Technical Why Is My MPG So Low?
Discussion in 'The Hokey Ass Message Board' started by Yardbirder, Mar 18, 2025.
  1. 49ratfink
    49ratfink
    sounds like the stupid modern way to me.... but I am good at math.
    lothiandon1940 and firstinsteele like this.
  2. carbking
    carbking
    I didn't see it mentioned, but check your odometer.
    Drive 20 or so miles on a road with mileposts, and compare your odometer reading to those.
    A change in rear end ratio or tire size can make a significant difference from actual to indicated distance. Even a change in air pressure can make a difference, although it is very minor.
    And guess I am in a minority, but MATH IS FUN! Even at my age!
    Math and physics are a car enthusiast's two best friends, unless he/she is independently wealthy!
    Jon
  3. arse_sidewards
    arse_sidewards
    from Central MA
    Pull the spark plugs, post pictures of the business end of the plugs.
    lothiandon1940 likes this.
  4. Yardbirder
    Yardbirder
    Yes, it’s a Fordamatic.
  5. Yardbirder
    Yardbirder
    The plugs have been replaced, but the engine has not had a compression test yet.
  6. Clydesdale
    Clydesdale
    @'28phonebooth was asking to see the business end of the plugs to use them as a diagnostic tool, the condition of the plugs can highlight a number of engine running issues (lean, rich, poor oil sealing etc etc)
    From your initial description it sounds at the very least it needs a tune up to baseline settings of ignition and carb, a compression test, then look into other areas of impact, such as poor transmission performance, dragging brakes or bearings etc.
    I think expectations should be realistically set with the minding that its an old car, that could have led any sort of life before your ownership.
    MPG figures whilst important to note if they suddenly change, on the whole aren't something a classic car owner should ever really be realistically concerned about. IMHO of course
  7. 05snopro440
    05snopro440
    That's****uming your odometer is accurate. If not, you can map our your route on Google maps nowadays to get a close approximation of the mileage.
  8. lothiandon1940
    lothiandon1940
    Pencil and Paper are Traditional.:D;)
    Montana1, Charlie K, joel and 7 others like this.
  9. 05snopro440
    05snopro440
    They are a record of the volume of fuel you purchased, important for determining mileage.
    My smartphone is terrible at keeping up with my actual route unless it's active the entire time. Using an app like that could mean a low estimate on mileage.
    Like you said, the MPG can indicate tuning issues or it not running as it should. While the absolute number isn't critical for a hobbyist, paying attention to it for someone less experienced can alert to when something isn't right.
    It sounds like to me he has an 80-ish year old car that may not have had much engine work or maintenance. Are the rings sealing poorly? Is the thing badly in need of a tune? Can it be brought back to stock without major engine work, maybe not, but a tune and checkup on the engine might improve things or at least bring awareness to what's happening.
    My cause of low fuel mileage on my cars is my foot.
    X-cpe and alanp561 like this.
  10. Download a compression check app
    34 5W Paul, HSF, ffr1222k and 18 others like this.
  11. twenty8
    twenty8
    I wanna like that more than just once......:D
  12. Yardbirder
    Yardbirder
    I didn’t post this thread to be ridiculed.
  13. squirrel
    please don't take our fun too seriously, we just like to have fun, but help folks at the same time.
    Cosmo49, BJR, Charlie K and 6 others like this.
  14. PhilA
    PhilA
    Checked your brakes? A dragging brake plus a tired engine is a recipe for miserable fuel economy.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    >>Download a compression check app>>
    >>I didn’t post this thread to be ridiculed. >>>
    No! No! It's a great idea. AliExpress has a sale on a compression check apparatus right now if you live in the US. 99¢ and free shipping. Even I can afford to get one now.
  16. MMM1693
    MMM1693
    What is a good compression number on a flathead?
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    Funny you should ask. I just asked google's auto intelligence guy the same question. He claims "For a well-maintained, normally aspirated street flathead engine, a good compression reading should be around 130 PSI or higher per cylinder, with readings consistently within 20% of each other"
  18. alanp561
    alanp561
    o_OAnd when your battery dies?:rolleyes:
  19. It’s called humor.
    and it helped my bumping the thread.
    that’s how it works
    34 5W Paul, Cosmo49, i.rant and 8 others like this.
  20. williebill
    williebill
    I've never known how to get with the program. That's why I'm here. I prefer pre app stuff.
    My dislike is based on fear and ignorance.
    J/K, Jack.
  21. Kevin Ardinger
    Kevin Ardinger
    You gotta have thick skin to hang around here brother. I’ve been insulted numerous times, but sometimes you just gotta consider the source. If you can weed through the*********, you will find some helpful information. Posted from my smart phone.
    lothiandon1940 and Baumi like this.
  22. RodStRace
    RodStRace
    You have changed the plugs. That IS a tune up on a car with a non points distributor and no timing adjustment. A flathead with a fordomatic is NOT that.
    Start with the basics. Do a full check and tuneup. This includes going into the distributor, compression check, dwell and timing set, carb adjustment and perhaps rebuild. This will confirm engine condition and optimum adjustment. Then check the rest of the drivetrain, brakes, alignment, tire pressures. All of this will affect MPG. Also understand that a 70 year old car was not designed for modern fuels, so some specs should be treated as suggestions, not absolutes. Each car will require different adjustments to run it's best due to wear, fuel, driving style and local conditions.
    The reason for some humor is that this concern for MPG has been an issue for as long as people have had to pay money for fuel. It has been discussed, been the impetus for wild claims and snake oil hoaxes, been researched by DIY, independents, major manufacturers and legislated by government.
    If you understand basic physics, you know that energy is used to move the vehicle and yourself, so using less to do more is a fundamental concept. Asking how is something that has been covered in the depression, during WWII with rationing, during the gas crisis, and at every time in between. It is a subject that has been covered more than the dangers of smoking. The answers are out there.
    Fordors, hfh, Yardbirder and 4 others like this.
  23. 05snopro440
    05snopro440
    If you have to say it's humour, maybe it wasn't funny. :) That bump from 6-minutes earlier was a noble service you provided. :p
    travisfromkansas likes this.
  24. Need a humor app
    34 5W Paul, BJR, i.rant and 9 others like this.
  25. Tickety Boo
    Tickety Boo
    from Wisconsin
    I agree with jaracer that the centrifugal advance might not be working, especially the way the flathead distributors have the advance located under the points plate where the weights seldom get lubed, cleaned and sometimes won't move because of rust :oops:
    The easy way to check is to connect a timing light to make sure timing advances during the change from low rpm to high rpm.
    05snopro440 likes this.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    You don't need any devices other than a pencil & paper ... And your mind ..shouldn't have to hunt for that !
    49ratfink, williebill and seb fontana like this.
  27. ClayMart
    ClayMart
    I think this car would have originally had a "Load-O-Matic" distributor. If it still does I don't think you'll find any advance weights below the breaker plate. Load-O-Matic distributors need to be used with a specific compatible carburetor that has a port that provides an air speed signal to the distributor to control ignition advance. Search the HAMB or the web for "Load-O-Matic" for more info and ways to update to a later model distributor with both mechanical and vacuum advance controls.
  28. ^^^^ This. The OP says the car is 'stock' but admits to not knowing much about it. An incorrect replacement carb, misconnection between the distributor and carb, there's multiple ways this could be wrong.
    And I would be concerned about the poor mileage as running that rich can't be doing the rings any good with washing away the oil.
  29. Rusty O'Toole
    Rusty O'Toole
    Could be a hundred things starting with
    1) engine condition. Tune up starting with compression test. Bad compression and low oil pressure = worn out motor
    2) Driving conditions
    3) Your driving habits
    4) General condition of car. Wheels out of line, low tire pressure, dragging brakes, and other things can drag down mileage but usually not that much.
    Lots of advice in this thread, should keep you busy for a while. Hope everything works out for you.
  30. ClayMart
    ClayMart
