Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. lumpy 63
    lumpy 63
    Muncie metal spinning:cool:
  2. lumpy 63
    lumpy 63
    It's whats on my Pontiac engine
  3. lumpy 63
    lumpy 63
    BTW Lloyd , I expect a sideways tire melting , rubber all over the 1/4 panels burnout from the likes of a guy who goes by Big Daddy:D
  4. scofflaw
    scofflaw
    from Ohio
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Jeg’s, Summit and Speedway has them.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. DDDenny
  8. Big Andy brought me some gauge cups. I'm gonna make a filler panel to cover the radio hole and the holes that were cut for gauges in the dash. The rear end is 62.5 inches wide, pushed the tires out a little more. I like it. 20250315_101215.jpg 20250315_101659.jpg
  9. It looks perfect! I wished Papaw looked like your wagon in the rear wheel department, but I’ve got pizza cutter 6.50-16’s!
  10. OK hear me out. I have a gas tank from a 72 corvette, been sitting in the back of the shop. 20 gallon tank, that was given to me. Thought I'd try it in the wagon before I left the shop this evening. I was happy that it fits, just gotta fab up some mounts. But I took the filler neck out, and the sending unit. After inspection, it has 6 or 7 pinhole's in the bottom. Question is, solder them up and pour some red kote in it? Gas tank repair epoxy and some Sealer inside? I'm sure it'll blow bigger holes in it if i try to weld them up. It's not horrible, but that one area has issues. Thoughts? You rich ****ers don't need to tell me to buy a new tank either. :p 20250328_161646.jpg
  11. Ignore the rust, not to that point yet
  12. primed34
    primed34
    Look around for some kind of farm or tractor tank.
  13. ROADSTER1927
    ROADSTER1927
    There is a body puddy might be all metal (I can look tomorrow)that gas does not effect. It works great on gas tanks. Do not put sealer in your tank, Gary
  14. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Buy a new tank you cheap ****!
  15. If i had money I would! The big daddy is broke!
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    The pinholes are rust. Rust never sleeps, better get a new tank. How did you make out on the shifter????
    Sharpone, porkshop, SS327 and 4 others like this.
  17. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
  18. I use all metal, but i was thinking about the JB Weld tank weld. Seems to me that my best option is to solder. This car sat for years, didn't have gas in it, but that lowest portion of the tank ac***ulated some moisture apparently. Just trying to salvage this tank, it fits great. And the 20 gallons is a plus also.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
  20. I climbed under the car, looked at it, wiggled some stuff, got dizzy, and haven't touched it since lol... this whole month has been a complete loss due to the flu and it's lingering remnants. Honestly believe i had pneumonia. Just send that eelco you have, I'll send you a compe***ion plus back :cool:
    mad mikey, Sharpone, porkshop and 4 others like this.
  21. I took the girlfriend on a weekend bourbon trail vacation, stupid expensive! I'll not do that again! Depleted Big Daddy's bank account lmao! 20250322_134010.jpg 20250322_115355.jpg 20250322_114617.jpg 20250322_113824.jpg 20250322_153507.jpg
  22. Very neat pictures, is that a barrel house? Great pictures of Missy too!
  23. Yeah that's one of the rack houses at heaven hill distillery, and hot rod parts ;)
  24. chevy57dude
    chevy57dude
    Cut out the section and weld in a larger plate. This way you'll get all the rust. Or at least you will be able to see if it's only rusted in one spot or if it's hopeless. Cool gauge cups!
  25. mohr hp
    mohr hp
    from Georgia
    Buy a new tank! I went down this road on a '64 Dodge. That car stranded me repeatedly with clogged up fuel filters as more **** kept comin' loose from the areas I thought were clean.
  26. 37 caddy
    37 caddy
    from PEI Canada
    I would have the tank sandblasted to get all the rust and then solder the holes up,done a lot like this over the years and never had a problem .I have sandblasted them with gas dripping out,never had a problem with that either.They use a hot iron to melt the solder so no flame handy the old gas.
  27. Crusty Chevy
    Crusty Chevy
  28. patsurf
    patsurf
    this or new(to you) tank--none of the other ideas 'hold water' pun intended
  29. 57 Fargo
    57 Fargo
    Ahhh the things we do for love!
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    man the new tanks are 1 hundred bucks....
    Sharpone, porkshop, 51504bat and 4 others like this.
