Projects Little Runaway
Discussion in 'Traditional Hot Rods' started by 270bob, Feb 11, 2025.
  1. 270bob
    270bob
    They are not clearanced for disc brakes, I know what you mean about that though. These are 16x5 front 16x5.5 rears.
  2. 270bob
    270bob
    Lets talk old Ford wheels, 15" wheels to be specific. 16" Ford wheels are another breed and some of this information will crossover, but I will focus on the 15" Ford steel rim found on 46-48 Ford p***enger cars and pickups. The p***enger car has a 5" wide rim, this makes a great front wheel. The pickup has a 5.5" wide rim and makes a great rear wheel.
    **"Fun Fact"** When trying to identify the wheels quickly, the truck wheels have a raised rib around the lug nut seat and is the same on 16" Ford wheels.
    When it comes to reversing wheels I prefer using the Ford hoop because I think it looks best. There is nice taper on the back side of the rim leading to the drop center. On the 5.5" wide rim this feature is even more pronounced and that is where the extra half inch is added to the rim width. This feature is not in the Ford 16" wheel. There are many no called "chrome reverse" out there, but not many like this. Once your eye gets trained to see the real stuff you will see the difference right away. For example, the Bill Woodard Roadster restored by the Seiver's has real chrome reverse wheels. If I plan on chroming the wheel I fit the wheel center to the hoop and label it for position prior to chroming and ***emble them after chroming. The chrome plating looks the best doing it this way.
    In the photos attached I do not have the reversed wheels on the front, but I plan on doing so. I have to run the Mercury hubcap in order to clear the front 39 Lincoln hubs. This set will probably get painted with trim rings and hubcaps. I will run 8.20-15 rear and 5.50-15 fronts. I am not sure about the white walls, but this rim package will be for road trips only because of easy maintenance. 20220225_145902-1.jpg 20220224_135304.jpg 20220224_135327.jpg 20220224_135437.jpg 20220224_134915.jpg 20220224_135608.jpg 20220224_135139.jpg 20220415_155059.jpg 20220430_185440.jpg 20220507_083104.jpg 20221223_154735.jpg 20221229_182227.jpg 20230225_190313.jpg 20230225_173055.jpg 20230225_173044.jpg 20230225_181549.jpg
  3. alchemy
    alchemy
    Hmm, learn something new every day. I didn’t know that Ford made 15” wheels in 46-48. I always thought those style steel wheels in 15” were originally on 49-56 pickups. Maybe later as well.
  4. 270bob
    270bob
    LOL You could be right, I may have misspoke. I obtained my wheels off a 48 Ford pickup and somebody could have swapped them out. So I wouldn't hold this information as gospel because all these parts interchange. I am mainly pointing out that there are truck wheels and p***enger car wheels. Thanks
    chryslerfan55 and Okie Pete like this.
  5. 270bob
    270bob
    20250304_171503.jpg 20250304_171454.jpg 20250304_140459.jpg 20250302_150847.jpg 20250302_135612.jpg 20250302_135627.jpg I am still working on the springs for Lil Runaway. I would hate to see the time ticket on this if I were a paying customer. Both front and rear are custom length and arch. My last step is hammering out the ends of the leaves to draw the metal out thin and then polish them all aka Hollywood spring.
    My favorite hammer got dinged up, total bummer, but I can fix it later. I shared a few pics of how I keep the hammer warm and the anvil warm. I keep those hammer heads hot and place them on the anvil while I heat the spring in the forge. I also place the hammer face on the stove to keep it warm in between sessions. 20250304_171503.jpg 20250304_171454.jpg 20250304_140459.jpg 20250302_150847.jpg 20250302_135612.jpg 20250302_135627.jpg
  6. V8-m
    V8-m
    from Alaska
    Now i understand why you say that you need to polish them all the time haha
    Good work on the leaf springs.
  7. 270bob
    270bob
    Here are some photos that do***ent the body work. I dis***embled the complete turtle deck. Polished the T rails and shaped to fit the quarters. Had to cut and put a piece of metal to the right quarter so it matched the left side. The turtle deck has been apart and put back together many times in order to get it to fit like I want. The same goes for the body fitment to the modified Deuce frame. The turtle deck is easily removable with basic hardware and fits pretty good. I cut the rockers out because they got welded into the body and I prefer it took look like a steel body so I fit new rockers in that resemble factory installation. I had to weld on the edges of of the deck lid and panel above deck lid to get decent gaps. 20220119_173156.jpg 20220118_184941.jpg 20211019_125109.jpg 20211018_190522.jpg 20211018_175139.jpg 20211018_152927-1.jpg 20210930_140703-1.jpg 20210929_160232.jpg 20210707_145421.jpg 20210707_150429.jpg 20210728_143604.jpg 20210728_145958.jpg 20210728_150145.jpg
  8. AmishMike
    AmishMike
    Just for the hell of it - I was bothered when read about your deck then realized “ hope you did not steal that steel deck”. Crazy English language & old age screws with the mind or mine……..
    Outback likes this.
  9. 270bob
    270bob
    Lol.....thanks. I was typing pre coffee.
    winduptoy, Outback and AmishMike like this.
  10. 57JoeFoMoPar
    57JoeFoMoPar
    Bro, your Dad knew exactly where that car was and was probably hot on it's trail for well over a decade. He was just waiting on your blessing to go and get it.
    Congrats on getting it back. It looks like you're doing a great job with the refresh and turning it into what you wanted it to be back then.
  11. 270bob
    270bob
    Thank you!
    As far as my Dad knowing where the car was, "He ***ured me, he didn't know." I have no reason not to believe him and I am pretty good at reading B.S. too. When we went to pick the car up and our initial walk up to the car we were both skeptical it was the car. As I inspected the car and saw things I fabricated and identified the yellow paint inside on the sub rails I nodded my head and said, "This is the car." I try not to get caught up in worldly items, but this one had me. I was speechless, and thought to myself "This car is OK." I was always hard on myself as a young man learning how to build HOT RODS thinking this one was never good enough and if I had a 32 Ford everything would be better. That is part of my motivation to make it better now. It is sure taking longer than expected, but we are enjoying the project. Thanks again.
    winduptoy, Outback, Okie Pete and 9 others like this.
  12. 57JoeFoMoPar
    57JoeFoMoPar
    That's awesome man. I think there are some cars that come along where they're just stepping stones on to bigger and better things. Nobody pops out of the womb with the know-how to compete for the AMBR or Ridler, there have to be cars along the way where you cut your teeth on them to learn and hone your skills. A lot of that experimentation ends up in some pretty marginal work, which is inevitable, but leads you to a better place. I've had plenty of test mules over the years. Still do! Good on you for getting this one back and doing it up right.
  13. 270bob
    270bob
    Thanks!
  14. 270bob
    270bob
    Front spring and shackles are done and ready for paint. I decided to make my own shackle and make it greasable. The right side gets a dead perch. 20250312_173219.jpg 20250312_173225.jpg 20250312_173228.jpg 20250313_162528.jpg 20250313_162542.jpg
  15. TomT
    TomT
    Man what a cool and very interesting build - a lot of fresh ideas here that’s for sure. My hat’s off to you!
    winduptoy, Outback, mad mikey and 2 others like this.
  16. 270bob
    270bob
    Thank you!
    TomT likes this.
  17. 270bob
    270bob
    Just waiting on some warmer weather to paint this car. 20240217_164805.jpg 20240115_184533.jpg 20240115_182243.jpg 20240115_181524.jpg 20240101_181620.jpg 20231228_174713.jpg 20231228_172345.jpg
    winduptoy, Outback, Tim and 13 others like this.
  18. Super Streak
    Super Streak
    from Florida
    That is an awesome build, your skills are great and it shows! I can't wait to see the finished product. Best of luck with it.
    Outback and 270bob like this.
  19. Roothawg
    Roothawg
    Neat build. I like it.
    winduptoy, Outback and 270bob like this.
  20. Tim
    Tim
    from KCMO
    Don’t think I’ve seen anyone make a “double main” leaf set up like that. I ***ume it’s to get some stiffness back in a leaf pack that is thin to get the car low?
    it’s only on one side it appears, is it related to the dead perch?
  21. 270bob
    270bob
    I copied a spring out of an early opened wheeled dirt car that had a real "Hollywood Spring" in it. After building this spring, I can say that it actually has more action than a regular style spring. There are many unknowns on this build and that is why I will not send anything out for chrome until I drive this car a little. Like I have said before, "This car is not the status quo." I have spent about 40 hours, to make the front and rear spring on Lil Runaway, that includes re-arching the springs, hammering out the ends, polishing and curling the spring eyes. This was all because I narrowed the track on this car and I was committed to using old Ford parts. Thanks for looking!
    winduptoy, mad mikey, hfh and 3 others like this.
  22. catdad49
    catdad49
    Lots of thought and skill in this Lil car. Dad must thrilled about his truck and where this build is going. Tell us a little about your forge, that looks interesting, too. Keep enjoying and sharing, Carp.
    mad mikey and 270bob like this.
  23. Grumpy ole A
    Grumpy ole A
    This is a very interesting build, good looking body. I bet your dad is very happy with what he sees.
    270bob likes this.
  24. swade41
    swade41
    from Buffalo,NY
    Some great work going on here
  25. 270bob
    270bob
    As I stumble through the body work I wanted to share some details. I always like using original parts. Here you see the restored hinges and door latches. When I decided to put a top on the car, I removed the original Model T post that protruded out of the side of the body and installed my own take how the top should fasten. Little Runaway will get painted with acrylic laquer. The paint was purchased from a friend Don Coleman 30 years ago. @ct1932ford FB_IMG_1742552238586.jpg FB_IMG_1742552265480.jpg FB_IMG_1742552205002.jpg FB_IMG_1742551996899.jpg 1692467896691.jpg
  26. 270bob
    270bob
    I wanted a top on this roadster. So I copied a Bob Lee top, used some cheap masking tape to mock it up. 20230118_181516.jpg 20230330_180725.jpg 20230103_181746.jpg 20230225_190503.jpg 20230226_182650-1.jpg 20230304_163056.jpg 20230226_184743.jpg
    winduptoy, clem, catdad49 and 19 others like this.
  27. akoutlaw
    akoutlaw
    That will look good! You must have $100.00 in masking tape there!
    catdad49, Algoma56, 270bob and 3 others like this.
  28. 270bob
    270bob
    LOL, it only took one roll of 2" wide masking tape.
  29. 270bob
    270bob
    The dash is done and the gauges are ready to go.
  30. AHotRod
    AHotRod
    Now that's a Hot Rod, well done.
