Technical Oil pressure dropped to zero on start up...
Discussion in 'Traditional Hot Rods' started by 32blownhemi, Feb 13, 2025.
  1. big duece
    big duece
    from kansas
    Who's filter was in there, FRAM?
    32blownhemi and Adriatic Machine like this.
  2. Andy
    Andy
    Most (all?) filters have a byp*** feature to allow flow if the filtering is blocked. I can’t understand how all flow was blocked. Was it a canister filter? What does the oil in the pan look like?
    32blownhemi likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    I posted /mention this issue in post #4
    426 Hemi
    I have Heard of quite a few times after oil filter removed / changed .
    No Oil pressure.
    Older Diesel would do the same on fuel filters, lose prime .
    32blownhemi and Eric David Bru like this.
  4. Ebbsspeed
    Ebbsspeed
    This is pretty much impossible on an early hemi unless you've converted from the stock canister type filter.
    The early hemi has an oil filter byp*** built into the block. Some folks block this safety feature with a plug (see image). If you do this, BE SURE that you use an aftermarket filter adapter and a filter with a byp*** in it. The original canister style DOES NOT have a byp***, so if you intend to retain the original canister filter DO NOT block the original byp*** system in the block.
