*** fuses in his house, too
  20. Tim
    Tim
    from KCMO
    I had a quick vision of him rolling the lathe out to the driveway on Dollie’s and running power from a light pole to run it lol
  21. Outback
    Outback
    from NE Vic, Oz
    :p:D:p:D:D:p:D:cool:
  22. patman
    patman
    <cough> tap tap tap...this thing on? :)
    Six Ball and Outback like this.
  23. Outback
    Outback
    from NE Vic, Oz
    ^^ This!! ^^ Radio Silence must mean a big unveil is planned hahaha :cool:
    Jeff34, Six Ball and trad27 like this.
  24. trad27
    trad27
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hey everyone, I'm back after some very fun travel. No finished car to show (yet), but I am chipping away at the little things on this ch***is.
    Before I left, I got the first anti-chatter rod in position. It's since been painted. The other side will need to be doglegged to clear the clutch linkage.
    The speedometer turtle received some grease along with fresh gaskets and hardware.
    The wood strips were finished up and secured to the frame, exactly how it was described in Street Rod Quarterly for Bud Bryan's "Project '29."
    And the copy.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Lastly, I very carefully tapped the rear axle bell to secure the rear brake line.
    I used grease, a low speed, and a magnet to make sure no chips made their way into the bell. Note the bolt head—that was the first lesson David taught me at di Falco Fabrications. I'll be installing the rest of the smaller clips later this week.
  27. 41 GMC K-18
    41 GMC K-18
    Most impressive young road warrior, most impressive indeed!
    J.Ukrop and Six Ball like this.
  28. Jeff34
    Jeff34
    Looking great, Joey! Keep at it!
    J.Ukrop, Six Ball and 41 GMC K-18 like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Keep it up. Looking good.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone. Chipping away at the little things!
