Hot Rods shock setup for 31 Coupe w/mechanical brakes
Discussion in 'The Hokey Ass Message Board' started by BarryBrothersRacing, Mar 7, 2025 at 11:00 AM.
  1. I have a 31 Ford Model A coupe that is pretty much stock right now. I will be running it without fenders and with a slight drop of 1-2”in the front. I am planning on retaining the mechanical brakes.
    I am looking for a tube shock kit that will work with this setup. Please post any pictures you may have, thanks.
    Kevin
  2. alchemy
    alchemy
    Nobody makes a bolt on for the front lower, that isn’t super ugly (they clamp on the beam). I welded some bent angle on the bottom eyelet of my wishbone. Bolted a regular parts store shock stud to it. Then used the common F-1 upper shock mount arm, with a little bending. I used shocks sized for a 50 Plymouth.
    For the rear you can try to find the bolt on lower brackets that come stock on a 48 Ford. Might require a little heating and bending to align it to the crossmember above. Then maybe a regular shock stud through the back side of the crossmember above.
  3. What about the studs that bolt to the bottom of the perch bolt?
    And does anyone run the shocks in front ot the axle?
  4. alchemy
    alchemy
    Your stock spring perches won’t have enough thread sticking out to bolt those modern lower mounts to. And a new aftermarket perch, while long enough to hold the shock mount, won’t have any brake bracketry on the top.
    Sure, you can mount your rear shocks in front of the axle. But you’ll probably have to fab all the mounts. I thought you were asking for ready made stuff.
  5. yes i am looking for bolt on. What about using the spring shackle mount for the lower and an F1 or other style bolt on upper mount
  6. 05snopro440
    05snopro440
  7. thank you although I may not have mentioned that I’m not running fenders, so appearance is very important
  8. PotvinV8
    PotvinV8
    It can be done. Lower shock mount as mention above and modified F-100 upper shock mounts.
    For bolt-in, look at what Pete & Jake's offer.
  9. alchemy
    alchemy
    I think you missed the part that he wants to use the mechanical brakes.
  10. PotvinV8
    PotvinV8
    Yeah crap. I saw that but forgot about all that monkey motion out over the perch bolt and the fact that they're so short.
    So... drill and tap the axle for a shock stud and the rest works. Not how I would do it, but I wouldn't use that combo of parts to begin with, but alas...
    Why not use friction shocks and attach to the stock ball end on the Model A perch bolt?
  11. chrisp
    chrisp
    Something like this :
    Before
    After
  12. alchemy
    alchemy
    I just assumed the OP was not able to do much fab work since he was asking for a “kit”.
  13. chrisp
    chrisp
    That's what I thought too, but there's no kit for this application, that's why I showed what needs to be done.
    But he can find a good welder to do such a mod.
