Technical Do I have the original running boards? (1940 Ford Coupe)
Discussion in 'Traditional Hot Rods' started by Rockson, Mar 21, 2025.
  1. Rockson
    Rockson
    I want to get running board covers but I read in another thread that they won't fit after market runningboards (Smoothies)?
    Are my running boards original or not? Can you tell by the pictures? I have no idea myself.
  2. BJR
    BJR
    Look aftermarket to me. Don't believe the originals were smooth under the rubber covers.
    lurker mick likes this.
  3. neilswheels
    neilswheels
    from England
    Probably a quick way to heck would be to look underneath, Stockers have loads of little holes for the vulcanised rubber to grab on to, and the curved edge on the outside is kind of angular, not smooth at all, in fact, they are pretty lumpy all over. If there are signs of this or the holes underneath, they may well be original, if not, Id say there aftermarket. On the plus side though, you wont need to do much prep to fir the covers, ***uming they will fir them if they are aftermarket.
    Rockson, clem, warbird1 and 2 others like this.
  4. Karl Wescott
    Karl Wescott
    Yours a most likely aftermarket. The curve on the outside is a bit too tight, It does not have the relief marks (that neilswheels remarked on) and it is too straight front to back. Aftermarket covers are simply not going to fit, they only fit original boards and there are no replacement boards with the correct shape.
    One option is fibergl***. We do make boards with the rib pattern molded in, painted with a dull and resilient bumper paint they can look stock.
    5window, williebill, Rockson and 3 others like this.
  5. chevyfordman
    chevyfordman
    A lot of running board covers I have seen installed, even Bob Drake ones, you have to really clean the boards good or eventually the rubber starts buckling like the rubber is too big when all that is wrong is really the glue surface. Rubber can be cut and glued back together with super glue to get to get a good fit. This might work for you.
    Algoma56 likes this.
  6. Ham065
    Ham065
    I didn't want a smooth finish on my painted 51 GMC running boards so I had them arma coated. Non slip and I think look really nice. You might consider doing that to these smoothies. Would look nice.
  7. alchemy
    alchemy
    I usta have a pair of originals around, but you don’t put your location in your profile so we don’t know if you are half way around the world, or next town over.
    Budget36 and Moriarity like this.
  8. 1946caddy
    1946caddy
    from washington
  9. Rockson
    Rockson
    I'm half around the world unfortunately. In Sweden.
    I appreciate all comments and help in this thread. Thank you guys.
  10. MMM1693
    MMM1693
    Why couldn't a guy strip the boards and recoat with bed liner? Too cheezzee looking as in cheap ***?
  11. Crusty Chevy
    Crusty Chevy
