Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    Looks like you've lost a pound or 3 Johnny:cool:
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    205 to 158
  3. choptop4
    choptop4
    20250307_111725.jpg 20250307_112842.jpg 20250307_131737.jpg working on making skirts .Mt brake is 32 in.s
    I need 36in.brake. so I clamped some stock top and bottom. And rolled the edge over with one of my wooden mallet. Came out nice. Then put the pattern on and scribe it.
    Roll the edge tomorrow.
  4. Royalshifter
    Royalshifter
    Moderator
    Worked on fuel lines today.
  5. swade41
    swade41
    from Buffalo,NY
    I spent entirely to long with hand tools trying to recess my wood plank for the wheel tub lip to sit down into.
    Tomorrow I think I'm going to try the hole saw in the drill press mill hack again, because a sander, wood chisel, sand paper on a puddy knife, angle grinder with flap wheel, then with grinding disc, then with a cutoff wheel, a file, just didn't cut it.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Look up router guide bushings.
  7. High test 63
    High test 63
    IMG_20250307_100959.jpg i don't know if you've checked it out or not but when i put studs in the intake and set the rochesters on, the front bolts were too narrow and the throttle bores didn't line up. You may hafta do more adjustments to the carb bases and intake. I don't know if those are factory carb mount holes but they look the same as yours.
    I paid up for the true tri-power carbs i have and i don't really want to grind away on the original secondary bases.
    I have another intake drilled for the rochesters only and am going to use that. Unfortunately i just figured the dual bolt pattern on my first intake was gonna take the rochesters just fine and went ahead and drilled and made a baffle underneath for a pcv and cleaned and painted the whole thing .
  8. I’ll check mine. I’ve just set them on
    If it’s off I guess I could enlarge rhe intake bolt holes and weld em up. Then re-drill
    Probable take the bases off, use the best one for the center and determine if I’ll modify mine or buy new end bases
    these covers fit a lot better. The cal custom ones wobble. The inside needs clearanced. Might use these but polished up
  10. mad mikey
    mad mikey
    Installed SFI new harnesses today , the lap and crotch belts that bolt to the floor cross members. Working on the seat frames and seats next. My buddy Vic came over to help, he owns a bad *** 64 Fairlane thunderbolt type car with a large big block. I had a nice day in my shop, and I really needed that after the week I had at work.
    rod1, alanp561, saltflats and 11 others like this.
  11. snoc653
    snoc653
    from Iowa
    Are your new belts the double crotch strap type? The only performance shop near me was still selling the 5 belt setup but I thought NHRA was going to be requiring the 6 belt systems. What ETs are you running?
  12. lumpy 63
    lumpy 63
    Worked on the trans tunnel on the Tempest and then we pulled Bob's stalled project out of the storage Shed to get a fresh start on it. Then we cooked up some carne asada for lunch 20250308_111733.jpg 20250308_111334.jpg
    Stock Racer, rod1, alanp561 and 23 others like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. swade41
    swade41
    from Buffalo,NY
    Oh yeah, much easier but still tedious
    Stock Racer, rod1, saltflats and 14 others like this.
  15. 427 sleeper
    427 sleeper
    A 40 Willys and grilled beef... My heart bleeds for 'ya. LOL!!!
    Some guys got ALL the luck! :p:p:p
  16. lumpy 63
    lumpy 63
    It was also 70 degrees and the sun was shining:cool:.
    Stock Racer, rod1, saltflats and 9 others like this.
  17. DDDenny
    I don't recall getting that email, no, not the work party, the BBQ party.
    Sure, rub our noses in it!
  18. lake_harley
    lake_harley
    Finally unloaded my FED a few days ago from the final race of the '24 season. Today with the help of the driver we pulled the engine and transmission to replace the 3rd member/rear end housing gasket that has always had a pesky, very small drip. Funny how you have to dis***emble what seems like half of the car to replace a single gasket, but with a coupler, not a driveshaft, that's what has to happen. Got the engine and ****** back in place in the ch***is and pulled the heads to replace pesky oil-seeping head gaskets. Neither oil seeping area was causing any problem with racing, but it just made enough mess on the car to have to constantly be wiping it off every week.
    It's good to be working on the dragster again rather than the less-fun things I have in progress.
    Lynn
    alanp561, saltflats, atch and 12 others like this.
  19. lumpy 63
    lumpy 63
    I would totally host a BBQ for you derelicts:D
    rod1, saltflats, 50chevytx and 13 others like this.
  20. DDDenny
    I got relates in La Mesa, at least I think they are still alive so you won't need to put me up but if you send a train ticket that would be great!:D
  21. Okie Pete
    Okie Pete
    I’ll bring my home grown steak
  22. lumpy 63
    lumpy 63
    20250308_113948.jpg It isn't fancy dining for sure:rolleyes:
    Stock Racer, rod1, alanp561 and 13 others like this.
  23. guthriesmith
    guthriesmith
    Working on dragging out parts for a swap meet in a couple weeks in between helping my son and his buddy work on a Bronco today. Hoping to get rid of some stuff to collect money for my y-block rebuild. I still have probably 3 or four times this amount to get drug out and loaded up.
  24. DDDenny
    Is that Chimichurri or Guacamole?
    Sharpone likes this.
  25. BJR
    BJR
    Welcome to the food network. :D
  26. choptop4
    choptop4
    20250308_090238.jpg 20250308_111339.jpg 20250308_135532.jpg 20250308_115146.jpg 20250308_141342.jpg the skirts are coming along. I rough cut and trimmed. Then rolled the edge in. Both sides fit good , but still need a little more work to fit just right. And figure out fasteners. Cheers.
    Stock Racer, skooch, Oneball and 15 others like this.
  27. High test 63
    High test 63
    Dibs on the couch!
  28. lumpy 63
    lumpy 63
    20250309_100846.jpg 20250309_100819.jpg 20250309_100858.jpg Went and picked up the el camino today, this was also on the property 20250309_100830.jpg
  29. Frenchie  1
    Frenchie 1
    from Colorado
  30. gene-koning
    gene-koning
    One of the garage door cables broke, so today was garage door fix it day.
    The door is only 2 years old, I was up to my neck in an off site project, so hired out the new garage door installation. I thought that sounded like a pretty short cable life.
    When I was ready to install the cables (I watched 3 different U tube how to videos so I'm nearly an expert...) things didn't look right. I discovered the guy that installed the door had the cable drums swapped to the wrong side! He had the cable coming over top of the drum, and the top roller forced it back where it belonged. fortunately, the cable was weaker then the rollers. I believe I'm pretty lucky we got a couple years out of the cables!
    Anyway, the door functions again, correctly this time.
    The next project is a couple days with the 49. Pretty much just a bit of extended summer ready maintenance. We have p***ed the 25,000 mile mark on the truck that was plated in 5/22. Solving a few minor leaks, chasing down a few rattles and squeaks, a set of plugs, trans filter change, oil change. You know, the boring stuff that keeps them rolling down the road. I don't have a hoist, so I tend to let the minor stuff that should be done under the truck slide, until nicer weather, and do a bunch of it at one time.
    In my younger days, I would have called that being lazy. These days I call it being smarter. Lazy may be more accurate...
