Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. ct1932ford
    ct1932ford
  2. tb33anda3rd
    tb33anda3rd
    helped Charlie today, keep working from the front to the back. we got the garnish molding cut down for the windshield and moved the stud, for the adjuster bar ,that props the windshield open. image0.jpeg image1.jpeg
    bchctybob, Stogy, winduptoy and 6 others like this.
  3. tb33anda3rd
    tb33anda3rd
    image2.jpeg image3.jpeg image4.jpeg we also cut and welded both doors and fit and tested the windshield again
    Outback, bchctybob, Stogy and 12 others like this.
  4. patsurf
    patsurf
    Stogy, winduptoy and tb33anda3rd like this.
  5. tb33anda3rd
    tb33anda3rd
    Stogy and winduptoy like this.
  6. ct1932ford
    ct1932ford
    Looks good for a couple of slackers!:p
    winduptoy likes this.
  7. ct1932ford
    ct1932ford
    Stopped by this week to see no one at work! “Slackers “ IMG_7837.jpeg IMG_7836.jpeg IMG_7838.jpeg
    Outback, bchctybob, Stogy and 9 others like this.
  8. TFoch
    TFoch
    Looking good!
  9. tb33anda3rd
    tb33anda3rd
    I took the doors and pieces back to my shop and finally got a chance to work on them.
    I trimmed the back door skin from the 4dr to shape and used the opposite jamb section from the other door to creat a jamb section of the back corner of the cab. image19.jpeg image18.jpeg
  10. tb33anda3rd
    tb33anda3rd
    I trimmed the jamb to match the front door shape, then welded it to the "back" door.
    Outback, bchctybob, Stogy and 10 others like this.
  11. tb33anda3rd
    tb33anda3rd
    I then cut a piece of sheet metal to the arch of the door to create a return for the back of the cab to attach to. image12.jpeg
    Outback, bchctybob, Stogy and 11 others like this.
  12. tb33anda3rd
    tb33anda3rd
    I cut off the the part of the "door" above the bead and made a new section, putting a raised area in it to mimic a 29 model A pickup. folded the sides and welded it in. image9.jpeg
    bchctybob, Stogy, winduptoy and 9 others like this.
  13. tb33anda3rd
    tb33anda3rd
    I then did the same for the other side, welded up the old door handle holes and cleaned it all up with a little 80 grit.
    bchctybob, Stogy, Okie Pete and 13 others like this.
  14. tb33anda3rd
    tb33anda3rd
    I chopped the back window only an inch and a half, so it is the same height as the side windows. image0.jpeg
    bchctybob, Stogy, winduptoy and 11 others like this.
  15. ct1932ford
    ct1932ford
    That’s it?:p
  16. tb33anda3rd
    tb33anda3rd
    Charlie was worried if we went any more he would have a hard time seeing out of it.
    Stogy, winduptoy and Okie Pete like this.
  17. ct1932ford
    ct1932ford
    No, I meant that’s all you did!:p
  18. tb33anda3rd
    tb33anda3rd
    slacker is as slacker does
    bchctybob, Stogy, winduptoy and 3 others like this.
  19. tb33anda3rd
    tb33anda3rd
    stopped by Charlie's to drop off the parts for test fit. put one door on and clamped the quarter to the post. I need to do a little t******* before I weld it in but it looks like it will work. image0-4.jpeg
    bchctybob, TFoch, Okie Pete and 5 others like this.
  20. tb33anda3rd
    tb33anda3rd
  21. tb33anda3rd
    tb33anda3rd
    two visitors today, Charlie dropped off the hood for me to louver and Mark came by and laid them out. image0-4.jpeg image1-2.jpeg image2-2.jpeg two rows per side. ten on the inside row and 8 on the outer side.
    bchctybob, TFoch, winduptoy and 4 others like this.
  22. tb33anda3rd
    tb33anda3rd
    once Mark-ed out, I cut thin slices with the grinder and a thin cut off wheel. the hand made tool slipped into the groove on the face side of the hood and the chisel tool punched the louver from the back side. image3-2.jpeg image4-3.jpeg image5.jpeg
  23. tb33anda3rd
    tb33anda3rd
    With a little hammer and dolly work and cleaned up with a file the hood is done.
  24. ct1932ford
    ct1932ford
    We make a good team.:cool: Hope Charlie likes it.
  25. tb33anda3rd
    tb33anda3rd
    he is going to love it.
    Outback, winduptoy and ct1932ford like this.
  26. HOTRODPRIMER
    HOTRODPRIMER
    I like the Jeep tires. HRP
    winduptoy, tb33anda3rd and ct1932ford like this.
  27. patsurf
    patsurf
    yes yes and yes--and perfect!
    winduptoy, ct1932ford and tb33anda3rd like this.
  28. Dino 64
    Dino 64
    from Virginia
    Love those louvers !! :)
  29. tb33anda3rd
    tb33anda3rd
  30. tb33anda3rd
    tb33anda3rd
    we also trimmed up the cab corners for fit and made some measurements for the back of the cab. image0.jpeg
    Outback, bchctybob, TFoch and 10 others like this.
