Technical FE Ford aluminum water pumps... which to buy?
Discussion in 'The Hokey Ass Message Board' started by Crazy Steve, Mar 4, 2025.
Tags:
  1. Well, I'm looking for reviews/opinions on the various aluminum water pumps for the FE, as well as possible fitment issues. I'll note I'm not unfamiliar with FEs, but I haven't seriously messed with 'em since the mid-70s. There are considerably more choices these days...
    Edelbrock is very proud of theirs at almost $400, but what about the less-costly options? Tuff Stuff, PRW and March are the other choices, all at about $160 give or take for non-polished versions. To further muddle things, if I specify a Galaxie body style, the Edelbrock disappears. To add to the confusion, the remaining ones are listed for '61 through '67 full-size only. For even more confusion, if I specify a '60 full-size (which is what I have), all of the aluminum ones disappear, leaving a couple of special-order cast-iron choices only. WTF???
    FWIW, a couple of the '61-67 pumps note a specific hub height of 7.56" which I ***ume is different from the others. But how different? Am I going to run into fan/radiator interference with the 'wrong' pump? Will I need to relocate the radiator forward? I'd like to use a clutch fan, so this may be an issue. More Ford pulley madness?
    I'm hoping someone with more recent FE experience can clear this up. I've been slowly acquiring the parts for my planned stroker, but with all the recent tariff talk, figure it may behoove me to buy some stuff now before prices take another jump up.
    THANKS!
    ffr1222k, mad mikey and rod1 like this.
  2. And as an additional follow-up, how about fuel pumps? Seems to be three choices: Carter, Holley and Mr. Gasket. They look identical, spec more or less the same and there's only $20 differences in price.
    ffr1222k likes this.
  3. I'll flag Jeff Norwell, I know he's dealt with this.... @Jeff Norwell
    ffr1222k and mad mikey like this.
  4. I recently dealt with Tuff Stuff. I found their tech staff to be helpful. They might be able to answer a question about length.
    mad mikey likes this.
  5. This is interesting. I don't know a lot but over the years of Many F,E's and all in full size the only differences I ran into was the change in threaded boss from Gen to Alt and the latter AC mounts added. None of that as I recall moved the pully hub location. Will be interesting to hear what Jeff says.
  6. Mike VV
    Mike VV
    from SoCal
    Hmm, Edelbrock...$400 ?
    I'd sooner spend a little more money and go with an electric pump if your belt can byp*** the pump and still work with other drives.
    I've been running a 493 inch Chrysler on the street with a very similar pump for a short time. But the previous owner had the pump on the car for about 20 years, and over 4000 miles.
    https://www.meziere.com/Products/Co...tric/Ford/Electric-Pump-Ford-FE-Standard.aspx
    Mike
  7. After some thinking, I think I know why the '60 turns up oddball, I know the '58-59 motors had a different-sized byp*** hose. It was an 11/16" ID, not the later 5/8". The hose was a OEM-only size, you had to buy it from Ford. Too big to get a 5/8 on it, and the 3/4 (the usual backyard fix) was a sloppy fit. The '60 probably still used that size, hence the different pump. Use a later intake, then you can use the later pump.
  8. Oneball
    Oneball
    As mention earlier they changed the alternator/gen mounting boss. The pulley stayed in the same place as I modified a later one to fit my 62 as it was half the price.
  9. Mr48chev
    You have probably already been there but some of the pumps and especially Carter give the hub face to mounting surface measurement on Rock Auto.
    The Ford parts guru that I know retired a number of years ago as he is the same age I am. His bud hits the cl***ifieds here every day but I don't If he checks the board very often although he has said he saw Something I wrote once in a while.
    if you have the original Ford pump I'd be searching the number cast into it.
    https://www.cvfracing.com/ford-390-...nt=&mtm_content=pla&mtm_kwd=2365&gad_source=1
    https://www.summitracing.com/parts/...MIr9rGgsvyiwMVx9rCBB03gAbcEAQYBSABEgKKEPD_BwE
    https://www.jegs.com/i/JEGS/555/510...nz96kkrL2lp11aVF2ksZmWuYdvF0vP9A_KqNRBrta7txo
    https://www.amazon.com/Top-Street-Performance-HC8053-Finish/dp/B00RZT8E5C?gQT=2
  10. partssaloon
    partssaloon
  11. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Edelbrock- $400.00. Wait comes with a one time rectal exam.
  12. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Mmmm......
    I run a Edelbrock WP .. and never paid 400 bucks.... I actually did some horse trading and so far.. it works well.
    The only comparison I can tell you is that is identical to the stock cast Fords I have in my possession....
    And I cannot tell you a year on any of the units.. wait. that's a fib.. one is a 352 unit from a short bed 65 Ford PU.The other 2 are unknown.
    When I was searching for a WP.... I found a very early unit and had it rebuilt (1958 FE)... at the same time I had another cast WP from a 69 390 GT out of a Mercury Cyclone.
    Both were rebuilt and it was cheap..$50 bucks a unit.(The rebuilder has since closed his doors)
    My point of this is.. the Neck flange The later had more reinforcement than the early one. so I ran that on my 428.
    The Edelbrock is on the 410
    I haven't seen or know of any differences in the Ford design.... I am gonna inquire with a few Ford guys....
    As for Fuel pumps...
    I run with Carter.... On both cars.... they serve me well
  13. DDDenny
    This Chevy guy says "if Stewart makes an FE water pump.........buy it.
    bchctybob, sdluck and mad mikey like this.
  14. 2devilles
    2devilles
    I've run Tuff Stuff aluminums and cast irons on all the FEs I've done, and an aluminum version has been on my daily OT F100 for about 100k miles on a pretty stout FE , never had an issue. For mechanical fuel pumps I've used the Carter M4008, but one did give up the ghost right away. Got a replacement under warranty, and it's been trouble free for years.
    mad mikey and Pist-n-Broke like this.
  15. Thanks everyone...
    Well, after making a few calls and searching the net for reviews, most of them inconclusive, I think I'm going with a Tuff Stuff pump. Fully US made including the casting and with the same warranty as the Edelbrock (***uming their tech guy didn't lie to me). None of the aluminum pumps are rebuildable. Almost all of the reviews I saw reported some sort of issue on all pumps, most minor where reviews were even available. Frankly, I can't see how Edelbrock justifies their price. And I'm not particularly a fan of their products in any case.
    I'm going with aluminum simply because it's lighter and will require less man-handling for installing. Those cast-iron pumps are heavy.... Same design guys that did the intake?
    The different hub heights turns out to be a tempest in a teapot. The apparent 'standard' height seems to be 7.578", I saw one with a 7.5" and several at 7.56". So the total variation would be under .030", fairly easily addressed with mounting gasket thickness or a pulley shim if needed.
    Again, thanks to all who replied...
  16. ffr1222k
    ffr1222k
    Thanks for the update to the issue Steve. I think it will help others in the future.
