Technical Paint dilemma & suspension parts
Discussion in 'The Hokey Ass Message Board' started by lostone, Mar 10, 2025.
  1. lostone
    lostone
    from kansas
    Got my frame on my 31' power coated finally and now working on suspension.
    Want to paint the suspension (4-bar straight axle and triangulated 9" ford rear). I want to go with spray bomb as I do drive some dirt roads and plan to drive the wheels off of it once it done so I want to be able to have easy touch-up.
    Now the dilemma, I have limited access to a sandblast cabinet but it's very limited and time in it is very limited. So it's one of those things where 1 day I could do the batwings but maybe 2 weeks before I can do spindles, then maybe a week or so to do axle etc.
    So what I'd like to do is find something like a good etch primer to paint the parts after sand blasting then applying spray bomb on top of that to protect the clean parts.
    I can't see mixing up epoxy primer, dirty a spray gun just to spray a couple small pieces each time.
    So is there a good spray can primer that would hold good to the bare metal so I could spray paint top coat it?
    Ready to get this suspension done and together!
  2. Bandit Billy
    Bandit Billy
    You can buy 2k primer and paint in spray cans at most paint stores or Eastwood on line. The kind with he bladder inside that had the hardener in it. I've used it, works fine. Not cheap.
    Tow Truck Tom, Just Gary and lostone like this.
  3. B1gDaddy
    B1gDaddy
    from aladambama
    Definitely prep parts correctly and epoxy prime. Use metal prep too. Go shop at tractor supply
    Paint w urethane , yes we all know, blah blah it’s expensive. Spray parts in small batches, no problem . It will stick and hold up like crazy. The purple guns are on sale at harbor freight. Go get a dozen . You will never regret doing it correctly .
    spray paint cans are for lawn mowers and charcoal grills
    ct1932ford, 40FORDPU and lostone like this.
  4. B1gDaddy
    B1gDaddy
    from aladambama
    And Billy’s reply above is probably the most economical. You can get two part paint on a spray can color of your choice on eBay. It’s a lot better than anyone one would expect
    Bandit Billy and lostone like this.
  5. vtx1800
    vtx1800
    I used Rust Oleum, on both the Studebaker and the Roadster that I've done, I sandblasted the frame and suspension pieces and shot them with their primer and then satin black. On both cars I had to modify "things" during construction, and it was no problem to "touch up". FullSizeRender(24).jpg
    tractorguy, X-cpe and lostone like this.
  6. 31Apickup
    31Apickup
    Rustoleum Hammertone, comes in variety of colors & no primer required. It’s my go to for ch***is parts.
    vtx1800 and lostone like this.
  7. Kerrynzl
    Kerrynzl
    Zinc plating ! dirt cheap and durable [you can paint over it]
    Clydesdale and lostone like this.
  8. Model A Gomez
    Model A Gomez
    I've used Rustoleum on a lot of small parts with good results. I just did the ch***is and suspension on the banger powered Model A I'm building now but it's an old style car.
    tractorguy and lostone like this.
  9. lostone
    lostone
    from kansas
    Appreciate the suggestions fellas, I want to go with a gun metal style gray, metallic would be a plus.
  10. RodStRace
    RodStRace
    Basic is spray bomb rustoleum or brush on direct to metal.
    Next up would be spray bomb primer and top coat
    Next would be many light coats of primer, sand, then top coat.
    Next would be good 2K primer, followed with spray bomb top coat.
    Tow Truck Tom likes this.
  11. pirate
    pirate
    from Alabama
    You could also spray suspension parts with Ospho which will etch the surface and form an iron phosphate coating which will resist flash rusting and also become a a good surface for painting in the future. I use Ospho in a pump spray bottle I save from other cleaning products or you can buy new ones at Lowe’s. https://www.ospho.com/directions.htm Ospho is a good product but there are also other metal preps out there.
  12. pirate
    pirate
    from Alabama
    I’ve used Rustoleum Hammertone on steel outdoor furniture with very minimal prep and it lasted a long time.
  13. swade41
    swade41
    from Buffalo,NY
  14. RICH B
    RICH B
    If you are only painting a couple parts at a time you might look at using Preval sprayers. I've mixed up small quan***ies of lacquer, catalyzed enamel, 2K primer, and epoxy to paint a part or two. Don't forget to strain the paint and some will need a little extra reducer. Anyway, the little sprayers work good for me.
    https://preval.com/diy-pro-products/preval-sprayer/
    RodStRace and Chucky like this.
  15. panhead_pete
    panhead_pete
    As an alternative you could use one of the Eastwood products like the Rust Encapsuator and use a brush. Ive done that with great success previously on a Model A. Edit - not sure if they do that in any other color than black.
  16. swade41
    swade41
    from Buffalo,NY
    Eastwood has it in silver
    panhead_pete likes this.
