History FLATHEAD Rear Center section === LARGER than normal
Discussion in 'Traditional Hot Rods' started by The37Kid, Mar 13, 2025.
  1. The37Kid
    The37Kid
    Flathead V8 stuff is new to me, is this a truck item or late production car? Back tomorrow with a gear count, pinion is much larger than most.
  2. That is most likely a Lincoln center section.
    Carter likes this.
  3. The37Kid
    The37Kid
    Thank you! I'll see if the Ford trumpets match.
  4. Dave G in Gansevoort
    from Upstate NY
    Is it my eyes, a trick of the angle of the photo or is that ring and pinion off center, i.e. hypoid?
  5. alchemy
    alchemy
    Yes Lincoln. Extra bolt holes for sure, I never even attempted to see if the Ford housings bolted up.
  6. The37Kid
    The37Kid
    I'll post photos later today. Bob :)
  7. The37Kid
    The37Kid
    Bolt holes all line up, you would have to drill and tap the one that isn't. Can you tell what year that trumpet is?
    Bob
  8. alchemy
    alchemy
    I think it’s a 46-47, but can’t guarantee from that angle.
    The37Kid likes this.
  9. banjorear
    banjorear
    Length determines the years from '39-'48. What is the overall length of the bell?
  10. What is the width of the housing?
