Projects 1934 Ford PU Build
Discussion in 'Traditional Hot Rods' started by Jeff34, Jul 27, 2015.
  1. Jeff34
    Jeff34
    I got my windshield back with new gl***, and got the seals for the sides and the top. Seals for the sides and bottom are installed, but I'm having a hell of a time getting the windshield back attached to the header. I punched the holes in the seal that goes across the top, but I just can't get the screws to go back in.
    Any tips or tricks on how to get this beast back in?
    TIA.
    Tim likes this.
  2. Tim
    Tim
    from KCMO
    I havnt done exactly that but it sounds like it’s likely one of those “old ford dance” situations.
    I feel like I can pull a part off, lol at it, and try to bolt it right back on and it won’t go on unless I put the bolts back in in a specific order. My thought would be to get a few drifts/ awls to get the holes close through all the layers and clamp it in place or close. And then get a screw/bolt threw on each end, and then the middle never getting them any more than started. Similar to s***ch welding something.
    then once they are all in dance around tightening them a little bit at a time so it’s drawing tight evenly. If you can get it clamped or ratchet strapped in place so the screws aren’t having to “lift” the windshield into place that would be best but that’s not always realistic.
    pepper in some colorful language and walking away a few times and it should get you there no trouble lol
    brEad and Jeff34 like this.
  3. Tim
    Tim
    from KCMO
    I would also try you tube. Aaron, a member here did his entire model A build as video updates and it’s a gold mine of information. Might flip through and see if he covers his windshield instal. Old fords don’t really change terribly much over a few years.
    https://youtube.com/@aarondominguez4533?si=VvFa21HdvSuLjUR6
  4. Jeff34
    Jeff34
    @Tim Yeah, I need to scrub through his videos again. I followed his build very closely. Don't remember him removing the windshield though. I'll have to look. Thanks for the tips!
    Tim likes this.
  5. steve hackel
    steve hackel
    It's only an ***embly suggestion for you to try . If you just pierced the rubber with a pointed object, then yes you'll probably have issues with the screws and their alignments. Take your seal and place it in its proper location on the windshields frame - hold it in place with lots of clothes pins and mark the holes with a Marker. Now comes the easy/hard part - the perfect tool is a sharp paper punch, and you punch holes "through" the seal, rather than.just piercing it with a pointed object.
    Tim likes this.
  6. Jeff34
    Jeff34
    Got the windshield back in with the help of a friend. What a bear! But it's done. I also got the drivers door back on the car with a new check strap and fixed the damaged hinge area (sort of). Should be good for a while.
    brEad, LAROKE, Outback and 3 others like this.
  7. Tim
    Tim
    from KCMO
    Congrats! Any tips for someone going down that same trail?
  8. Jeff34
    Jeff34
    The new header seal makes it hard to line up the holes. It’s thicker and holds the frame forward. We used an awl in the adjacent hole to pull the hinge back to get the adjacent screw in. We tried all kinds of other ways that didn’t work. I punched holes in the upper header seal for the screws. I think that worked well.
    Reminds me that I should take more pictures. Not necessarily for me, but for others who need to do the same thing
    brEad and Tim like this.
