1936 International C1 6v to 12v
Discussion in 'Off Topic Hot Rods & Customs' started by Zigs, Mar 16, 2025.
  1. Zigs
    Zigs
    Switching my c1 from 6v to 12v. I know I'm going to get the WHY from the purist, not my first go around with this. This is my first conversion , pretty straight forward. Everythings changed to 12v. . Now the problem lies when I try to start it , it kicks once then I have to wait and it will only kick once , in otherworldly it won't spin.
    I put battery to starter and it kicks as should.
    6v starter , 12 v Battery neg ground , original starter key switch and original floor stomp starter. Should I be using a starter solenoid ?
    There is an obvious power drop between switches and direct battery to starter.
    I'm open to thoughts , suggestion.
  2. squirrel
    When you put the battery to the starter, are you just byp***ing the starter ****on?
    If that's the case, it seems that you've found there the problem most likely is. The switch or it's wiring.
  3. Zigs
    Zigs
    For switch wiring I'm using no less then 14 guage. By switch do you mean key switch , key switch shows 12v transfer in and out. Its a two post switch. Foot start shows the same but may not stay open. I'm using 10 guage from key to floor and 4 g from floor to starter. Starter is a 1 post starter no solenoid.
  4. squirrel
    I don't understand. Can you draw a schematic?
  5. Zigs
    Zigs
  6. Zigs
    Zigs
    Very basic. Really not much to it
  7. squirrel
    That won't work! you need a big (#4) cable from the battery to the stomp switch.
    Current to the starter should NOT go through the key switch!
  8. Zigs
    Zigs
    Schematic? What is the key switch for?
  9. Zigs
    Zigs
    Is the key switch just for dash , headlights etc?
  10. Zigs
    Zigs
    I had nothing to go buy on this as alot ofcthe wiring was destroyed
  11. squirrel
    Normally the foot starter switch like that, connects the battery to the starter. This is using big fat wires, because the starter draws hundreds of amps current.
    The key switch turns on power to the ignition coil, so the engine can run. I might also power the gauges and heater, etc.
  12. Zigs
    Zigs
    OK. That makes sence. Thank you for the help.
  13. squirrel
    you're welcome, let us know if it works
  14. Zigs
    Zigs
    Got it
