Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    I must have been a smart man not putting the flywheel on when it was mocked up.
  2. Greg Rogers
    Greg Rogers
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. Paul
    Paul
    Editor
    very cool, I see a couple rare Eelco fittings on the front carbs
    curious what jets you end up with
    ifrc my BBC setup worked best with 10 sizes larger than stock on the big 2GCs
    worst mpg but best seat of the pants power setup I ran on my big block
    better than low rise 2x4, cross ram 2x4, bread box 2x4 or tunnel 2x4
    plus they just look so cool
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Kinda funny you say bigger because all of the old how to info published by Man a fre back in the day call for smaller than stock jets like 10 numbers smaller. These are 58 chev 283 carbs and I think the stock jets were 58's? the ones that I had been running are 50's. I have tried 48's but it surged (lean) on the freeway. I put a set of 49's in it and we will see. the plugs look a little blacker than I thought they should look. I actually get fantastic milage with this thing and have checked it at 24 mpg freeway. Which is in line with what the man a free literature used to talk about. I have a tendency to wonder about the power valves because there are only 2 cylinders making a vac signal for each carb? there is no manifold vacuum port to attach a gauge to. But there is a ported fitting, I may t a gauge into the vac adv hose and see what there is, or I guess I could t into the pcv vacuum....
  6. Paul
    Paul
    Editor
    they say memory is the first thing to go..
    must have been 10 under then..
    mine for what it's worth, twenty plus years ago, no wonder my recollection is dim..
    I must have been checking plugs, the wires are not attached
    porkshop, 61Cruiser, enloe and 7 others like this.
  7. DDDenny
    Paul
    You didn't mention that copper fuel line, I would have but I didn't want Mark to think less of me.:oops:
    porkshop and Sharpone like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    haha, it is that nicopp stuff.. that stuff is ok ain't it? I don't think you can even buy the old zinc plated steel anymore can you??
    porkshop, Sharpone and 427 sleeper like this.
  9. DDDenny
    If I may be so bold........
    Zip Products has various Chevy (OEM) pump to carb line kits in both chrome and SS, some slight modifications but with your skills, eezy peezy.
    I do see they have become a bit pricey since I last inquired.
    porkshop, Sharpone and Moriarity like this.
  10. badgascoupe
    badgascoupe
    Mostly done with a door skin on the 39 pu. Gotta add a welding rod edge to a cpl spots but im pleased with it.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ve been lucky. NAPA is the only drive to parts store to get it. Then again, it’s been a year since I last bought some.
  12. verno30
    verno30
    Still completing ***embly on the 55 g***er.
    Hope to start on bodywork in the next couple weeks
    20250321_092405.jpg 20250321_092423.jpg 20250321_092432.jpg 20250321_092446.jpg 20250321_092453.jpg 20250321_092500.jpg
    porkshop, 61Cruiser, Sharpone and 7 others like this.
  13. Learning facts just in time versus learning too late. I specialize in the latter but once in awhile relieved to find out critical things just in time.
  14. saltflats
    saltflats
    from Missouri
    Kinda wondered why I never primed the oil pump on this one. This project has been a very slow build as it isn't the owners main priority so visits can be spread out for a spell.
  15. High test 63
    High test 63
    ...As he picked up his hammer and saw ...
  16. alanp561
    alanp561
    porkshop likes this.
  17. patsurf
    patsurf
    doesn't the up and down at the heim take care of that
    porkshop and Tickety Boo like this.
  18. Dick Stevens
    Dick Stevens
    It would also have to pivot at the connecting point on the rear end to not bind a little
  19. tubman
    tubman
    I was starting to wonder about binding myself, but then I saw that this is a G***er.
    porkshop, swade41 and Tickety Boo like this.
  20. patsurf
    patsurf
    i can't quite picture it for some reason-thought that the swing at one end and up down at other would do all the twisting
  21. Dick Stevens
    Dick Stevens
    The suspension still has to work even in a g***er!
  22. Paul
    Paul
    Editor
    looks like a heim at both ends to me
    and heavy ones at that.
    porkshop, verno30 and Tickety Boo like this.
  23. Dick Stevens
    Dick Stevens
    My 81 year old eyes aren't seeing a heim joint on the end connected to the rear end
    porkshop and verno30 like this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
  25. 50chevytx
    50chevytx
    Would think it would work better if heim joints were parallel
  26. swade41
    swade41
    from Buffalo,NY
    mad mikey likes this.
  27. dana barlow
    dana barlow
    from Miami Fla.
    Well.no car show this weekend for me;
    Hotrod failedTonights test drive friday ,I though I'd fixed every thing,added new rad. n all. But NOPE. leaking cooling water between timing chain housing and block. So likely killed my new oil n filter,my new water wetter, wasted as well. along with a lot of hours,, Fan now flexing above 2000 rpm and hitting top tank of new rad. < was not doing it before getting super hot=must of made the plastic soft it was made from..Was big deal to fit new rad in,as not same as old one that got two leaks{ Alum so I can't fix them my self { Who can fix alum rad's,?,,,So old rad could of been a back up! Pretty much two weeks n too many $$$ wasted= nothing fixed. Not going to car show after all. Was really trying,but I failed. [​IMG]. I'll look a little closer maybe sunday or monday..
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
  29. gene-koning
    gene-koning
    Just to show my ignorance, isn't the bar suppose to be level before the bend? How does that bar in its current position, not shift the rear axle side to side as the suspension travels up and down?
    After some thought, maybe the bar is level with the body on the frame? Would that eliminate most of the bind as well?
  30. Dick Stevens
    Dick Stevens
    I can see the heim joint on that end, it's the other end I am not seeing and if there is one the orientation is not the best to make it work IMHO
