Technical Model A spare tire carrier question?
Discussion in 'The Hokey Ass Message Board' started by 1942g506, Mar 9, 2025.
  1. 1942g506
    1942g506
    I think I made a mistake tonight I was pushing my model A sedan around on Dollie’s. I stupidly pushed on the spare tire on the back, after looking I noticed the carrier is not bolted to the frame but the body itself. It looks like there is a dent around my spare tire carrier. Did I do this or is there a factory indent in the body? Thanks
  2. 1942g506
    1942g506
    Looks like it may have been done already judging by the light rust where paint has flaked.
  3. Squablow
    Squablow
    I'm pretty sure there never was a factory indent but I think it's pretty common damage. Definitely not a good spot to push against.
    1942g506 likes this.
  4. CSPIDY
    CSPIDY
    ^^^^^^ what he said x2
  5. CSPIDY
    CSPIDY
    That can be repaired very easily with the back seat removed
  6. woodiewagon46
    woodiewagon46
    from New York
    Something does not look right with your spare tire carrier. The bottom two bolts should bolt to the rear body sub rail, not under it as you picture.
  7. dln1949
    dln1949
    I’m with Woodie wagon, some one modified that ***embly before you got it
