Projects 28 CCPU build
Discussion in 'Traditional Hot Rods' started by G_Don, Mar 2, 2025.
  1. G_Don
    G_Don
    Think I'm just gonna modify the bed to fit. Id rather have the suspension working the way the guys from cl***ic st rod mfg designed it... But I appreciate the concern.
    Also, I think I am good on running board brackets. Still not home so can't check for sure, but definitely will keep that in mind.
    Thanks for all the kind words. Will see how far I get in the next 5 weeks and will send updates.
    Gordy
    LCGarage and lothiandon1940 like this.
  2. gimpyshotrods
    gimpyshotrods
    Caster is NOT SET by the crossmember.
    That angle is set to reduce spring bind.
    LCGarage, OFT, Blues4U and 1 other person like this.
  3. 05snopro440
    05snopro440
    Yes, to reduce spring bind because of the caster angle of the axle... Semantics, but still pretty much the same thing.
    As I understand the choices are to live with spring bind, get a new crossmember, or get the adjustable perches.
    OFT and lothiandon1940 like this.
  4. gimpyshotrods
    gimpyshotrods
    Not semantics, but confusing misinformation.
    I cannot count how many people who now think that you set the front axle caster at the crossmember.
    That is very real, and VERY wrong.
    rmcroadster and '28phonebooth like this.
  5. 05snopro440
    05snopro440
    Interesting, I haven't run across anyone who thought that.
    badshifter likes this.
  6. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    If caster is not set at the crossmember, how do you set caster without putting the spring in a bind?
    Von Dago and badshifter like this.
  7. gimpyshotrods
    gimpyshotrods
    Caster is the kingpin angle, in relationship to the ground.
    You adjust link bars, pie cut and weld up the wishbone, or bend the beam axle.
    OFT, Blues4U and rmcroadster like this.
  8. G_Don
    G_Don
    I'll be more careful next time I type up the next part of the build thread.
    I set the caster by lengthening the heims on the lower bars of the front four bars and the crossmember allows the front spring to not be in a bind to achieve my 7 degrees of caster. And if the lengthening of the lower four bars wont technically make it a true four bar, then I guess this build will have ugly hairpins that look like four bars. lol
    Gordy
  9. 05snopro440
    05snopro440
    You explained it just fine. We knew what you were talking about.
  10. G_Don
    G_Don
    IMG_0145.jpeg IMG_0147.jpeg IMG_0146.jpeg Not much to report. Finish welded the ch***is minus the front shock mounts. Gonna use the roadster supply ones and weld a bung between them and then run them like the speedway zinc ones. Returning the speedway zinc ones cause theyre a 1/2" dia and I need a 7/16".
    Not pictured, finish welded the exhaust pipes.
    Next im gonna play with fitting the fenders and getting the tanks put on. I got these cool gas caps from my friend George at a local swap. I'm gonna try to fit them up into the aprons. Once I figure out the fenders and tanks, next step is ch***is paint.
    Anyone familiar with how the tankz saddle tanks work? They seem to have an extra hole on them, which I'm ***uming is to run a pipe between the two? The directions I received are pretty terrible lol
    Gordy
  11. 05snopro440
    05snopro440
    You should have this and a toggle switch to operate it. https://www.tanksinc.com/index.cfm/...duct_id=93/category_id=-1/mode=prod/prd93.htm
    A guy I used to travel with long-distance to shows had them on his A Tudor he built into a tub. He hated them. All the rest of us would pull up to a pump, fill, and be done. He would need to fill on both sides and it was slow. He said he'd never use them again on another A. Just food for thought. They're a good idea in terms of space saving, but if you ever need to service them you need to pull the splash pans, meaning raise the body. Big job.
    ALLDONE and G_Don like this.
  12. 05snopro440
    05snopro440
    I took your lead and I have the same front crossmember waiting for my build. It looks way better than my stock piece too.
    osage orange, Dave Mc and G_Don like this.
  13. Rand Man
    Rand Man
    I like it. Good thread.
  14. G_Don
    G_Don
    Dang, yeah the plan was to use the truck as a truck when I needed it. (Not that its a huge bed to begin with) So wanted to avoid putting a tank in the bed. Im super limited in room for the bed. I think I'll just run them for now and change them down the road if it I ever need to service them. Too late to return them and they were quite pricey haha
    hook00pad and 05snopro440 like this.
  15. 05snopro440
    05snopro440
    Yeah, they're not cheap. I've heard the odd guy rave about them, but if you like taking it on long trips you may not. You have them now, so might as well.
    I am thinking I'll unfortunately end up with a tank in the bed but am not sure.
    hook00pad and G_Don like this.
  16. ALLDONE
    ALLDONE
    the tanks don't work you do...I have them on my woody,.. came that way...they put the fillers in the wheel wells so I don't alwaays have fuel on the running boards...getting gas is constant... with only 7 gallons.. doesn't take long to run through 5, then you have to switch over.. and head for the gas station... you fill the first one up to full and run the other side for a while, and again doesent take long to run through 5 gals... constant monitoring the fuel level..
    OFT, 05snopro440 and Dave Mc like this.
  17. G_Don
    G_Don
    Playing with body blocks and the bed. Think I either need to modify the blocks or modify the coil over mounts. Thinking I'll just mod the blocks though as that seems to be the easiest solution.
    Also it appears my running board brackets are all the same? Is that how they were or are they different from right to left and front to back? The back p*** side looks right, but the front p*** side looks very off.
  18. Weedburner 40
    Weedburner 40
    The two front running board brackets are longer, otherwise they are the same side to side if I remember correctly.
    Tim, OFT, lothiandon1940 and 3 others like this.
  19. 05snopro440
    05snopro440
    A friend of mine made a steel substructure to mount the bed to instead of the wood blocks. It was much more stout and secure, and looked better too.
    LCGarage, OFT, Dave Mc and 2 others like this.
  20. Dave Mc
    Dave Mc
    My 29 has a twelve-gallon tank in the bed, works for me, accurate fuel gauge. IMG_0490.JPG
    Okie Pete, 05snopro440 and 2deuces64 like this.
  21. Weedburner 40
    Weedburner 40
    I also replaced the wood support with a steel tubing unit for the bed. I then built a 15 gallon tank that fits in it under the front of the bed with the filler neck between the bed and body on my 31 rpu.
  22. Rand Man
    Rand Man
    On a subject to fuel tanks, my coupe had one of those rounded, Speedway, moon type tanks, probably less than 10 gallons with no fuel gauge . I could hardly drive anywhere without stopping for gas. I learned the hard way several times, I better for damn sure be stopping for gas anytime I saw a station. I replaced it with a 17 gallon tank (with a gauge) I put behind the seat. I don’t think the closed cab pick up has any room at all for something like that. I think you could probably put a decent size tank under the bed, behind the rear axle. I would put a cover on it, so it might look like some sort of rolled pan. If you’re running a V8, don’t cut yourself short on fuel capacity.
    LCGarage and Dave Mc like this.
  23. chickenridgerods
    chickenridgerods
    from DSM, IA
    A stock cowl top Model A tank is only 10 gallons. A stock '32 tank is only 11 gallons. 5+5=10. Not much different in the end.
  24. 05snopro440
    05snopro440
    My old man has an oval factory tank in his 33 Dodge with a gauge. He found out quickly that 1/4 tank means full up now. The volume of the top 1/4 and bottom 1/4 is very much less than the middle.
    Tim likes this.
  25. 05snopro440
    05snopro440
    10 gallons on a stock tank in 1928-1932 with a stock engine where you weren't going far or fast is a different story than today's driving with a hopped up engine.
    OFT and Weedburner 40 like this.
  26. chickenridgerods
    chickenridgerods
    from DSM, IA
    Not arguing that, but the point was that running saddle tanks isn't really a hinderance to range any more than a stock Model A or '32 tank would be. There are a lot of hot rods running around that are powered by SBCs (or the like) with stock A and '32 tanks. The vast majority of the country is going to have a gas station within 100 miles of the next one.
    Dave Mc likes this.
  27. Rand Man
    Rand Man
    I have three Stromberg’s and a heavy foot. I’m gonna use up some gasoline, fellas.
    osage orange and 05snopro440 like this.
  28. 05snopro440
    05snopro440
    Who wants to stop every 100 miles on a road trip? The saddle tanks are only 13 gallons combined. Imo, the closest to 20 gallons you can get is ideal in a hot rod. In an A you might be lucky to get 16 or so.
    If you're driving in a spirited manner, 10 gallons could get drank up fast.
    osage orange and Rand Man like this.
  29. G_Don
    G_Don
    I'm running the stock tank and fuel gauge on my Phaeton and definitely stop a decent amount. Havent done any crazy long road trips. I feel comfortable just getting more gas when it says 1/4 on my model a.
    I guess the saddle tanks are 13 gallons so thats more than im used to... this truck will have a single 4bbl on it, where my phaeton has a single 2bbl (waiting to get my 3x2 intake fixed) lol
    Not sure how much different fuel consumption is between a 4bbl and a 2bbl but I gotta think 4bbls drink more (***uming theyre both tuned correctly).
    Gordy
    Primered Forever likes this.
  30. 05snopro440
    05snopro440
    If you like the sound of all 4 barrels wide open, it will drink more.
    G_Don likes this.
