Hot Rods 392 Hemi Neilson cam info needed
Discussion in 'The Hokey Ass Message Board' started by indianmark, Mar 14, 2025.
  1. indianmark
    indianmark
    I picked up a project 57 392 engine that came with a Neilson cam.
    I was told it was a roller Neilson re-grind with a blower profile and came with a box of new solid roller lifters.
    Card in box reads as follows:
    Engine 392 Chrysler
    Cam Grind R-570
    Valve Lift .572"
    Duration 290° 252° @ .050"
    Valve Clearance .025"
    112°
    Anyone help decipher these specs? I am not familiar with roller cams but a .572 valve lift seems huge.
    Thanks to all!
  2. Deuces
    Deuces
  3. indianmark
    indianmark
    Numbers stamped in end of cam:
    569356
    00J1A
  4. indianmark
    indianmark
    Anyone shed some light on this Neilson cam?
  5. indianmark
    indianmark
    Any Hemi guys out there?
  6. caprockfabshop
    caprockfabshop
    Have you considered calling one of the cam companies and giving them those specs and getting their thoughts? I'm not sure what information you're looking for here.
  7. 73RR
    73RR
    Although Chris was talented, I'm not sure how he got 572 lift on a reground roller. Those lobes gotta be small.
    A couple thoughts;
    When lifts go past 500, all else being in stock configuration, you will get the rocker tip sliding/scuffing across the valve tip (side loading the guide). Yes, lash caps will ease this but, now you are adding length to the top of the valve. Lifts above 520 really require that the shafts be moved in the stands to maintain geometry. And yes, you could buy some of the aftermarket stands that have relocated shafts, ***uming they are where you need them or step up to custom roller tip rockers.
    gimpyshotrods likes this.
  8. indianmark
    indianmark
    I did call Oregon cam and they did say that .572 is a lot of lift and the 290/252 duration is for a high reving engine.
    Not much else.
    Gary, I agree with everthing you said in your response above. I don't know if this is a roller or not. Either way .572 is a big lift and probably not for me as I do not want deal with all of the valve train geometry issues or build a race engine.
    Maybe a good cam company can figure it out if I send it to them?
  9. 73RR
    73RR
    The lobe is generous on the nose, almost looks like a roller. The huge duration also makes a fat nose so someone with a CamDoctor will need to look at the ramps.
