Projects Another 283 with no oil to the rockers plz help!
Discussion in 'Traditional Hot Rods' started by fatty mcguire, Mar 10, 2025.
  1. fatty mcguire
    fatty mcguire
    59085B4E-11E2-44AF-9589-63550B276ACE.jpeg Got my car running and noticed no oil to the rockers except 1 maybe 2, it’s a 57 283 with newer heads and solid lifters. After trying a few things I took the intake off, had oil in the valley, and ended up taking a lifter out in #1 looks like it’s getting plenty of oil as well. I heard about the cams in 57 may need a notch, if the wrong cams in it would I be getting oil to the #1 lifter. Or another problem. Cars a 30 roadster old build never had the engine apart car started with 60lbs oil pressure with about 40? With the primer on a drill. Did notice with the intake off looks like oil is seeping past the lifter From the bore but not sure if that’s normal or not
    turboroadster likes this.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You're sure it's a '57 engine? If it's a '56 block, the incorrect distributor oiling problem comes into play.
  3. silent rick
    silent rick
    i know i'm no help but my inner adrian monk has to point out the your carb scoops aren't straight, they need to be the same..
    anyway, a bump for you
  4. 26Troadster
    26Troadster
    not sure if true or not, but was told early 60's 283 had a hole in the distributor to oil the lifters too. if not i'm sure someone will set me straight.
  5. RICH B
    RICH B
    Maybe start by IDing what you are working with. Is the code still stamped on the right front pad, is the casting number on the left rear, does the block have provisions for side mounts? Any of these should help determine where to start or help eliminate stuff.
  6. Kerrynzl
    Kerrynzl
    Only 55-56 265's had pulse oiling to the lifter bores. In 57 chevy converted to constant flow for all engines.
    You can use a late distributor in an early engine [splash lube]
    but if you use an early distributor in a later engine it will pump oil into the dist cap
    If your engine has no side mounts it needs casting number 3731548 to be a 57 283/265 [otherwise it is an early 265]
    If you have a 55-56 block with a later camshaft you will have no oil to the R/H lifter gallery
    All Chevys with side mounts have constant oil flow to the lifter galleries .
    Also if you didn't get oil to the lifter bores while priming ,there could be your problem.
    You need a proper priming tool or an old distributor cut down to seal the R/H lifter gallery
    And if you are using an early [55-56] pressure feed distributor, it must be clocked correctly or you won't have oil pressure in the R/H lifter gallery [late distributors can rotate 360°]
  7. Oneball
    Oneball
    If you haven’t rotated the engine at any point only the pushrods where the lifter oil hole is lined up with the gallery will be getting oil when you are using a priming tool
    mad mikey and Kerrynzl like this.
  8. 05snopro440
    05snopro440
    How long was it running for?
    I had the heads off of my 455 Buick for several months. Got it back together, and had no oil to the lifters, maybe a squirt here and there on either side. Since it oils through the pushrods, it took a while to fill them back up. After confirming it had oil pressure and was getting oil, we ran the engine with the valve covers off while oiling the lifters with an oil can. After about 10 minutes, I got oil at the lifters. It took WAY longer than me and the 2 automotive mechanics that were helping me thought it would.
    Oneball likes this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Deuces, Deutscher, -Brent- and 2 others like this.
  10. Kerrynzl
    Kerrynzl
  11. Mr48chev
    As the others said, Post the block casting number and the suffix number (or the whole number) stamped on the pad in front of the right side head so it can be clarified as to what block you have.
    Have you looked through the push rods to make sure that they are clear and clean inside? A few years back some folks stuck a couple of pipe cleaners in the Chevy push rods to slow down oil getting to the top end and keep it down on the bearings and after sitting for a while that may cause too much restriction of that was done, not an issue if you can see straight through them.
    Again on any mix and match engine you start checking to see if the mixed parts actually match and function together. If you had the distributor out and it is a Delco it should have a number on it that tells you what engine it was originally built for.
    This is the screenshot out of the GM Heritage center archives 57 Chev vehicle info kit showing the 57 engine suffix codes. The second one is the codes for 57 truck engines.
  12. fatty mcguire
    fatty mcguire
  13. fatty mcguire
    fatty mcguire
    So got home, no side mounts, I’m running a Mallory distributor full circle, when I ran it was like 5 minutes I just posted the engine numbers and biggest update I swapped a solid lifter with a hydrolic and that one’s getting oil now so I’m ***ume bad lifters or wrong ones
  14. BJR
    BJR
    Why does your oil look milky? Water in it?
  15. Kerrynzl
    Kerrynzl
    Your engine could either be a 57 265 or a 57 283 [Chevy used the same casting number on both.]
    But the good news is it has full flow oiling to the lifter galleries.
    pull the distributor and make sure you have a 57 or newer dist.
    If you have a 55-56 dist it could be clocked wrong
    On early distributors the groove at the bottom [red] is not 360° and could partially block the R/H gallery if clocked wrong.
    This photo explains the clocking issue
    Deuces, Deutscher, 61Cruiser and 2 others like this.
  16. jaracer
    jaracer
    Pull a couple and compare them side to side with the hydraulic. Something has to be different.
    Kerrynzl likes this.
  17. 26Troadster
    26Troadster
    thank you sir.
  18. hotrodA
    hotrodA
    Last year I had the same issue with six rockers in a used 283 I thought that I was going to put in my 40.
    Pulled the pushrods, made sure the p***ages were clean, same with the rocker arms. Still nothing.
    Engine guru in our club said “Yep, just back off those dry rockers a turn or more and you’ll get oil.”
    I did and whatta ya know! Started with a slow weep and grew to a gusher like the others.
    Tightened them back down until they quieted down and they stayed wet as normal.
    Magic!
    X-cpe likes this.
  19. fatty mcguire
    fatty mcguire
    FFCD69C2-2AF2-4550-AF07-5B8F6360744E.jpeg The one on the right is the one I took out
    [/ATTACH]
  20. deucemac
    deucemac
    I don't if this info will help at all, but many years ago I owned a 61 Impala hardtop and rebuilt the 283 in it. Not long after the rebuild, I had valve clatter very loudly. I started looking for what was wrong and found the wire bale distributor hold down had slipped partly off the distributor flange and allowed the distributor to move up just enough to block off one side and no oil was flowing to the lifters it took me awhile to see the problem and replaced the wire bale hold down with a solid steel unit and never had another problem. They was over 50 years ago and I always replaced those wire bale hold downs whenever I saw one.
  21. Kerrynzl
    Kerrynzl
    You have the correct distributor [it can be clocked 360°]
    Those are edge orifice flat tappet lifters, Change them and your problems will go away.
    Chevy went to constant flow/ pressure ,but metered the flow at the top when the pushrod lined up with the hole in the rocker. [which is why we use restrictors with roller rockers]
    RMR&C likes this.
