Projects 53 Chevy Bel Air "Cleetus" mild custom daily driver
Discussion in 'Traditional Customs' started by The Chevy Pope, Sep 15, 2023.
  1. So while I was straightening the other lowering block I realized the perch plates were slightly rubbing the tires. Not much but I didn't like it. So I grabbed these as a temporary bandaid to keep from blowing a tire in my yard till I swap rear ends lol. IMG_20250303_211009_HDR.jpg
    Okie Pete likes this.
  2. I still gotta double check that I have the right one. But ***uming yes another piece of the puzzle lol. Conversion u joint to allow me to run my current drive shaft with the 58 Impala rear end. I'm eventually going to buy a 100% new drive shaft built to order but I didn't feel like coming up with $400 for one right now lol IMG_20250306_194757.jpg
    61Cruiser, Okie Pete and Tim like this.
  3. Odd way to sell valve stem dice lol. Got them in and wondered why there were only two. Went to the site and despite the pics showing sets of four they're sold in pairs. Lol. Oh well guess I'll order another pair lol Screenshot_20250307-165344.png Screenshot_20250307-165352.png
    61Cruiser and Okie Pete like this.
  5. And the u joint ended up being the wrong one. So I returned it and picked up stuff to start welding and peaking my hood. Ended up getting 5/16" rod because I want a pretty prominent peak since this hood isn't louvered IMG_20250308_152924_HDR.jpg
  6. Lone Star Mopar
    Lone Star Mopar
    Looks good man !
    The Chevy Pope likes this.
  7. Was glad to finally be able to rinse it off lol
  8. Fixed the hokey throttle cable and got rid of the funky stainless steel braid wrap off cable at same time
  9. So was measuring for an eventual driveshaft for my eventual rear end swap and found this. Just barely kissing the floorboard under hard throttle. Had already thought about going from 3" to 2" lowering blocks. Going up an inch in the rear along with hammering the tunnel a bit(it's under the seat) should solve the issue. Had been trying to find someone that sold a 56" long driveshaft with 2.5" tubing with 1310 ends but at that length I'm only finding 3" tube. 2.5" would have gained a bit more clearance IMG_20250312_191536 (1).jpg
    LCGarage, 61Cruiser and Okie Pete like this.
  10. MS Coonass
    MS Coonass
  11. So I'm thinking about making my own 1.75" lowering blocks. Use 1/8"-1/4" 1.75" square steel tube. Drill center pin all the way through to insert appropriate size rod through to be axle locating pin on top. Weld both ends. Drill the spring side hole before welding in end caps. Possibly some tabs on the sides to help keep straight on the spring. Then save the 3" blocks for the 54
  12. So my wife surprised me with carpet for this thing......sort of lol. She did actually get me carpet. And I don't think she meant for me to know till the day it came in. But apparently stock interiors has a thing on s***ched carpet like on a 53 Chevy where it can take up to 15 business days just to get it shipped due to made to order status of the business. And she was a bit flustered and didn't know when it was going to ship as they also said around 3 days on molded carpet and she had no clue what my car uses. She did show me what she ordered and I verified she ordered right. Also noticed she put down a "shop" name that I had joked about in the past. Guess I might actually need to start calling my side "business" that lol. Anyway cleetus is finally getting carpet lol
  13. So update. I guess the company cl***ifies 53 Chevy carpet as molded as it's already shipped. Supposed to have it Monday. So less than a week for made to order carpet isn't bad
    Lone Star Mopar and Tim like this.
  14. Finally finished this mess up. Definitely has a face for radio(no pun intended....ok maybe a little pun intended lol). But I think it'll work. I'll have to run more speaker wire as I only ran for one speaker in the dash. Going to try to do it tomorrow as carpet is supposed to be in Monday lol IMG_20250315_184141_HDR.jpg IMG_20250315_184150_HDR.jpg
  15. Tim
    Tim
    from KCMO
    I think I saw that guy in a Pixar movie
  16. Luckily it'll be hidden behind a speaker grill lol
    Tim likes this.
  17. And got a wild hair and reupholstered this piece tonight. Still gotta clean it, dig up the chrome trim for it, and poke holes for the mounting screws and seat adjustment lever. And get around to doing the other side lol IMG_20250316_205216_HDR.jpg
  18. And front carpet mostly in place. Going to let it sit a couple days with strategic weight before final t******* and cutting a hole for the dimmer switch. And finally got to throw in my temporary shift boot(waiting till the carpet relaxes to screw down) and the fresh shift knob Karen I've been hoarding till I got carpet. Starting to feel like a complete car lol. Still gotta source decent sill plates and not sure when I'll get to the rear carpet IMG_20250317_202301.jpg IMG_20250317_202327.jpg
    LCGarage and Okie Pete like this.
  19. And in case anyone wonders why I don't just reuse the original sills lol IMG_20250317_203841.jpg
  20. Tim
    Tim
    from KCMO
    Sounds silly but carpet does make it feel more like a car. Good upgrade :)
  21. P***enger side may never fit exactly right. P***enger floor board is literally just a dodge caravan door skin hammered into shape lol
    Tim, Okie Pete and TrailerTrashToo like this.
  22. Tim
    Tim
    from KCMO
    You’d be surprise what a summer of sunshine will do to carpet kits!
  23. Well I discovered why people take the whole seat at least loose when doing carpet tonight. Went to bolt the front of the seat down and stripped a bolt trying to get it to grab. Luckily I have a really nice tap and die set I bought of the snap on guy a few years ago so I'll just tap them to 3/8"-16 and be done with it. Also if I can manage to clean the back of the car out I may try to get the rear carpet section in in the next couple days
  24. Busy night without a lot of progress that would be noticable to the average viewer. Started cleaning out the back seat for carpet and found the missing shiny piece to my seat garnish(is that what it's called? Lol) and stuck it in place for now. While the back still looks a mess I literally filled a trash can with stuff that'd ac***ulated over the last two years lol. I'll finish cleaning it tomorrow and get the rear seat bottom out in anticipation of rear carpet. Also after getting the redone seat garnish (?) in place I decided just a Mexican blanket isn't going to cut it. Thinking I'll snag a cheap seat cover and stretch and hog ring it in place under said garnish so it fits more like actual upholstery. Then put the Mexican blanket back on lol. Will look better than shredded foam and shredded rotten cloth hanging out the edges of the Mexican blanket IMG_20250320_193842.jpg IMG_20250320_194042.jpg IMG_20250320_195100.jpg
  25. @Tim see the brown vinyl on the rear seat I was telling you about that I bought thinking it was black? Lol
    Tim and Okie Pete like this.
  26. Tim
    Tim
    from KCMO
    lol that’s hillarious
  27. And got the rear carpet in and the seat bolted back down. was about like six monkeys trying to hump the same muddy football in the rain at the same time lol. Fitment wasn't perfect but honestly far better than I expected. And I did actually end up with one usable rear sills plate. I figure I'll clean it up and fog it silver and see if I have a p***able p***enger side to do the same to and call it good enough for the rear. Found some high polish front sills actually for a 53/54 sedan delivery Im going to try to pick up for the front. When out and about the rear doors will rarely be opened. Now I just need to find a factory style rubber trunk mat. I had a small piece of the original and liked the look but only had like 20% of it on top of the fact it was like a rock lol IMG_20250321_194602.jpg IMG_20250321_194632.jpg
