Projects Spreading a coil spring
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Mar 22, 2025.
  1. IowaTom
    IowaTom
    I'm needing to spread the coils on a '52 Willys Aero just enough to get a pair of hard rubber lift blocks in. Have tried all kinds of knuckle-busting ways to open it wide enough. Have the tire off but not interested in loosening a control arm. I've looked around the shop for something that could wedge or do a jaws-of-life but no luck. Sooo, I've ordered this from azamon (for squeezing a caliper) and hope it has the horsepower to spread my springs just an inch or so. Have you ever had such a dilemma?
  2. IowaTom
    IowaTom
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. Budget36
    Budget36
    The front coils in my ‘78 Fbody sagged a bit. I got these things that sorta screwed in between the coils. Sorta square, but was 4-5-6 sided (been 40 years) but easy to put in with a 1/2 ratchet
    Don't recall what they were called though.
    Moriarity likes this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
  6. Budget36
    Budget36
    IMG_1651.png These are listed at 15.99 at AutoZone
    Kevin Ardinger, IowaTom and Moriarity like this.
  7. Budget36
    Budget36
    Not quite what I used back when, but similar
  8. IowaTom
    IowaTom
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    I think they are intended for rear coil springs where the wraps are further apart. There are 2 sizes of the twist in with a 1/2" drive rachet , same deal the smaller ones are for front springs where the wraps are closer together. I wonder if the rubber ones you have are meant for rear springs.... I have always been able to get those in with a little vaseline on them and grab the middle of them with a channel lock and twist em in. But if you are trying to put the ones meant for rear springs in a front spring, I don't care what you do it ain't goin in....
    saltflats, 427 sleeper and Budget36 like this.
  10. 6sally6
    6sally6
    Splitting wedge ?! Like when you're cutting/splitting far-wood...
    Maybe drive it in with a ship fitter's hammer.
    Coal chisel ? and ^^^^^^^^^^^^^^^^^^^^ !
    6sally6
    427 sleeper and 49ratfink like this.
  11. I'm sure this is a question not needed to be asked, but is the car supported by the frame and not under the control arm. Sorry for asking such a dumb question but I've seen some pretty wild stuff over the years.
    427 sleeper and Moriarity like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    skip a coil , surely it will go in that way, maybe you can spread it enough to get one in next to it then?
    427 sleeper likes this.
  13. Budget36
    Budget36
    Incorrect info, deleted my response
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    If the rubbers he is trying to put in are truly intended for front spring use, there should be no spring spreading required.....
  15. Dan Timberlake
    Dan Timberlake
    lubrication makes the world go round.
  16. Joe H
    Joe H
  17. hoop
    hoop
    I used a duck bill porta power.Worked for me.
    Algoma56, 2OLD2FAST and lostone like this.
  18. That caliper piston tool uses a mechanism similar to a caulk gun, it won't be spreading a suspension coil spring 1", I would either return it or use it for the intended purpose.
  19. Joe H
    Joe H
  20. KenC
    KenC
    That's what I was going to suggest.
    That or a ball joint or tie rod separator, the kind is just a forked wedge that you drive in. Probably need one for heavy trucks in order to be thick enough. Either small or large should enough to let you start the twist in wedges.
  21. twenty8
    twenty8
    Have you disconnected the shocks? Full droop will be limited if they are still in place.
    saltflats likes this.
  22. If the vehicle sees road use, those little twist-in spacers will fling out of the spring when the suspension droops. The bolt in spreaders will also get bent during compression and fall out. I learned those lessons 25 years ago. The best "spacer" is one that slips around the top or bottom of the coil spring and is trapped between the spring and the mounting point. This type of spacer also doesn't change the spring rate like the others do. Also, new coil springs are cheap.
    saltflats and IowaTom like this.
  23. Clydesdale
    Clydesdale
    yea gotta agree, anything other than a block under the spring base with a registration for the pigtail or a new spring all together is just a waste of time, after all the fangled tools and devices you'll buy it wont be far off a new set of springs.
    IowaTom likes this.
  24. IowaTom
    IowaTom
    You nailed it, Nick! It didn't have the umph to spread the coils enough. Keeping it, tho, for calipers.
    Pocket Nick likes this.
  25. IowaTom
    IowaTom
    Yes, shock is disconnected. I'm sure you guys are right about either replacing the shocks or adding the blocks under the coil seat. I dread undoing a control arm knuckle...but maybe gotta do it.
  26. fastcar1953
    fastcar1953
    Replacing spring or adding a spacer under one is easier than you think. Could of been done by now.
    SS327 and 427 sleeper like this.
  27. Budget36
    Budget36
    He just want to spread the springs to use what he has if I read the first post correctly.
  28. Budget36
    Budget36
    Is that the spreader attachment? I have one, never knew that’s what it was called.
  29. hoop
    hoop
    Yes .It is a spreader.
    Budget36 likes this.
  30. 6sally6
    6sally6
    Best move is to get thicker rubber spring isolators They come in MANY different thicknesses
    I used a 1" size to raise my (M-word) up enough it wouldn't scrub going over speed bumps.
    I bet Rock Auto has them.........
    6sally6
