9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
    This is my Bonneville car with my sweet Jodie Dog!
    fatassbuick, 1Nimrod, Stooge and 11 others like this.
  2. ffr1222k
    ffr1222k
    Foxbody Tbirds are cheap. I have had several Turbo Coupes given to me. They do weigh a little more than a Mustang but have a decent trunk. Turbo Coupes come with either a 3.73 or 3.55 8.8 limited slip. Automatics had the 3.73 and manuals had the 3.55.
  3. Harv
    Harv
    from Sydney
    If memory is right, '87 was the last year for the Screaming Chicken. This poncho needs one (please :D).
    Cheers,
    Harv
    porkshop and Sharpone like this.
  4. RodStRace
    RodStRace
    I'm just waiting on a Jeep update.
  5. Rear leaf springs. large engine bay. As light as can be. Spend no money. Strong criteria. I would suggest an older 1/2 ton pickup. Many have decent rear axles and disc brakes on the front. There's enough room under the hood for a turbo and plumbing and a large frontal opening for engine cooling and intercooling. Most have enough trans tunnel to do whatever. Putting in a turbo with space limitations can hurt the efficiency of the unit. You will also need space for the electronics to run the efi and have laptop tuning. You have less to strip from a truck cab than a p***enger car. You will need a stronger frame for 1000 hp. We've all seen a bodied car twist radically off the starting line with out a good ch***is and some cage work. If a truck is off limits, then I would try to maximize the points you laid out in the beginning. :)
    bobss396, porkshop and Crosley like this.
  6. squirrel
    I have a truck, but it's way too heavy for what I want to do, has no room inside (can't lock stuff in the bed in hotel parking lots), etc. It's not what I want for this project. I've already spent a lot of time considering it.
    I'll get an update next week. Other stuff going on now.
  7. SS327
    SS327
    I thought the checker was a great idea. :(
  8. 19Eddy30
    19Eddy30
    from VA
    @SilverJimmy
    Have a question on reason for the
    Neck Down Scoop ,
    Was it to reduce air to engine ?
    Or increase air pressure & the speed of air ?,
    Or a higher air pressure closer to noise ?
    Pro Sock / Door Slammer used that scoop for years , but not in that configuration.
    Sharpone, swade41 and porkshop like this.
  9. I vote for wild cherry. Just because of the name.:)
  10. 6sally6
    6sally6
    ALways want to build something outta one of these !!
    351W are a bolt-in.... Stroke-able (zatta word?!) to 427+
    Ease to lighten up
    Really cool body style and AC and such come standard...
    6sally6
  11. chevy57dude
    chevy57dude
    I vote Firebird! Generous offer for sure. Mr. Jim will go fast no matter what he builds.
  12. Scoop is designed that way for a couple reasons.
    1) At the speed I’m trying to go (200 mph!) the scoop opening only needs to be large enough to supply the air that the engine can use. The way it was explained to me was that if the scoop opening was too large air would pack into the scoop and then start coming back out and cause turbulence and drag. A friend of mine who was a lot smarter than I am designed the size and also the shape of that aluminum piece that I call a “Schnozzel”! It actually has NACA airfoil shapes on the inner and exterior surfaces. I think that my scoop is pretty much invisible to the air that I’m trying to go thru in my quest for 200!
    2) The reasoning on the tapered design is also based on the speeds I’m trying to reach and the distance that we race over. By having my scoop get larger past the opening the theory is that as the air expands it will slow down before going into the engine which should help with fuel mixtures and making power.
    3) SCTA rules limit how high your scoop can be above the hood and also how far forward the opening can be.
    All of the above is for land speed racing, it seems to work as my Firebird has a 302 CI GMC inline 6 and I was able to set the record at ElMirage @ 165.545 mph and was able to go about 190 mph at Bonneville!
    Hopefully Jim gets what he wants and then we all get to watch the fun again!
  13. 19Eddy30
    19Eddy30
    from VA
    @SilverJimmy
    Thats what I was thinking ,
    Packing air , (parachute)
    & also small cid ,
    Thank you for the response
    porkshop, Deuces and Sharpone like this.
  14. T. Turtle
    T. Turtle
    Well Uncle Tony's Garage over at YT is thinking like you do...
    porkshop, Baumi and squirrel like this.
  15. How about a Ford Granada with a LS.
    It's another fairly mundane car, I believe they are the older Mustang / Maverick ch***is so there is also a ton of parts availability I believe some of them came with 9-in axles and if you're real lucky you can find a Lincoln Versailles and it's even disc braked in the rear.
    I mean if you want to go stupid fast and win the cheering part of the zip tie drags You're going to need mismatch fenders maybe a little cancer on top of the wheel wells You know standard stuff that makes the car look like it's ready for the trash heap.
    porkshop likes this.
  16. squirrel
    I haven't seen any Granadas anywhere lately....
  17. RodStRace
    RodStRace
    They are fairly heavy, too. I'd guess 2-300 over a similar Fairmont.
  18. DDDenny
    The LQ4 in my 2000 Silverado said adios this week, I just ordered a rebuilt, cash and carry. A LOT OF CASH, haven't got the total $$$ or expectation of delivery date yet.
    :mad:
    1Nimrod, porkshop and squirrel like this.
  19. finn
    finn
    SN 95 six cylinder Mustangs are everywhere and cheap here in Tucson. The LS fits, and the 8.8 will bolt in if it doesn’t already have one.
    1Nimrod, porkshop and ffr1222k like this.
  20. snoc653
    snoc653
    from Iowa
    Focus on the robots Jim. We still be here to tell you how we’d spend your money when it’s our turn again. The Firebird has to be a real contender as anything you can dream up is probably available to buy or look at for inspiration on how to build your own. And the LS works well in them.
  21. A Boner
    A Boner
    What do you want to run in it? LS or how about an in-line Chevy 4200…easier to turbo, I would think…plenty of HP!
  22. squirrel
    I looked into the Atlas engines, seems like a difficult way to go, although it would be neat.
    There are just too many issues with them....not fitting, blowing up, etc. And not easy to find an engine, when I looked.
    porkshop and TrailerTrashToo like this.
  23. mcgyver
    mcgyver
    A 4 door G body would likely fit the parameters other than leaf spring rear... The olds and buicks are much less pretty than the Malibu and could possibly be much cheaper if you could find one.
    A 4 door 70's Nova or BOP equivalent?
    greasemonkey54 and porkshop like this.
  24. squirrel
    all my buddies run those cars, I need something different :)
  25. justabeater37
    justabeater37
    Turbo LS Vega Wagon?
    porkshop, Deuces and squirrel like this.
  26. squirrel
    Vegas are few and far between these days, too. And they take a lot of work to get capable of going fast, not much useful rear suspension, etc, not much room in the engine bay or tunnel either.
    1Nimrod, porkshop and Deuces like this.
  27. Deuces
    Deuces
    My folks had one just like it... Same color even....:rolleyes:
  28. Kerrynzl
    Kerrynzl
    The 3rd Gen Trans Am had the same drag coefficient as a modern C7 and C8 Corvette [0.32]
    The Firebird was slightly less at 0.33
    So they are pretty good
    They can also be gutted out to weigh next to nothing
    I had a 3rd Gen Z28E [Euro] that weighed 3000 lbs with all the road legal requirements
    porkshop and SilverJimmy like this.
  29. squirrel
    3000 is pretty light for a newer (remember I'm into 1960s stuff) V8 RWD car.
    this is the Cherokee...pretty interesting. The weights might be with the 4 cylinder?
    pprather and porkshop like this.
  30. snoc653
    snoc653
    from Iowa
    The firebird was originally about 3500 lbs from the factory. 3000lbs should be doable fairly easily. The Cherokee’s lack of a frame will require support being added and they don’t have a whole lot to remove to offset the weight gain from the needed support. I’ve wheeled with some Cherokees and seen them get twisted from off camber stuff when they weren’t reinforced. I like both vehicles and would take either if it was offered. The Cherokee would be more unique but the Pontiac would be safer and easier to build. The Firebird would have a better resale value as well as the fact that if you kept it, there is no reason you would have to stop at 9s.
