Technical 1157style socket
Discussion in 'Traditional Hot Rods' started by dave agosti, Mar 6, 2025.
  1. dave agosti
    dave agosti
    I need a double filament socket for turn signal or stop light. 1157 type, but I need shallow one, or 90Deg type? any ideas?
  2. 302GMC
    302GMC
    from Idaho
    Normal double contact, offset pin.
    LOU WELLS likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    Dorman catalogue
    Metal you can modify with file ,
    Older ones change pig tail around to your needs ,
    Plastic options also,
  4. tb33anda3rd
    tb33anda3rd
  5. HOTRODPRIMER
    HOTRODPRIMER
    As close as your local NAPA. HRP
  6. RICH B
    RICH B
    Algoma56 likes this.
  7. tb33anda3rd
    tb33anda3rd
    yes and the junk yards are full of them
  8. HOTRODPRIMER
    HOTRODPRIMER
    Sadly,the junk yards I grew up with in this area have turned into recycling/crushing yards.
    A guy can no longer roam aimlessly through rows of cars on a Saturday morning looking for parts like I did when I was a teenager. HRP
  9. '29 Gizmo
    '29 Gizmo
    from UK
    Modern, non-led tail lights have plastic sockets and usually quite shallow. Check what's on your daily driver
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Lasted until about 15-20 years ago around here , special dispensation for some of us older guys with common sense ...
  11. dave agosti
    dave agosti
  12. 325w
    325w
    If you have the metal or plastic with correct side pins just change to a two pin card
  13. mammyjammer
    mammyjammer
    from Area 51
    I got these AmericanAutowire sockets from Summit. You don’t have to use the hold down plates, but they turned out to be a life saver for my ******ed up tail lights. I can’t get a good measurement on them installed, but the are not as deep as the original FoMoCo socket…
  14. deathrowdave
    deathrowdave
    from NKy
    Look into someone that has an early Cougar sitting 90 * 1157 socket in the tail lights , 6 of them
    dirt t likes this.
  15. brokenspoke
    brokenspoke
    What bulb did you use?
  16. mammyjammer
    mammyjammer
    from Area 51
    Holley LED 1157. Seem to be pretty bright, but I have not got it out of the garage yet to confirm.
  17. 1971BB427
    1971BB427
    from Oregon
    I just bought some repair 1157 sockets at NAPA for mine. They came with 6" leads attached. Once I snapped them in I bent over a few ot the little clips as I don't plan on replacing them, and wanted them to stay put.
    tb33anda3rd likes this.
