Projects I bought the worst hot rod project in the country. Model A ’28 homemade Coupe
Discussion in 'Traditional Hot Rods' started by attitudor, Feb 1, 2023.
  1. attitudor
    attitudor
    from Finland
    The new garage season is about to start! It was a sunny autumn Saturday. Rolled the Hot rod out from the garage for motivation and turned it other way round again. The roof bones came out perfect!
    Okie Pete, Nailhead A-V8 and mvee33 like this.
  2. attitudor
    attitudor
    from Finland
    Some updates from this winter period. One step forward and two back. I removed the whole rear leaf spring suspension and will replace it with coil overs. If you read this thread, you can see that I've been struggling with the rear suspension, it is always too low but too stiff. So, let's just forget the original Model A spring.
    Also made lot of work by mounting the brake pedal system. Then removed it all and installed a new 90 degrees system instead. It just didn't look good when it poked out through the firewall. Had to tear the gas tank in pieces and use it as a cowl top only. Now I’m working with the dash and firewall. The battery is finally installed, it was a tight fit but a small one fit half under the trunk floor. Luckily I got all wrong parts sold very easily and I was able to buy me a carburetor, air cleaner, starter, and dash panel.
    Of course, when I had to remove the gas tank including the dash, I had to remove the steering column again. And then mount it back and fabricate new mounts and everything. It is very tight fit between brake system, brake system mounts, steering column, brake pedal arm, dash, firewall etc. Very slow progress and lot of thinking.
    IMG_4786.jpeg IMG_4785.jpeg IMG_4792.jpeg IMG_4821.jpeg IMG_4838.jpeg IMG_4841.jpeg
    Rickybop, orbitup, Okie Pete and 6 others like this.
  3. Baumi
    Baumi
    Your persistance is crazy, my hat´s off to you. You brought her back to life. I just had to giggle a bit after imagining you driving your freshly finished Hot Rod to a carshow one day and the first person you meet would be an old geezer saying what a shame it was to cut up such a nice car, hahahaha
  4. attitudor
    attitudor
    from Finland
    I had to blow the gas tank in parts. Now everything just bolts on back together. Here is my new old dash which was cut off from the tank and now it is bolt-on. The dash panel is similar what I put in my previous Hot rod 15 years ago. Glad I found the similar one!
  5. HOTRODPRIMER
    HOTRODPRIMER
    Damn, that explains the colloquialism of making Chicken salad out of Chicken Sh!t.:D HRP
    RAK and attitudor like this.
  6. Pasthisprime
    Pasthisprime
    I have never seen such a pile of rust, literally, turned into a car body. I would never even attempt what you have pulled off. Congratulations!!
    59sedandelivery, RAK and attitudor like this.
  7. deathrowdave
    deathrowdave
    from NKy
    Outstanding A+
    attitudor likes this.
  8. attitudor
    attitudor
    from Finland
    I built front shock mounts and when they were finished I realized my poor old frame is flexing like hell. I made some reinforcement and now it’s alot sturdier. Glad I found this issue now.
    It’s sunny outside, time to take Packard out and give it a wash! ☀️
    IMG_4873.jpeg IMG_4876.jpeg IMG_4877.jpeg IMG_4880.jpeg IMG_4879.jpeg IMG_4884.jpeg
    Deutscher, Okie Pete, 2Blue2 and 6 others like this.
  9. chlsnk
    chlsnk
    Great work! Doing something similar with a sport coupe. Got the back half of a tudor from @JimmyThe****** using it for a top to replace the wood/soft top.
    Rickybop and attitudor like this.
  10. G85
    G85
    What a fantastic resurrection, what an accomplishment. I just stumbled on this because of the ***le and I'm really glad I did. Talk about inspiration!
  11. 59sedandelivery
    59sedandelivery
    An ABSOLUTELY STUNNING TRANSFORMATION!!!! some of you guys metal crafting skills are amazing....
  12. attitudor
    attitudor
    from Finland
    We have functional steering!! Great milestone. Vintage Motors Finland machined new steering links, thank you. It was a tight fit between Vega box and SBC engine mount.
    Deutscher, Rickybop, Jeff34 and 6 others like this.
  13. NoSurf
    NoSurf
    Great job!
  14. panhead_pete
    panhead_pete
    Really love this build and your problem solving.
  15. attitudor
    attitudor
    from Finland
    I’m happy! I will continue again next winter. This garage season was pretty good.
    IMG_5222.jpeg IMG_5227.jpeg IMG_5228.jpeg IMG_5231.jpeg IMG_5232.jpeg IMG_5234.jpeg IMG_5241.jpeg IMG_5237.jpeg
    jamesgs4, orbitup, AHotRod and 13 others like this.
  16. Squablow
    Squablow
    Looks good! A TON of welding and fab work in that one, for sure.
  17. Rickybop
    Rickybop
    More than "pretty good".
    You're my new hero.
    Cool Daddy-O.
    Thanks for sharing.
    NoSurf and attitudor like this.
  18. attitudor
    attitudor
    from Finland
    Thank you. I mean it would have been great to have this in driveable condition but small things always take more time. This is my winter project so luckily I have work left for the next winter still.
    Baumi, Rickybop and Deutscher like this.
  19. Rickybop
    Rickybop
    You well answered the question asked in the recent thread, "What Do You Guys Do In The Winter?"
    I'll watch for you next season.
  20. attitudor
    attitudor
    from Finland
    Two swap meets during the weekend. I managed to buy a cheap shifter for the Coupe. Also scored these cool old chromed hairpins. I guess I have officially started to collect parts for my next Roadster project.
    Stock Racer, The37Kid and Deutscher like this.
