Projects 1956 Chevy Carryall new wood body
Discussion in 'The Hokey Ass Message Board' started by mamllc, Mar 17, 2025.
  1. mamllc
    mamllc
    1956 Chevy Carryall. Everything you don't see in these pictures will be wood. If you remember the Power Wagon project from a few years back, this will be very similar. IMG_5731.JPG IMG_5732.JPG
  2. guthriesmith
    guthriesmith
    Man, that is going to be cool! I’ll be following along to see your progress. :cool:
  3. squirrel
    Is that a one ton panel truck that you started with?
  4. The37Kid
    The37Kid
    Great project, I'll be following the build. Bob
  5. mamllc
    mamllc
    It's a 3/4 ton that was buit with a Cantrell wood body. The owner did a lot of research on it so I got a lot of paperwork with it. It looks like they made them in 1/2 3/4 and 1 ton models, It looks like the 3/4 and 1 ton trucks may have been special order only. 56 was Cantrells last year, I don't know for sure but this may be the only 3/4 ton they made. I know they made at least a few 1/2 ton trucks, if there's one around anywhere I'd love to see it.
  6. The37Kid
    The37Kid
    Cantrell was what came to mind when I saw this thread. A friend wrote an article on the company, I'll p*** this info along to him and ask if he has any info in his files.
    Bob
  7. squirrel
    Interesting, so it was probably a model 3612 Ch***is with Windshield Cowl, when Chevy built it.
  8. mamllc
    mamllc
    Pretty good chance, wheelbase looks right.
  9. squirrel
    Chevy made 1/2 and 1 ton Panel trucks, but only 1/2 ton Suburban Carryalls. The 1 ton panels were longer wheel base. The 3/4 ch***is is the same wheelbase as the 1/2 ton long bed truck, which is between the short bed 1/2 ton, and the 1 ton.
  10. Okie Pete
    Okie Pete
  11. mamllc
    mamllc
    As far as the history of this truck i've got more questions than answers. This is a picture I got with the truck, it's badged as a 3600 and it has 8 lug axles. GVW on the tag is 6900. 465878325_1309439063412351_1998316686522215960_n.jpg
  12. mamllc
    mamllc
    I've got most of the floor in place, made of White Oak. Working on getting the pillars made. The back corners are the worst because they determine the location of the rest of them and because I have no original wood to use. I have a couple pictures but the actual location shape and size are going to end up being my best guess. The wood around the rear fender is not original and came with the truck. It looks like someone cut some metal out of the back of the fender to fit that wood. I'm not sure why and it's likely to cause a problem later.....but that's for another day. IMG_5740.JPG IMG_5741.JPG IMG_5744.JPG IMG_5745.JPG IMG_5746.JPG IMG_5747.JPG IMG_5748.JPG
  13. patsurf
    patsurf
    show the tooling that does those perfect finger joints!
  14. mamllc
    mamllc
  15. Where did you source? What is it called? And, what tool powers it? I'm far less than an amateur woodworker, and in total awe of your progress so far.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Nice shop. Do you the means to sharpen your own cutters?
  17. 1952henry
    1952henry
    I see a true craftsman.
  18. Budget36
    Budget36
    Wow. I love TF trucks, but have never seen or heard of these models.
    I’ll be looking forward to the finished version!!
  19. patsurf
    patsurf
    Sharpone and Bill's Auto Works like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The cutter resembles a custom made unit from a saw shop vs catalog or ready made. Looks to be for a 1” spindle?
    Sharpone likes this.
  21. mamllc
    mamllc
    No I don't. I've got multiples of everything so I let the dull stuff (saw blades, planer/jointer knives etc..) pile up and send it all out at once. I have never sharpened the finger joint cutters. They are carbide and compared to most of the other cutting tools they don't see a lot of use.
  22. mamllc
    mamllc
    I run these on a 5hp Powermatic shaper with a 1-1/4' spindle. For smaller joints I don't need all of the cutters but when I do need to it's a bit much even for that shaper. I ended up modifying the spindle to add a third bearing to the top of it, it made a big difference. The cutters are almost 6" diameter. I had them custom made but don't remember where, been too long. They weren't cheap, I do remember that!
  23. 51504bat
    51504bat
    Subscribed
  24. hfh
    hfh
    from Western MA
    Thank you for taking the time to share pictures and to tell the story of the reconstruction.
  25. The37Kid
    The37Kid
    Finger joints on station wagon bodies always get my attention. How you hold on to the piece and get the perfect cut must take years to master. Off to find a YouTube video of the operation. [​IMG]
  26. mamllc
    mamllc
    It became immediately obvious the first time I saw those cutters spinning that I was not going to be feeding the wood by hand. This is what I came up with. Made from whatever steel I had in the shop at the time, it's been modified a few times over the years. It's keyed into the slot in the table and is driven by a screw attached to the table on the right side, I drive it with a drill. There is a bearing on a bracket that is attached to the blade guard to hold it down. You can see the clamp I am using to hold the piece of wood in the cage. In use the wood would have whatever angle(s) the finger joint needed to be at cut on the end of it. I would have to do whatever it takes to get IMG_5754.JPG IMG_5755.JPG the angled end of the board parallel to the fence and hold it there. If the board is only angled in one direction it's pretty simple, if the end is a compound angle I have to get more creative. The depth of cut of the joint is 1-1/4" so I do it in multiple p***es. You can also see the extra bearing I added to the top of the spindle.
    Sharpone, rod1, VANDENPLAS and 17 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Holy Cow! That’s a hell of a jig. Made a lot of coping jig’s (in left and right) (sticker stock ran on molding machine prior) for raise panel doors. Stock being 1 1/2” thick at times. Never had I made a jig that heavy duty.
  28. 1-SHOT
    1-SHOT
    from Denton
    I bet that makes a lot of noise. I can smell the saw dust from over here.
    Sharpone and lostn51 like this.
  29. squirrel
    This is an example of a flat face cowl. No OEM windshield, the coach builder gets to make that part.
