Technical How to hold the engine up ?
Discussion in 'The Hokey Ass Message Board' started by SDS, Mar 10, 2025 at 1:36 PM.
  1. SDS
    SDS
    I'm preparing to pull the th350 transmission out of my 32 Ford roadster, from below. I'm trying to come up with a way to suspend the 327 Chevrolet V8 while, there's no transmission to robustly support the rear of it. My distributor is very close to the firewall, so I can't afford for it to move much at all without pulling the distributor.
    Anyone have any clever ideas?
    Thanks ~
  2. Pontmerc
    Pontmerc
    from Finland
    Rachet strap and block of wood.
    Paulz, toolz, lostone and 3 others like this.
  3. Oneball
    Oneball
    4”x2” strapped to the chassis with some blocks as spacers.
    61Cruiser, firstinsteele and Sharpone like this.
  4. squirrel
    floor jack under the 2x4. Or a jack stand, and some other type of shims as you can cobble.
  5. MCjim
    MCjim
    from soCal
    Pull the diztributor, and lower it down as much as you can, block it up; will make it easyier to get the tranymission out...just watch for the fluid running out of the tail.
  6. Happydaze
    Happydaze
    I'd be thinking with a sbc in a 32 the distributor will be coming out one way or another, either to gain clearance or to replace it after it gets damaged.
    Chris
  7. Mr48chev
    I've got to agree that it is wise to remove the distributor before you have to remove the pieces of the distributor.
    Pontmerc's suggestion of ratchet strap and block of wood is word for word what I was going to say.
    Or if there is a hole on each rail of the frame in the right spot a couple of bolts the right length and a piece of metal or a 2x4 the right length with matching holes will work. Or a chain between the bolts with a block of wood under the pan.
    I'm not found of the idea of using a floor jack because they can drop or bleed down, they get in the way when you are working and they can be knocked out from under the pan when they get in the way.
    gimpyshotrods likes this.
  8. Bikelessbill
    Bikelessbill
    Jackstands under oil pan rail at block on each side.
    Chucky likes this.
  9. squirrel
    yeah, you need one you can trust.
    Usually just getting the distributor cap loose will prevent damage to the distributor, but it can still mess up the paint on the firewall. If you remove the whole thing, then you'll have to get it back in properly, and meantime you'll be dealing with filling the transmission, etc.
    have fun!
  10. If on a lift, support the oil pan with a lift stand
    On the floor I’d use a jack stand with a rag to protect the pan. You can use plywood under the jack stand to dial in the height so it doesn’t drop any
    Ive supported a bunch of em with a jack. But for long term holding I’d use a jack stand
    Just Gary and theHIGHLANDER like this.
  11. theHIGHLANDER
    theHIGHLANDER
    Bump the engine til you're at your timing point and mark it on the distributor and engine. Masking tape if it's all showey and you don't want a sharpie mark. Pull it. Sleep well through the process. Why mark it at all? Gotta turn the motor to unbolt the convertor so why add timing it from scratch to the process? I'm lazy like that. I can't see your get up so simple logic, blocking and safety should apply, but the ability to lower or raise it as you pull bellhousing bolts might be handy, and of course when you reassemble. Again, I'm lazy like that.
  12. fastcar1953
    fastcar1953
    Use a cherry picker. Then you can raise or lower as needed. I would just pull cap and rotor. That should be enough clearance.
    Algoma56 likes this.
  13. Dave 39
    Dave 39
    I've known a lot of long time car guys that are askeered of pulling the distributor but if you don't disturb the motor it's no big deal. I also like a screw or sissors jack to suport the back of the motor. No bleed down of hydralic jack. A plastic plug from the auto parts store so trans fliud dosent dump out the tailshaft and you're good to go.
  14. RodStRace
    RodStRace
    With an auto, there isn't as much aligning and jiggling to get things apart and together, but it's still possible.
    As said, I'd pull the converter bolts (rotating the engine), bring it up to TDC, mark and remove the dist. then drop the engine/trans down enough to clear the bellhousing bolts. Support the engine with your choice, if the car doesn't have to move, the solid object to floor, or if it must be mobile, straps or frame mounted rig. The reinstall will be easier if there is enough room for a straight shot and the engine is solid. Depending on clearance, you may want to stuff rags behind the engine so it is cushioned at the firewall. A slight dent is preferable to both being scratched.
    At this point, the driveshaft, shifter and cooler lines can be removed, then the bellhousing bolts and trans. The output plug is a great tool, but many of us have done the big spill and roll in it. A bag, glove or other rigged catch usually doesn't work. A drain pan can limit the spill, but is usually a big pain and doesn't prevent some on the floor.
    If using a regular jack, you can lower the trans, but if the car isn't way up in the air, it often gets to the point where the trans has to be slid into the floor and dragged out. A sheet of cardboard or plywood or even a blanket helps here.
  15. 1946caddy
    1946caddy
    from washington
  16. FrozenMerc
    FrozenMerc
    Swap the motor with one that has the distributor on the correct end....
    Just Gary, Bentrodder and 1946caddy like this.
