Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. 19Eddy30
    19Eddy30
    from VA
    @Just Gary,
    Congrats,
    First drives are always nerve-racking!!
    Finding all the characteristics of a new build or combo:eek:
    Stay up Late pass your bedtime
    Take a ride for shakedown with no traffic or go up to the Convention center parking lot
    Make laps around the parking lot :D
  2. 19Eddy30
    19Eddy30
    from VA
    @Just Gary
    I was talking to Jacky afew days ago
    He asked about You & car ,I told him what I seen online was close to being a driver so I will pass the link to him.
  3. Robdski
    Robdski
    Congratulations!
    Beautiful hotrod, sounds great, looks great.
    The rake is awesome!
    chevy57dude, mad mikey and Just Gary like this.
  4. Congratulations Gary, sounds great. Time to button up and enjoy driving. Hey, sooner or later you just have to say F^ck it and drive them, see what happens. That is one fine Hot Rod in every sense of the word. WHOOOO HOOOO!:)
  5. Tim
    Tim
    from KCMO
    Fuck yeah dude! If I saw that thing go buy I would 100% turn around and chase ya down. Wowza!
    also if your videos are more than 30 seconds long and you film in land scape instead of portrait the videos will imbed in the post with a player instead of having to click the link.
    congrats man! Shit looks straight out of a Norwell illustration!
    mad mikey, Outback and Just Gary like this.
  6. The37Kid
    The37Kid
    Congratulations! For every finished build there must be 3-4 that are unfinished. Looks fantastic. Bob
  7. Super! That first drive is one you won't forget. Congrats!
  8. Bentrodder
    Bentrodder
    from Cotati
  9. Congrats on the drive man !
  10. Can't wait to see it in person.
  11. Yes! Fortunately @Dino 64 had my back.
    Tell him his transmission shifts nicely.:cool:
    Thanks everyone, but gotta fix some issues before venturing beyond the 'hood:
    - Check the drag link/pitman arm geometry; the car turns farther right than left.o_O
    - Fine tune the adjustable brake proportioning valve.
    - Either narrow both brake & gas pedals, or move the brake pedal pad away from the gas pedal. My right foot accidentally stomped on both... twice.:eek:
    - Lower the seat more for better visibility.
    - Tighten the brake light actuator lever.
    brEad, Robdski, mad mikey and 2 others like this.
  12. ....Not completely sure which pedal pads you are using without looking back in your posts, but someone makes rectangular ones and someone also makes ones (round) with the mounting stud off-set. These can free up some room and avoid the scary hitting both pedals at once scenario.
  13. flamedabone
    flamedabone
    YEA!!!!!! That little thing looks bitchn' rolling down the street.
    -Abone.
  14. ...Never mind.:rolleyes:..I should look before offering my thoughts.:( 20240603_184720.jpg
  15. bowie
    bowie
    Great job Gary! Very happy for you! Your car is just plain BITCHN’ !!!
  16. Watch that throttle cable sawing through that aluminum ferrel, might need to extend that upper gas pedal arm so it centers the cable out the hole more.
  17. neilswheels
    neilswheels
    from England
    Fantastic, must be a great feeling, even if there are some teething problems, what an achievement
  18. I took a break from driving to install the windshield & back glass.
    Templates are 1/4" pegboard & plywood scraps.
    My local "Auto Glass Express" cut the clear laminated glass....
    .... then glued their windshield into my powdercoated frame.
    I inadvertently cut the 1-piece side & bottom gasket into 3 pieces when beveling it's corners.
    They're glued in place with 3M black super weatherstrip adhesive and binder clips.
    I attached the frame to the header with the top gasket in place, but that caused the bottom of the frame to rub the cowl paint, so I removed the gasket and everything fits nicely.
    Bratton's hardware.
  19. Tim
    Tim
    from KCMO
    Was just thinking we were due an update! Looks
    Good :)
  20. Excellently done Gary, However , I remember the old saying, If Henry Ford would have built boats we would have all drown.:eek:
    :D
  21. mohr hp
    mohr hp
    from Georgia
    Congratulations!
  22. finalxstage
    finalxstage
    from Joliet, IL
    So rad Gary!!! It’s got “the look!”
  23. BigJoeArt
    BigJoeArt
    Dadgum gary. Thats bitchin!
    hot rods in motion beat hot rods parked 1000000%
    cant wait to see it out on the highway racking up miles!
  24. Thanks for the kudos, fellas.
    I fixed those first-drive issues:
    1) Removed the pitman arm and centered the tires, steering box & steering wheel. Then reinstalled the pitman arm so it's perpendicular to the drag link (measured with a large metal framing square).
    After that, I rechecked 1/8" toe-in and reassembled everything with new cotter pins.
    Now the steering wheel and tires all turn the same amount in both directions.
    2) Narrowed the gas pedal and moved the brake pedal to the left 1/4"- so they're no longer accidently pressed simultaneously. :eek:
    3) Fine-tuned the brake proportioning valve at 0700 Saturday morning on a nearby empty street.
    Here's how:
    How Does a Proportioning Valve Work? And How Do You Adjust It?
    When setting up a street car for performance driving or converting a classic to disc brakes, it is essential to ...
    Now there's max braking pressure with no rear lockup. :)
    4) Cut, lowered & rewelded the seat bases a bit more. Same steps as back in July '24.
    Oh yeah- I also added turn signal and high-beam indicator lights.
    They're inconspicuous but visible to the driver.
  25. Tim
    Tim
    from KCMO
    Love seeing that beast outside!
  26. The hot rod is absolutely stunning Gary.
    Dino 64, Just Gary and lothiandon1940 like this.
